monitor wy
mer
monitor wyłącza się przy niektórych grach
Post autor: mer »
xorg.conf: http://wklej.org/id/293560/
Section "Files"
        FontPath        "/usr/share/fonts/X11/misc"
        FontPath        "/usr/share/fonts/X11/cyrillic"
        FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
        FontPath        "/usr/share/fonts/X11/Type1"
        FontPath        "/usr/share/fonts/X11/100dpi"
        FontPath        "/usr/share/fonts/X11/75dpi"
        # path to defoma fonts
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
        Load    "i2c"
        Load    "bitmap"
        Load    "ddc"
        Load    "dri"
        Load    "extmod"
        Load    "freetype"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
     Load    "dbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc105"
        Option          "XkbLayout"     "pl"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "ImPS/2"
        Option          "ZAxisMapping"          "4 5"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "Device"
        Identifier      "nVidia Corporation NV17 [GeForce4 MX 440]"
        Driver          "nvidia"
    Option "AddARGBGLXVisuals" "true"
    Option "DisableGLXRootClipping" "true"
        BusID           "PCI:1:0:0"
EndSection
Section "Monitor"
        Identifier      "T710PH"
        Option          "DPMS"
        HorizSync      30-80
        VertRefresh    50-100
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "nVidia Corporation NV17 [GeForce4 MX 440]"
        Monitor         "T710PH"
        DefaultDepth    24
        SubSection "Display"
                Depth           1
                Modes           "1280x1024" "1024x768" "800x600" "640x480"
        EndSubSection
                Depth           4
        EndSubSection
                Depth           8
        EndSubSection
                Depth           15
        EndSubSection
                Depth           16
        EndSubSection
                Depth           24
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
EndSection
Section "DRI"
        Mode    0666
EndSection
Section "Extensions"
    Option "Composite" "Enable"
EndSection
Problem taki, że gry korzystające z open Gl chyba (na razie Super tux i Cs 1.6 steam) wyłączają monitor. Na monitorze jest:
mode not suported
Monitor to hyundai n19s.
godlark
Post autor: godlark »
Pewnie próbujesz mu ustawić za dużą rozdzielczość lub odświeżanie.
mer, dostarcz zawartość pliku:
/var/log/Xorg.0.log
i wyniki:
cat /etc/apt/sources.list
uname -r
mer
Post autor: mer »
godlark, wiem ale gry same to wymuszają.
Log Xorga (wcześniej supertux włączony).
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny2)
Current Operating System: Linux debian 2.6.26-2-686 #1 SMP Wed Feb 10 08:59:21 UTC 2010 i686
Build Date: 08 June 2009  09:12:57AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar 12 19:09:29 2010
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "T710PH"
(**) |   |-->Device "nVidia Corporation NV17 [GeForce4 MX 440]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
    Entry deleted from font path.
(==) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
    /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
(==) RgbPath set to "/etc/X11/rgb"
(**) Extension "Composite" is enabled
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
    X.Org ANSI C Emulation: 0.3
    X.Org Video Driver: 2.0
    X.Org XInput driver : 2.0
    X.Org Server Extension : 0.3
    X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
    compiled for 1.4.2, module version = 1.0.0
    ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 8086,2570 card 1028,0151 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 1028,0151 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 1028,0151 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24d7 card 1028,0151 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,24de card 1028,0151 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 1028,0151 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24db card 1028,0151 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,24d1 card 1028,0151 rev 02 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 1028,0151 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24d5 card 1028,0151 rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0171 card 10b0,0002 rev a3 class 03,00,00 hdr 00
(II) PCI: 02:07:0: chip 1102,0007 card 1102,100a rev 00 class 04,01,00 hdr 00
(II) PCI: 02:0c:0: chip 8086,100e card 1028,0151 rev 02 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
    [0] -1    0    0x00000000 - 0x0000ffff (0x10000) IX[B]
    [0] -1    0    0x00000000 - 0xffffffff (0x0) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
