Witam!
Mam kilka pytań. Prosiłbym o pomoc, będę bardzo wdzięczny.
Jeżeli mam na serwerze dedykowanym grę np. Counter Strike i ona jest powiedzmy na porcie 27015. I ten serwer ma modyfikację, która potrzebuje mysql. Mam bazę danych, strony na niej działają itd. Ale mam pewien problem.
Gdy w na serwerze ustawiam bazę na ,,localhost'' to pokazuje mi w logach coś takiego (w logach serwera):
L 01/27/2010 - 00:19:01: Error on Table query: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
L 01/27/2010 - 00:19:01: Could not connect to SQL database.
A gdy daje na moje ip to pokazuje mi się coś takiego:
L 02/09/2010 - 20:54:24: Error on Table query: Can't connect to MySQL server on 'Moja IP.' (111)
L 02/09/2010 - 20:54:24: Could not connect to SQL database.
Co może być tego przyczyną? To, że gra ma inny port? A jeżeli tak to jak to ustawić?
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# [url]http://dev.mysql.com/doc/mysql/en/server-system-variables.html[/url]
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
# * Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 128K
thread_cache_size = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
#log = /var/log/mysql/mysql.log
# Error logging goes to syslog. This is a Debian improvement :)
# Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
# other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
# * BerkeleyDB
# Using BerkeleyDB is now discouraged as its support will cease in 5.1.12.
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# You might want to disable InnoDB to shrink the mysqld process by circa 100MB.
#skip-innodb
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
# * NDB Cluster
# See /usr/share/doc/mysql-server-*/README.Debian for more information.
# The following configuration is read by the NDB Data Nodes (ndbd processes)
# not from the NDB Management Nodes (ndb_mgmd processes).
# [MYSQL_CLUSTER]
# ndb-connectstring=127.0.0.1
# * IMPORTANT: Additional settings that can override those from this file!
# The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
