Jądro 2.6.33 z Siduksa, przy próbie kompilacji vboxdrv:
make KBUILD_VERBOSE=1 -C /lib/modules/2.6.33-0.slh.3-sidux-amd64/build SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo; \
/bin/false)
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
make -f scripts/Makefile.build obj=/tmp/vbox.0
gcc-4.4 -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include -I/usr/src/linux-headers-2.6.33-0.slh.3-sidux-amd64/arch/x86/include -Iinclude -include include/generated/autoconf.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -fno-stack-protector -fomit-frame-pointer -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/lib/modules/2.6.33-0.slh.3-sidux-amd64/build/include -I/tmp/vbox.0/ -I/tmp/vbox.0/include -I/tmp/vbox.0/r0drv/linux -D__KERNEL__ -DMODULE -DRT_OS_LINUX -DIN_RING0 -DIN_RT_R0 -DIN_SUP_R0 -DVBOX -DRT_WITH_VBOX -DVBOX_WITH_HARDENING -DCONFIG_VBOXDRV_AS_MISC -DRT_ARCH_AMD64 -DVBOX_WITH_64_BITS_GUESTS -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(SUPDrv_linux)" -D"KBUILD_MODNAME=KBUILD_STR(vboxdrv)" -c -o /tmp/vbox.0/linux/.tmp_SUPDrv-linux.o /tmp/vbox.0/linux/SUPDrv-linux.c
In file included from /tmp/vbox.0/include/VBox/types.h:34,
from /tmp/vbox.0/linux/../SUPDrvInternal.h:39,
from /tmp/vbox.0/linux/SUPDrv-linux.c:37:
/tmp/vbox.0/include/iprt/types.h:100:30: error: linux/autoconf.h: Nie ma takiego pliku ani katalogu
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] Błąd 1
make[1]: *** [_module_/tmp/vbox.0] Błąd 2
make: *** [vboxdrv] Błąd 2
[Dodano: |26 Lut 2010|, 2010 22:48]
Problem rozwiązany. Można zamknąć.
