Miałem problem z bardzo dużym obciążeniem serwera przy ,,hashowaniu torrentów''. Ktoś mi podpowiedział, że to problem z dostępem do dysku. Miał rację.
Hdparm pokazuje wyłączone DMA.
/dev/hda:
using_dma = 0 (off)
00:02.1 SMBus: Silicon Integrated Systems [SiS] SiS961/2 SMBus Controller
Flags: medium devsel
I/O ports at 0c00 [size=200]
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 [IDE] (prog-if 80 [Master])
Subsystem: ASRock Incorporation Unknown device 5513
Flags: bus master, medium devsel, latency 128
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=75]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=200]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=75]
I/O ports at ff00 [size=200]
cat /proc/modules
e100 33484 0 - Live 0xe0839000
mii 5344 1 e100, Live 0xe082a000
sis5513 7652 0 [permanent], Live 0xe081e000
generic 4484 0 [permanent], Live 0xe0821000Kod: Zaznacz cały
hdparm -i /dev/hda
/dev/hda:
Model=WDC WD5000AAKS-00A7B0, FwRev=01.03B01, SerialNo=WD-WMASY1632416
Config={ HardSect NotMFM HdSw>15uSec SpinMotCtl Fixed DTR>5Mbs FmtGapReq }
RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=50
BuffType=unknown, BuffSize=16384kB, MaxMultSect=16, MultSect=off
CurCHS=4047/16/255, CurSects=16511760, LBA=yes, LBAsects=268435455
IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120}
PIO modes: pio0 pio3 pio4
DMA modes: mdma0 mdma1 mdma2
UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5
AdvancedPM=no WriteCache=enabled
Drive conforms to: Unspecified: ATA/ATAPI-1 ATA/ATAPI-2 ATA/ATAPI-3 ATA/ATAPI-4 ATA/ATAPI-5 ATA/ATAPI-6 ATA/ATAPI-7
* signifies the current active mode
/dev/hda:
setting using_dma to 1 (on)
HDIO_SET_DMA failed: Operation not permitted
using_dma = 0 (off)
