Postfix wirtualni użytkownicy na mysql - b
dong
Postfix wirtualni uŻytkownicy na mysql - błędy połączeń
Post autor: dong »
Mam postfixa i wirtualnych użytkowników w MySQL.
Pojawiają się takie błędy:
Mar  2 10:32:09 kimsufi postfix/smtpd[25002]: connect from alv85.rev.netart.pl[85.128.178.85]
Mar  2 10:32:09 kimsufi postfix/smtpd[25002]: warning: mysql query failed: MySQL server has gone away
Mar  2 10:32:09 kimsufi postfix/smtpd[25002]: NOQUEUE: reject: RCPT from alv85.rev.netart.pl[85.128.178.85]: 451 4.3.0 <login1@host.pl>: Temporary lookup failure; from=<heniek@heniek.nazwa.pl> to=<login1@host.pl> proto=ESMTP helo=<heniek.nazwa.pl>
Mar  2 10:32:09 kimsufi postfix/cleanup[25006]: D7A95CA045: message-id=<20100302093209.D7A95CA045@kimsufi.kimsufi.com>
Mar  2 10:32:09 kimsufi postfix/qmgr[658]: D7A95CA045: from=<double-bounce@kimsufi.kimsufi.com>, size=1110, nrcpt=1 (queue active)
Mar  2 10:32:09 kimsufi postfix/virtual[25007]: warning: mysql query failed: MySQL server has gone away
Mar  2 10:32:09 kimsufi postfix/virtual[25007]: warning: table virtual_mailbox_maps: lookup [email]postmaster@moj.org[/email]: Success
Mar  2 10:32:09 kimsufi postfix/smtpd[25002]: disconnect from alv85.rev.netart.pl[85.128.178.85]
Mar  2 10:32:09 kimsufi postfix/virtual[25007]: D7A95CA045: to=<postmaster@moj.org>, orig_to=<postmaster>, relay=virtual, delay=0.03, delays=0.01/0.01/0/0.01, dsn=4.3.5, status=deferred (mail system configuration error)
Mar  2 10:35:29 kimsufi postfix/anvil[25004]: statistics: max connection rate 1/60s for (smtp:212.91.6.33) at Mar  2 10:31:24
Mar  2 10:35:29 kimsufi postfix/anvil[25004]: statistics: max connection count 1 for (smtp:212.91.6.33) at Mar  2 10:31:24
Mar  2 10:35:29 kimsufi postfix/anvil[25004]: statistics: max cache size 2 at Mar  2 10:32:09
Mar  2 10:38:55 kimsufi postfix/pickup[21521]: EBC20CA051: uid=33 from=<www-data>
Mar  2 10:38:55 kimsufi postfix/cleanup[25469]: EBC20CA051: message-id=<20100302093851.0a1b99527c84@www.mojhost.org>
Mar  2 10:38:55 kimsufi postfix/qmgr[658]: EBC20CA051: from=<www-data@kimsufi.kimsufi.com>, size=833, nrcpt=1 (queue active)
Mar  2 10:38:56 kimsufi postfix/smtp[25472]: EBC20CA051: to=<beatika@op.pl>, relay=mx.poczta.onet.pl[213.180.147.146]:25, delay=0.44, delays=0.06/0.01/0.18/0.19, dsn=2.0.0, status=sent (250 2.0.0 Accepted; S134220631Ab0CBJgFjV3i0)
Mar  2 10:38:56 kimsufi postfix/qmgr[658]: EBC20CA051: removed
Mar  2 10:41:14 kimsufi postfix/qmgr[658]: D7A95CA045: from=<double-bounce@kimsufi.kimsufi.com>, size=1110, nrcpt=1 (queue active)
Mar  2 10:41:14 kimsufi postfix/virtual[25770]: D7A95CA045: to=<postmaster@moj.org>, orig_to=<postmaster>, relay=virtual, delay=545, delays=544/0.04/0/0.01, dsn=2.0.0, status=sent (delivered to maildir)
Mar  2 10:41:14 kimsufi postfix/qmgr[658]: D7A95CA045: removed
Mar  2 10:41:58 kimsufi postfix/smtpd[25773]: warning: database /etc/aliases.db is older than source file /etc/aliases
Mar  2 10:41:58 kimsufi postfix/smtpd[25773]: connect from alv85.rev.netart.pl[85.128.178.85]
Mar  2 10:41:58 kimsufi postfix/smtpd[25773]: 6F18CCA045: client=alv85.rev.netart.pl[85.128.178.85]
Mar  2 10:41:58 kimsufi postfix/cleanup[25777]: 6F18CCA045: message-id=<210cf83e4a11c6e7cd35c23cd1b26dfb@www.alfaclub.pl>
Mar  2 10:41:58 kimsufi postfix/qmgr[658]: 6F18CCA045: from=<heniek@heniek.nazwa.pl>, size=1504, nrcpt=1 (queue active)
Mar  2 10:41:58 kimsufi postfix/virtual[25770]: warning: mysql query failed: MySQL server has gone away
Mar  2 10:41:58 kimsufi postfix/virtual[25770]: warning: table virtual_mailbox_maps: lookup [email]login1@host.pl[/email]: Success
Hosty celowo zmieniłem. Pojawia się to raz na jakiś czas. Raz maile dochodzą, raz nie.
To konfiguracja mojego MySQL:
[client]
default-character-set=latin2
port = 3306
socket = /var/run/mysqld/mysqld.sock
[mysqld]
language=/usr/share/mysql/polish
character-sets-dir=/usr/share/mysql/charsets
default-collation=latin2_general_ci
skip-character-set-client-handshake
bind-address = 127.0.0.1
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
#skip-name-resolve
safe-show-database
#old_passwords
back_log = 50
skip-innodb
max_connections = 300
key_buffer_size = 80M
myisam_sort_buffer_size = 64M
myisam_max_sort_file_size = 2048M
join_buffer_size = 1M
read_buffer_size = 1M
sort_buffer_size = 2M
table_cache = 4000
thread_cache_size = 256
wait_timeout = 30
interactive_timeout = 60
connect_timeout = 20
tmp_table_size = 64M
max_heap_table_size = 64M
max_allowed_packet = 64M
net_buffer_length = 16384
max_connect_errors = 100000
thread_concurrency = 4
concurrent_insert = 2
table_lock_wait_timeout = 30
read_rnd_buffer_size = 786432
bulk_insert_buffer_size = 8M
query_cache_limit = 2M
query_cache_size = 48M
query_cache_type = 1
query_prealloc_size = 262144
query_alloc_block_size = 65536
range_alloc_block_size = 4096
transaction_alloc_block_size = 8192
transaction_prealloc_size = 4096
default-storage-engine = MyISAM
max_write_lock_count = 8
[mysql]
[mysql.server]
[mysqldump]
[mysqld_safe]
open_files_limit = 8192
[mysqldump]
quick
[myisamchk]
key_buffer_size = 128M
read_buffer_size = 16M
write_buffer_size = 16M
[mysqlhotcopy]
interactive-timeout
Niedawno zmieniłem konfigurację MySQL - od tego momentu problem zaczął się pojawiać. Konfig napisali mi ze wsparcia technicznego vBulletin. Coś w nim musi być nie tak.
