vo = gl
MPlayer interrupted by signal 11 in module: decode_video
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
AVI file format detected.
[aviheader] Video stream found, -vid 0
[aviheader] Audio stream found, -aid 1
VIDEO: [XVID] 640x272 12bpp 23.976 fps 928.7 kbps (113.4 kbyte/s)
Clip info:
Software: VirtualDubMod 1.5.10.2 (build 2540/release)
SUB: Added subtitle file (1): /home/grubas/Downloads/Surrogates/Surrogates.txt
[gl] using extended formats. Use -vo gl:nomanyfmts if playback fails.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
[mpeg4 @ 0xd22c80]Invalid and inefficient vfw-avi packed B frames detected
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
Movie-Aspect is 2.35:1 - prescaling to correct movie aspect.
[swscaler @ 0xe0a3e0]using unscaled yuv420p -> rgb32 special converter
VO: [gl] 640x272 => 640x272 BGRA
