B
twozniak
Błąd podczas instalacji fluxboksa
Post autor: twozniak »
Podczas instalacji fluxboksa pojawia się następujący problem:
tom:/home/tom# cd /home/tom
tom:/home/tom# cd fluxbox-1.0.0
tom:/home/tom/fluxbox-1.0.0# ./configure && make
/home/tom/fluxbox-1.0.0/missing: Unknown `--run' option
Try `/home/tom/fluxbox-1.0.0/missing --help' for more information
configure: WARNING: `missing' script is too old or missing
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for ranlib... ranlib
checking for sed... sed
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking nl_types.h usability... yes
checking nl_types.h presence... yes
checking for nl_types.h... yes
checking process.h usability... no
checking process.h presence... no
checking for process.h... no
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/signal.h usability... yes
checking sys/signal.h presence... yes
checking for sys/signal.h... yes
checking for sys/stat.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for sys/types.h... (cached) yes
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking sstream usability... yes
checking sstream presence... yes
checking for sstream... yes
checking cassert usability... yes
checking cassert presence... yes
checking for cassert... yes
checking cctype usability... yes
checking cctype presence... yes
checking for cctype... yes
checking cerrno usability... yes
checking cerrno presence... yes
checking for cerrno... yes
checking cmath usability... yes
checking cmath presence... yes
checking for cmath... yes
checking cstdarg usability... yes
checking cstdarg presence... yes
checking for cstdarg... yes
checking cstdio usability... yes
checking cstdio presence... yes
checking for cstdio... yes
checking cstdlib usability... yes
checking cstdlib presence... yes
checking for cstdlib... yes
checking cstring usability... yes
checking cstring presence... yes
checking for cstring... yes
checking ctime usability... yes
checking ctime presence... yes
checking for ctime... yes
checking whether time.h and sys/time.h may both be included... yes
checking for basename... yes
checking for getpid... yes
checking for setlocale... yes
checking for sigaction... yes
checking for strcasestr... yes
checking for snprintf... yes
checking for vsnprintf... yes
checking for catopen... yes
checking for catgets... yes
checking for catclose... yes
checking for strftime... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv declaration... no
checking for t_open in -lnsl... no
checking for socket in -lsocket... no
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... no
checking for XOpenDisplay in -lX11... yes
checking for setlocale in -lxpg4... no
checking for gencat... gencat
checking whether to build support for the XShape extension... yes
checking for XShapeCombineShape in -lXext... yes
checking for X11/extensions/shape.h... yes
checking whether to include the Slit... yes
checking whether to include remember functionality... yes
checking whether to include Toolbar... yes
checking whether to have (POSIX) regular expression support... yes
checking whether to include the new WM Spec... yes
checking whether to include Pseudocolor ordered dithering code... no
checking whether to include verbose debugging code... no
checking whether to include NLS support... no
checking whether to use the new timed pixmap cache... yes
checking whether to have KDE slit support... yes
checking whether to have GNOME support... yes
checking whether to have Xft support... yes
checking for pkg-config... /usr/bin/pkg-config
Package xft was not found in the pkg-config search path.
Perhaps you should add the directory containing `xft.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xft' found
Could not link with Xft. Install Xft if you want support for it.
checking whether to have Xrender (transparent) support... yes
checking for XRenderCreatePicture in -lXrender... no
checking whether to have Xpm (pixmap themes) support... yes
checking for XpmReadFileToPixmap in -lXpm... no
checking whether to have Imlib2 (pixmap themes) support... yes
checking for imlib2-config... no
checking for imlib2 - version >= 1.0.0... no
*** The imlib2-config script installed by imlib2 could not be found
*** If imlib2 was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the IMLIB2_CONFIG environment variable to the
*** full path to imlib2-config.
no
checking whether to have Xmb (multibyte font, utf-8) support... yes
checking whether to have RANDR (The X Resize and Rotate Extension) support... yes
checking for XRRQueryExtension in -lXrandr... no
checking whether to build support for the Xinerama extension... yes
checking for XineramaQueryScreens in -lXinerama... no
checking return type of signal handlers... void
	fluxbox version 1.0.0 configured successfully.
Using '/usr/local' for installation.
