Nie potrafię zainstalować karty Wi-Fi USB D-Link DWA-140.
Mam Sida x86_64.
Proszę o pomoc.
Instalacja karty Wi-Fi USB D-Link DWA-140
jmarcin_1984
- Beginner
Powinno pomóc: http://wiki.debian.org/rt2870sta W sidzie masz już tą paczkę. Ewentualnie zerknij tutaj -> http://sudosys.be/?q=D-Link_DWA_140_ubuntu
Na ta chwilę zainstalowałem już
Przy włożonej karcie mam taki error podczas startu sytemu:
wireless-tools
wicd
firmware-ralink
[ 6.701128] Registered led device: rt2800usb-phy0::radio
[ 6.701146] Registered led device: rt2800usb-phy0::assoc
[ 6.701162] Registered led device: rt2800usb-phy0::quality
[ 6.701481] usbcore: registered new interface driver rt2800usb
[ 6.758267] rt3070sta: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.762835] rtusb init --->
[ 6.762867] usbcore: registered new interface driver rt2870
[ 6.778680] rt2870sta: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.783233] rtusb init --->
[ 6.783238] Error: Driver 'rt2870' is already registered, aborting...
[ 6.783466] usbcore: error -16 registering interface driver rt2870
