Tak wyglada moja siec
_______SERVER_______
..eth0......eth1.......eth2....eth3..
...K1.........K2........internet........
na K2 NIE dziala internet i NIE dziala ping do servera
K1 i K2 sa dobrze skonfigurowane bo zamieniajac je miejscami internet dzialal na innych kompach ;]
W skr[u/o]cie siec dziala na eth0 ale juz nie chce dzialac na eth1
Co zrobic zeby dzialal net na eth1?
//Edit: Moze jest w tym blad ze pare kart ma ten sam adres czyli: 192.168.0.1??
Dolaczam kody:
→# ifconfig
→# cat /etc/init.d/maskarada
→# lspci | grep Et
→# cat /etc/network/interfaces
→# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0E:2E:9C:73:20
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::20e:2eff:fe9c:7320/64 Scope:Link
RX packets:149 errors:0 dropped:0 overruns:0 frame:0
TX packets:862 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:14272 (13.9 KiB) TX bytes:64140 (62.6 KiB)
Interrupt:177 Base address:0xc400
eth1 Link encap:Ethernet HWaddr 00:60:52:08:7F:0D
inet6 addr: fe80::260:52ff:fe08:7f0d/64 Scope:Link
RX packets:1778 errors:0 dropped:0 overruns:0 frame:0
TX packets:23 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:118626 (115.8 KiB) TX bytes:2988 (2.9 KiB)
Interrupt:185 Base address:0xc800
eth2 Link encap:Ethernet HWaddr 00:E0:7D:E4:C0:F7
inet addr:89.76.62.86 Bcast:255.255.255.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:576 Metric:1
RX packets:21223 errors:0 dropped:0 overruns:0 frame:0
TX packets:4949 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2647005 (2.5 MiB) TX bytes:458240 (447.5 KiB)
Interrupt:193 Base address:0xcc00
eth3 Link encap:Ethernet HWaddr 00:05:1C:0:D B:D E
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:169 Base address:0xc000
lo Link encap:Local Loopback
RX packets:73 errors:0 dropped:0 overruns:0 frame:0
TX packets:73 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5367 (5.2 KiB) TX bytes:5367 (5.2 KiB)Kod: Zaznacz cały
#!/bin/sh
case "$1" in
start)
echo 'Wlaczam NAT'
/sbin/iptables -F -t nat
/sbin/iptables -X -t nat
/sbin/iptables -F -t filter
/sbin/iptables -X -t filter
/sbin/iptables -t filter -P FORWARD DROP
/sbin/iptables -t filter -A FORWARD -s 192.168.0.0/24 -d 0/0 -j ACCEPT
/sbin/iptables -t filter -A FORWARD -s 0/0 -d 192.168.0.0/24 -j ACCEPT
/sbin/iptables -t nat -A POSTROUTING -s 192.168.0.0/24 -d 0/0 -j MASQUERADE
stop)
echo 'KoÅczÄ pracÄ Netfiltera'
echo 'UÅźycie: /etc/init.d/maskarada {start|stop}'
exit 1
esac
exit 0Kod: Zaznacz cały
00:0a.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0c.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0d.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)Kod: Zaznacz cały
auto lo
iface lo inet loopback
allow-hotplug eth2
auto eth2
iface eth2 inet dhcp
auto eth0
iface eth0 inet static
address 192.168.0.1
netmask 255.255.255.0
auto eth1
iface eth1 inet static
address 192.168.0.1
auto eth3
iface eth3 inet static
address 192.168.0.1
