Karta dźwi
freetu
Karta dźwiękowa i ustawienia mikrofonu - Ubuntu 9.04
Post autor: freetu »
Witam, mam problem. Posiadam Linuksa Ubuntu 9.04. Nie działa mi mikrofon, tylko straszny szum słychać, a pod Windowsem działa.
Po wpisaniu komendy:
lspci
coś takiego mam:
freetu@freetu-linux:~$ lspci
00:00.0 Host bridge: nVidia Corporation nForce3 250Gb Host Bridge (rev a1)
00:01.0 ISA bridge: nVidia Corporation nForce3 250Gb LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation nForce 250Gb PCI System Management (rev a1)
00:02.0 USB Controller: nVidia Corporation CK8S USB Controller (rev a1)
00:02.1 USB Controller: nVidia Corporation CK8S USB Controller (rev a1)
00:02.2 USB Controller: nVidia Corporation nForce3 EHCI USB 2.0 Controller (rev a2)
00:05.0 Bridge: nVidia Corporation CK8S Ethernet Controller (rev a2)
00:06.0 Multimedia audio controller: nVidia Corporation nForce3 250Gb AC'97 Audio Controller (rev a1)
00:08.0 IDE interface: nVidia Corporation CK8S Parallel ATA Controller (v2.5) (rev a2)
00:09.0 IDE interface: nVidia Corporation nForce3 Serial ATA Controller 2 (rev a2)
00:0a.0 IDE interface: nVidia Corporation nForce3 Serial ATA Controller (rev a2)
00:0b.0 PCI bridge: nVidia Corporation nForce3 250Gb AGP Host to PCI Bridge (rev a2)
00:0e.0 PCI bridge: nVidia Corporation nForce3 250Gb PCI-to-PCI Bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 AP [Radeon 9600]
01:00.1 Display controller: ATI Technologies Inc RV350 AP [Radeon 9600] (Secondary)
02:08.0 Network controller: RaLink RT2760 Wireless 802.11n 1T/2R Cardbus
Może ktoś pomóc?
PS. Uwaga jestem początkującym użytkownikiem Linuksa, jeżeli decydujesz się na pomoc, proszę o dokładne instrukcję.
f1.micro
Post autor: f1.micro »
To jest mikrofon zewnętrzny? Jeżeli masz dwa - jeden wbudowany drugi do wpięcia, musisz obczaić który jest. Najpewniej ten wbudowany będzie oznaczony jako FRONT.
Jeżeli robi Ci się sprzężenie a nie nagrywa (nie słychać Cię w skype), to nie masz włączonego przechwytywania.
Najłatwiej kliknąć w ikonę volume-manager prawym i zaznaczyć przechwytywanie, a następnie włączyć.
