Po instalacji Debiana Squezee dostaję taki komunikat, po wydaniu polecenia:
dmesg
[ 827.458570] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458573] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458577] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458580] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458583] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458586] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458589] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458592] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 827.458595]
[ 827.458599] i915 0000:00:02.0: VGA-1: EDID invalid.
[ 892.013594] [drm:edid_is_valid] *ERROR* Raw EDID:
[ 892.013602] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013606] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013609] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013612] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013615] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013618] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013621] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013624] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 892.013627]
[ 892.013631] i915 0000:00:02.0: VGA-1: EDID invalid.
[ 927.577594] [drm:edid_is_valid] *ERROR* Raw EDID:
[ 927.577602] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577606] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577609] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577612] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577615] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577618] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577621] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577625] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 927.577627]
[ 927.577631] i915 0000:00:02.0: VGA-1: EDID invalid.
[ 927.730578] [drm] DAC-6: set mode 15
[ 945.922584] [drm:edid_is_valid] *ERROR* Raw EDID:
[ 945.922592] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922596] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922599] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922602] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922605] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922608] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922611] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922615] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 945.922617]
[ 945.922621] i915 0000:00:02.0: VGA-1: EDID invalid.
[ 946.075669] [drm] DAC-6: set mode 17
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02)
uname -a Linux debian 2.6.33-amd64 #1 SMP Sun Jan 10 22:40:40 UTC 2010 x86_64 GNU/Linux
OS Debian squeeze
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "built-ins"
EndSection
Section "Module"
Load "record"
Load "dbe"
Load "glx"
Load "extmod"
Load "dri"
Load "dri2"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "NoAccel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "ColorKey" # [i]
#Option "CacheLines" # [i]
#Option "Dac6Bit" # [<bool>]
#Option "DRI" # [<bool>]
#Option "NoDDC" # [<bool>]
#Option "ShowCache" # [<bool>]
#Option "XvMCSurfaces" # [i]
#Option "PageFlip" # [<bool>]
Identifier "Card0"
Driver "intel"
VendorName "Intel Corporation"
BoardName "82945G/GZ Integrated Graphics Controller"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
#SubSection "Display"
#Depth 1
#Modes "1280x1024" "1024x768" "800x600" "640x480"
#EndSubSection
#Depth 4
#EndSubSection
#Depth 8
#EndSubSection
#Depth 15
#EndSubSection
#Depth 16
#EndSubSection
#Depth 24
#EndSubSection
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
[Dodano: |1 Mar 2010|, 2010 20:19]
Jest to bardziej problem sprzętowy dlatego proszę o przeniesienie do odpowiedniego działu.
Gdyby ktoś miał podobne problemy z kartami intel rozwiązanie http://forum.dug.net.pl/viewtopic.php?id=16258