Using '$(prefix)/share/fluxbox/menu' for location menu file.
Using '$(prefix)/share/fluxbox/styles/bloe' by default style.
Using '$(prefix)/share/fluxbox/keys' for location keys file.
Using '$(prefix)/share/fluxbox/init' for location init file.
Using '$(prefix)/share/fluxbox/nls' for nls files.
Using 'g++' for C++ compiler.
Building with '-g -O2  -DSHAPE  ' for C++ compiler flags.
Building with '  -lX11  -lXext ' for linker flags.
configure: creating ./config.status
config.status: creating Makefile
config.status: creating version.h
config.status: creating src/Makefile
config.status: creating src/FbTk/Makefile
config.status: creating util/Makefile
config.status: creating util/fbrun/Makefile
config.status: creating data/Makefile
config.status: creating data/styles/Makefile
config.status: creating data/styles/BlueFlux/Makefile
config.status: creating data/styles/BlueFlux/pixmaps/Makefile
config.status: creating data/styles/Emerge/Makefile
config.status: creating data/styles/Emerge/pixmaps/Makefile
config.status: creating data/styles/arch/Makefile
config.status: creating data/styles/arch/pixmaps/Makefile
config.status: creating data/styles/zimek_bisque/Makefile
config.status: creating data/styles/zimek_darkblue/Makefile
config.status: creating data/styles/zimek_green/Makefile
config.status: creating data/styles/ostrich/Makefile
config.status: creating data/styles/green_tea/Makefile
config.status: creating data/styles/bora_black/Makefile
config.status: creating data/styles/bora_blue/Makefile
config.status: creating data/styles/bora_green/Makefile
config.status: creating data/styles/carp/Makefile
config.status: creating data/styles/bloe/Makefile
config.status: creating data/styles/bloe/pixmaps/Makefile
config.status: creating doc/Makefile
config.status: creating doc/ru/Makefile
config.status: creating nls/Makefile
config.status: creating nls/C/Makefile
config.status: creating nls/be_BY/Makefile
config.status: creating nls/bg_BG/Makefile
config.status: creating nls/cs_CZ/Makefile
config.status: creating nls/da_DK/Makefile
config.status: creating nls/de_AT/Makefile
config.status: creating nls/de_CH/Makefile
config.status: creating nls/de_DE/Makefile
config.status: creating nls/el_GR/Makefile
config.status: creating nls/en_GB/Makefile
config.status: creating nls/en_US/Makefile
config.status: creating nls/es_AR/Makefile
config.status: creating nls/es_ES/Makefile
config.status: creating nls/et_EE/Makefile
config.status: creating nls/fi_FI/Makefile
config.status: creating nls/fr_CH/Makefile
config.status: creating nls/fr_FR/Makefile
config.status: creating nls/it_IT/Makefile
config.status: creating nls/ja_JP/Makefile
config.status: creating nls/ko_KR/Makefile
config.status: creating nls/lv_LV/Makefile
config.status: creating nls/nb_NO/Makefile
config.status: creating nls/nl_NL/Makefile
config.status: creating nls/no_NO/Makefile
config.status: creating nls/pl_PL/Makefile
config.status: creating nls/pt_BR/Makefile
config.status: creating nls/pt_PT/Makefile
config.status: creating nls/ru_RU/Makefile
config.status: creating nls/sk_SK/Makefile
config.status: creating nls/sl_SI/Makefile
config.status: creating nls/sv_SE/Makefile
config.status: creating nls/tr_TR/Makefile
config.status: creating nls/uk_UA/Makefile
config.status: creating nls/vi_VN/Makefile
config.status: creating nls/zh_CN/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Wejście do katalogu `/home/tom/fluxbox-1.0.0'
Making all in doc
make[2]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/doc'
Making all in ru
make[3]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/doc/ru'
make[3]: Nie ma nic do zrobienia w `all'.
make[3]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/doc/ru'
make[3]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/doc'
make[3]: Nie ma nic do zrobienia w `all-am'.
