nie moge zainstalowac screena
chmielusek
Post autor: chmielusek »
94:~# apt-get update && apt-get install screen
Err [url]http://ftp.debian.org[/url] etch Release.gpg
  Could not resolve 'ftp.debian.org'
Get:1 [url]http://security.debian.org[/url] etch/updates Release.gpg [835B]
Hit [url]http://security.debian.org[/url] etch/updates Release
Ign [url]http://security.debian.org[/url] etch/updates/main Packages/DiffIndex
Ign [url]http://security.debian.org[/url] etch/updates/contrib Packages/DiffIndex
Ign [url]http://ftp.debian.org[/url] etch Release
Hit [url]http://security.debian.org[/url] etch/updates/main Packages
Hit [url]http://security.debian.org[/url] etch/updates/contrib Packages
Ign [url]http://ftp.debian.org[/url] etch/main Packages/DiffIndex
Ign [url]http://ftp.debian.org[/url] etch/contrib Packages/DiffIndex
Err [url]http://ftp.debian.org[/url] etch/main Packages
Err [url]http://ftp.debian.org[/url] etch/contrib Packages
Fetched 1B in 0s (2B/s)
Failed to fetch [url]http://ftp.debian.org/debian/dists/etch/Release.gpg[/url]  Could not resolve 'ftp.debian.org'
Failed to fetch [url]http://ftp.debian.org/debian/dists/etch/main/binary-i386/Packages.gz[/url]  Could not resolve 'ftp.debian.org'
Failed to fetch [url]http://ftp.debian.org/debian/dists/etch/contrib/binary-i386/Packages.gz[/url]  Could not resolve 'ftp.debian.org'
Reading package lists... Done
E: Some index files failed to download, they have been ignored, or old ones used instead.
94:~# aptitude update && aptitude install screen
Fetched 1B in 0s (3B/s)
Building dependency tree... Done
Reading extended state information
Initializing package states... Done
Reading task descriptions... Done
Building tag database... Done
The following packages have been kept back:
  gzip libc6 locales python2.4 python2.4-minimal
The following NEW packages will be installed:
  screen
0 packages upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
Need to get 587kB of archives. After unpacking 999kB will be used.
WARNING: untrusted versions of the following packages will be installed!
Untrusted packages could compromise your system's security.
You should only proceed with the installation if you are certain that
this is what you want to do.
  screen
Do you want to ignore this warning and proceed anyway?
To continue, enter "Yes"; to abort, enter "No":
czakll
Post autor: czakll »
Może po prostu trzeba wpisać "Yes" ...
mati75
Post autor: mati75 »
Dostałeś o informację na temat bezpieczeństwa, ponieważ wersja Etch od 14 lutego nie jest wspierana paczkami bezpieczeństwa.