    [0] -1    0    0xfd000000 - 0xfeafffff (0x1b00000) MX[B]
(II) Bus 1 prefetchable memory range:
    [0] -1    0    0xf0000000 - 0xf80fffff (0x8100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
    [0] -1    0    0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
    [0] -1    0    0xfcf00000 - 0xfcffffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV17 [GeForce4 MX 440] rev 163, Mem @ 0xfd000000/24, 0xf0000000/27, 0xf8000000/19, BIOS @ 0xfea00000/17
    [1] -1    0    0x00000000 - 0x0000ffff (0x10000) IX[B]
    [0] -1    0    0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [1] -1    0    0x000f0000 - 0x000fffff (0x10000) MX[B]
    [2] -1    0    0x000c0000 - 0x000effff (0x30000) MX[B]
    [3] -1    0    0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [4] -1    0    0x0000ffff - 0x0000ffff (0x1) IX[B]
    [5] -1    0    0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xefffffff to 0xdfffffff
(II) Active PCI resource ranges:
    [0] -1    0    0xfcfe0000 - 0xfcffffff (0x20000) MX[B]
    [1] -1    0    0xfebff900 - 0xfebff9ff (0x100) MX[B]
    [2] -1    0    0xfebffa00 - 0xfebffbff (0x200) MX[B]
    [3] -1    0    0xfebffc00 - 0xfebfffff (0x400) MX[B]
    [4] -1    0    0xffa80800 - 0xffa80bff (0x400) MX[B]
    [5] -1    0    0xe0000000 - 0xdfffffff (0x0) MX[B]O
    [6] -1    0    0xfea00000 - 0xfea1ffff (0x20000) MX[B](B)
    [7] -1    0    0xf8000000 - 0xf807ffff (0x80000) MX[B](B)
    [8] -1    0    0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [9] -1    0    0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
    [10] -1    0    0x0000df40 - 0x0000df7f (0x40) IX[B]
    [11] -1    0    0x0000df20 - 0x0000df3f (0x20) IX[B]
    [12] -1    0    0x0000edc0 - 0x0000edff (0x40) IX[B]
    [13] -1    0    0x0000ee00 - 0x0000eeff (0x100) IX[B]
    [14] -1    0    0x0000eda0 - 0x0000edbf (0x20) IX[B]
    [15] -1    0    0x0000fea0 - 0x0000feaf (0x10) IX[B]
    [16] -1    0    0x0000fe30 - 0x0000fe33 (0x4) IX[B]
    [17] -1    0    0x0000fe20 - 0x0000fe27 (0x8) IX[B]
    [18] -1    0    0x0000fe10 - 0x0000fe13 (0x4) IX[B]
    [19] -1    0    0x0000fe00 - 0x0000fe07 (0x8) IX[B]
    [20] -1    0    0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    [21] -1    0    0x00000374 - 0x00000374 (0x1) IX[B]
    [22] -1    0    0x00000170 - 0x00000177 (0x8) IX[B]
    [23] -1    0    0x000003f4 - 0x000003f4 (0x1) IX[B]
    [24] -1    0    0x000001f0 - 0x000001f7 (0x8) IX[B]
    [25] -1    0    0x0000ff20 - 0x0000ff3f (0x20) IX[B]
    [26] -1    0    0x0000ff40 - 0x0000ff5f (0x20) IX[B]
    [27] -1    0    0x0000ff60 - 0x0000ff7f (0x20) IX[B]
    [28] -1    0    0x0000ff80 - 0x0000ff9f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
    [4] -1    0    0xfcfe0000 - 0xfcffffff (0x20000) MX[B]
    [5] -1    0    0xfebff900 - 0xfebff9ff (0x100) MX[B]
    [6] -1    0    0xfebffa00 - 0xfebffbff (0x200) MX[B]
    [7] -1    0    0xfebffc00 - 0xfebfffff (0x400) MX[B]
    [8] -1    0    0xffa80800 - 0xffa80bff (0x400) MX[B]
    [9] -1    0    0xe0000000 - 0xdfffffff (0x0) MX[B]O
    [10] -1    0    0xfea00000 - 0xfea1ffff (0x20000) MX[B](B)
    [11] -1    0    0xf8000000 - 0xf807ffff (0x80000) MX[B](B)
    [12] -1    0    0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
    [13] -1    0    0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
    [14] -1    0    0x0000ffff - 0x0000ffff (0x1) IX[B]
    [15] -1    0    0x00000000 - 0x000000ff (0x100) IX[B]
    [16] -1    0    0x0000df40 - 0x0000df7f (0x40) IX[B]
    [17] -1    0    0x0000df20 - 0x0000df3f (0x20) IX[B]
    [18] -1    0    0x0000edc0 - 0x0000edff (0x40) IX[B]
    [19] -1    0    0x0000ee00 - 0x0000eeff (0x100) IX[B]
    [20] -1    0    0x0000eda0 - 0x0000edbf (0x20) IX[B]
    [21] -1    0    0x0000fea0 - 0x0000feaf (0x10) IX[B]
    [22] -1    0    0x0000fe30 - 0x0000fe33 (0x4) IX[B]
    [23] -1    0    0x0000fe20 - 0x0000fe27 (0x8) IX[B]
    [24] -1    0    0x0000fe10 - 0x0000fe13 (0x4) IX[B]
    [25] -1    0    0x0000fe00 - 0x0000fe07 (0x8) IX[B]
    [26] -1    0    0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    [27] -1    0    0x00000374 - 0x00000374 (0x1) IX[B]
    [28] -1    0    0x00000170 - 0x00000177 (0x8) IX[B]
    [29] -1    0    0x000003f4 - 0x000003f4 (0x1) IX[B]
    [30] -1    0    0x000001f0 - 0x000001f7 (0x8) IX[B]
    [31] -1    0    0x0000ff20 - 0x0000ff3f (0x20) IX[B]
    [32] -1    0    0x0000ff40 - 0x0000ff5f (0x20) IX[B]
    [33] -1    0    0x0000ff60 - 0x0000ff7f (0x20) IX[B]
    [34] -1    0    0x0000ff80 - 0x0000ff9f (0x20) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded by default.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
    compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
    compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module  96.43.16  Thu Jan 28 16:14:25 PST 2010
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
    compiled for 1.4.2, module version = 1.1.0
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
    compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
    compiled for 1.4.0.90, module version = 1.3.1
    ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
    compiled for 1.4.0.90, module version = 1.3.0
(II) NVIDIA dlloader X Driver  96.43.16  Thu Jan 28 16:02:25 PST 2010
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
    ABI class: X.Org ANSI C Emulation, version 0.3
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
    [14] 0    0    0x000a0000 - 0x000affff (0x10000) MS[B]
    [15] 0    0    0x000b0000 - 0x000b7fff (0x8000) MS[B]
    [16] 0    0    0x000b8000 - 0x000bffff (0x8000) MS[B]
    [17] -1    0    0x0000ffff - 0x0000ffff (0x1) IX[B]
    [18] -1    0    0x00000000 - 0x000000ff (0x100) IX[B]
    [19] -1    0    0x0000df40 - 0x0000df7f (0x40) IX[B]
    [20] -1    0    0x0000df20 - 0x0000df3f (0x20) IX[B]
    [21] -1    0    0x0000edc0 - 0x0000edff (0x40) IX[B]
    [22] -1    0    0x0000ee00 - 0x0000eeff (0x100) IX[B]
    [23] -1    0    0x0000eda0 - 0x0000edbf (0x20) IX[B]
    [24] -1    0    0x0000fea0 - 0x0000feaf (0x10) IX[B]
    [25] -1    0    0x0000fe30 - 0x0000fe33 (0x4) IX[B]
    [26] -1    0    0x0000fe20 - 0x0000fe27 (0x8) IX[B]
    [27] -1    0    0x0000fe10 - 0x0000fe13 (0x4) IX[B]
    [28] -1    0    0x0000fe00 - 0x0000fe07 (0x8) IX[B]
    [29] -1    0    0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    [30] -1    0    0x00000374 - 0x00000374 (0x1) IX[B]
    [31] -1    0    0x00000170 - 0x00000177 (0x8) IX[B]
    [32] -1    0    0x000003f4 - 0x000003f4 (0x1) IX[B]
    [33] -1    0    0x000001f0 - 0x000001f7 (0x8) IX[B]
    [34] -1    0    0x0000ff20 - 0x0000ff3f (0x20) IX[B]
    [35] -1    0    0x0000ff40 - 0x0000ff5f (0x20) IX[B]
    [36] -1    0    0x0000ff60 - 0x0000ff7f (0x20) IX[B]
    [37] -1    0    0x0000ff80 - 0x0000ff9f (0x20) IX[B]
    [38] 0    0    0x000003b0 - 0x000003bb (0xc) IS[B]
    [39] 0    0    0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "true"
(**) NVIDIA(0): Option "DisableGLXRootClipping" "true"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):     enabled.
(WW) NVIDIA(GPU-0): Unable to read EDID for display device CRT-0
(II) NVIDIA(0): NVIDIA GPU GeForce4 MX 440 at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 65536 kBytes
(--) NVIDIA(0): VideoBIOS: 04.17.00.60.20
(II) NVIDIA(0): Detected AGP rate: 4X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce4 MX 440 at PCI:1:0:0:
(--) NVIDIA(0):     CRT-0
(--) NVIDIA(0): CRT-0: 350.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-0
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "1280x1024"
(II) NVIDIA(0):     "1024x768"
(II) NVIDIA(0):     "800x600"
(II) NVIDIA(0):     "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(WW) NVIDIA(0): Unable to get display device CRT-0's EDID; cannot compute DPI
(WW) NVIDIA(0):     from CRT-0's EDID.
(==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GART.
(II) NVIDIA(0): Setting mode "1280x1024"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(**) Option "CoreKeyboard"
(**) Generic Keyboard: always reports core events
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Generic Keyboard: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: always reports core events
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Configured Mouse: Sensitivity: 1
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
(II) NVIDIA(0): Setting mode "1280x1024_60"
SetClientVersion: 0 9
(II) NVIDIA(0): Setting mode "640x480"
Repozytoria (tak wiem mam niezły bałągan):
# deb http://ftp.pwr.wroc.pl/debian/ lenny main
deb-src http://ftp.pwr.wroc.pl/debian/ lenny main
deb http://security.debian.org/ lenny/updates main
deb-src http://security.debian.org/ lenny/updates main
deb http://volatile.debian.org/debian-volatile lenny/volatile main
deb-src http://volatile.debian.org/debian-volatile lenny/volatile main
deb http://ftp.de.debian.org/debian lenny main
#~~~~~~Lenny~~~~~~#
deb http://ftp.pl.debian.org/debian/ lenny main non-free contrib
deb-src http://ftp.pl.debian.org/debian/ lenny main non-free contrib
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/ lenny/updates main contrib non-free
#~~~~~~Debian-multimedia~~~~~~#
deb http://www.debian-multimedia.org lenny main
deb-src http://www.debian-multimedia.org lenny main
#flashplugin-nonfree
deb http://repo.dug.net.pl/dfr/ etch main contrib
deb http://www.lamaresh.net/apt lenny main
