Dodawanie wpisów do xorg.conf - compiz
BHOY
Post autor: BHOY »
Cześć.
Dla umilenia pracy postanowiłem zainstalować Compiza. Instalacja przebiegła bez problemu, pojawia się on dopiero przy dodawaniu wpisów do xorg.conf.
Jak poprawnie dodać te wpisy z http://wiki.debian.org/Compiz tak by grafika się nie posypała?
Używam karty graficznej od Nvidi, sterowniki do niej są zainstalowane.
Mój oryginalny xorg.conf:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
	FontPath     "built-ins"
EndSection
Section "Module"
#	Load	"dri"
	Load  "extmod"
	Load  "dbe"
	Load	"glx"
	Load  "dri2"
	Load  "record"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
        ### [arg]: arg optional
        #Option     "SWcursor"           	# [<bool>]
        #Option     "HWcursor"           	# [<bool>]
        #Option     "NoAccel"            	# [<bool>]
        #Option     "ShadowFB"           	# [<bool>]
        #Option     "UseFBDev"           	# [<bool>]
        #Option     "Rotate"             	# [<str>]
        #Option     "VideoKey"           	# [i]
        #Option     "FlatPanel"          	# [<bool>]
        #Option     "FPDither"           	# [<bool>]
        #Option     "CrtcNumber"         	# [i]
        #Option     "FPScale"            	# [<bool>]
        #Option     "FPTweak"            	# [i]
        #Option     "DualHead"           	# [<bool>]
	Identifier  "Card0"
	Driver	"nvidia"
	Option      "Coolbits"	"1"
	Option      "AddARGBGLXVisuals"	"true"
	Option      "TripleBuffer"	"false"
	VendorName  "nVidia Corporation"
	BoardName   "G94 [GeForce 9600 GT]"
	BusID       "PCI:2:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Extensions"
#	Option      "Composite"	"disable"
#	Option      "RENDER"	"disable"
EndSection
RA1D3N
Post autor: RA1D3N »
Do xorg.conf dodaj takie coś
	Option "Composite" "Enable"
	Option "RENDER" "Enable"
EndSection
Section "DRI"
	Mode 0666
EndSection
i w Section "Module" dodaj
        Load    "i2c"
        Load    "bitmap"
   	Load 	"dbe"
        Load    "ddc"
        Load    "dri"
	Load	"drm"
        Load    "extmod"
        Load    "freetype"
	Load 	"type1"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
a do Section "Device" dodaj
        Option          "AddARGBGLXVisuals"     "True"
        Option          "RenderAccel"           "True"
	Option          "AllowGLXWithComposite" "True"
BHOY
Post autor: BHOY »
Dodałem te wpisy, nic się nie wysypało, grafika działa ale po wpisaniu polecenia:
compiz -replace
dalej znikają obramowania okien.
xorg.conf po edycji:
EndSection
Section "DRI"
    Mode 0666
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
#	Load	"dri"
	Load  "extmod"
	Load  "dbe"
	Load	"glx"
	Load  "dri2"
	Load  "record"
   	Load    "i2c"
        Load    "bitmap"
        Load     "dbe"
        Load    "ddc"
        Load    "dri"
   	Load    "drm"
        Load    "extmod"
        Load    "freetype"
    	Load     "type1"
        Load    "glx"
        Load    "int10"
        Load    "vbe"
EndSection
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
EndSection
Section "Monitor"
EndSection
Section "Device"
	Identifier  "Card0"
	Driver	"nvidia"
BusID       "PCI:2:0:0"
EndSection
Section "Screen"
	Device     "Card0"
	Monitor    "Monitor0"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
EndSection
RA1D3N
Sekcja "Screen" powinna wyglądać tak
    Device     "Card0"
    Monitor    "Monitor0"
   DefaultDepth    24
        Viewport   0 0
        Depth     24
    EndSubSection
i usuń z końca
EndSection
giaur
Post autor: giaur »
Nie trzeba nic dotykać do konfiguracji xorg-a. Warunki:
- najnowszy xorg
- najnowszy kernel
- najnowsze sterowniki do karty (i, na Zeusa NIE Z REPOZYTORIUM tylko od producenta)
BHOY
Post autor: BHOY »
No niestety coś robię nie tak i Compiz nie chce działać. Mimo wszystko dzięki za pomoc.
Andros
Post autor: Andros »
Może ktoś jednak zna jakieś rozwiązanie bo też mam ten sam problem
[ Dodano: |23 Lut 2010|, 2010 21:08 ]
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder75) Tue Dec 8 21:04:28 PST 2009
Identifier "Layout0"
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
moja konfiguracja X'ow, comipz niby dziala ale mam dziwny problem, obramowanie okien jest ale nie można otwartym oknem ruszać, minimalizować itp