make[3]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/doc'
make[2]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/doc'
Making all in nls
make[2]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls'
make  all-recursive
make[3]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls'
Making all in C
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/C'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/C'
Making all in cs_CZ
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/cs_CZ'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/cs_CZ'
Making all in da_DK
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/da_DK'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/da_DK'
Making all in es_AR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/es_AR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/es_AR'
Making all in es_ES
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/es_ES'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/es_ES'
Making all in et_EE
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/et_EE'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/et_EE'
Making all in fr_FR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/fr_FR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/fr_FR'
Making all in pt_BR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/pt_BR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/pt_BR'
Making all in ru_RU
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/ru_RU'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/ru_RU'
Making all in sv_SE
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/sv_SE'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/sv_SE'
Making all in tr_TR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/tr_TR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/tr_TR'
Making all in it_IT
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/it_IT'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/it_IT'
Making all in pt_PT
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/pt_PT'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/pt_PT'
Making all in bg_BG
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/bg_BG'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/bg_BG'
Making all in ja_JP
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/ja_JP'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/ja_JP'
Making all in ko_KR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/ko_KR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/ko_KR'
Making all in lv_LV
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/lv_LV'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/lv_LV'
Making all in de_DE
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/de_DE'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/de_DE'
Making all in nl_NL
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/nl_NL'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/nl_NL'
Making all in no_NO
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/no_NO'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/no_NO'
Making all in sl_SI
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/sl_SI'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/sl_SI'
Making all in pl_PL
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/pl_PL'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/pl_PL'
Making all in vi_VN
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/vi_VN'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/vi_VN'
Making all in be_BY
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/be_BY'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/be_BY'
Making all in uk_UA
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/uk_UA'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/uk_UA'
Making all in el_GR
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/el_GR'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/el_GR'
Making all in nb_NO
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/nb_NO'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/nb_NO'
Making all in zh_CN
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/zh_CN'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/zh_CN'
Making all in fi_FI
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/fi_FI'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/fi_FI'
Making all in en_US
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/en_US'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/en_US'
Making all in en_GB
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/en_GB'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/en_GB'
Making all in de_CH
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/de_CH'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/de_CH'
Making all in de_AT
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/de_AT'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/de_AT'
Making all in fr_CH
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/fr_CH'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/fr_CH'
Making all in sk_SK
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls/sk_SK'
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls/sk_SK'
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/nls'
make[4]: Nie ma nic do zrobienia w `all-am'.
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls'
make[3]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls'
make[2]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/nls'
Making all in src
make[2]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/src'
make  all-recursive
make[3]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/src'
Making all in FbTk
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/src/FbTk'
make[4]: Nie ma nic do zrobienia w `all'.
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/src/FbTk'
make[4]: Wejście do katalogu `/home/tom/fluxbox-1.0.0/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I./FbTk   -g -O2  -DSHAPE   -MT fluxbox.o -MD -MP -MF .deps/fluxbox.Tpo -c -o fluxbox.o fluxbox.cc
mv -f .deps/fluxbox.Tpo .deps/fluxbox.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I./FbTk   -g -O2  -DSHAPE   -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cc
main.cc: In function ‘void showInfo(std: :o stream&)’:
main.cc:71: error: ‘strlen’ was not declared in this scope
make[4]: *** [main.o] Błąd 1
make[4]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/src'
make[3]: *** [all-recursive] Błąd 1
make[3]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/src'
make[2]: *** [all] Błąd 2
make[2]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0/src'
make[1]: *** [all-recursive] Błąd 1
make[1]: Opuszczenie katalogu `/home/tom/fluxbox-1.0.0'
make: *** [all] Błąd 2]
W sumie jestem w kropce, przez Google nic pomocnego nie znalazłem.
AdeBe
Post autor: AdeBe »
A od kiedy to fluxboxa na Debianie trzeba kompilować ze źródeł? :shock:
Zapoznaj się z odnośnikami z tego tematu: http://debian.linux.pl/viewtopic.php?t=6073
jesli chcesz juz bardzo fluxa kompilowac to musisz dodac wpis do repo source debiana
a potem
apt-get/aptitude update
nastepnie.
# apt-get build-dep fluxbox
i zaczynasz sobie kompilować ;)
choć czasem wystarczy binarna instalacja fluxa bez kompilaji :)
apt-get install fluxbox fluxconf
