Mam:
2.6.32-trunk-amd64
sudo cat /tmp/vmware-root/setup-1832.log
sty 24 11:48:11.753: app-140441929299696| Log for VMware Workstation pid=1832 version=7.0.0 build=build-203739 option=Release
sty 24 11:48:11.753: app-140441929299696| The process is 64-bit.
sty 24 11:48:11.753: app-140441929299696| Host codepage=UTF-8 encoding=UTF-8
sty 24 11:48:11.753: app-140441929299696| Logging to /tmp/vmware-root/setup-1832.log
sty 24 11:48:11.838: app-140441929299696| modconf query interface initialized
sty 24 11:48:11.848: app-140441929299696| modconf library initialized
sty 24 11:48:11.900: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:11.909: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:11.921: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:11.949: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:11.967: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:12.030: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.035: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.040: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.045: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.049: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.079: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.080: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.082: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.084: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.088: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.094: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:12.109: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:12.127: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.129: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.130: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.131: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.133: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.135: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:12.141: app-140441929299696| Your GCC version: 4.3
sty 24 11:48:12.177: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.180: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.182: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.185: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.187: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.406: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:12.406: app-140441929299696| Building module vmmon.
sty 24 11:48:12.406: app-140441929299696| Extracting the sources of the vmmon module.
sty 24 11:48:12.413: app-140441929299696| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmmon-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/2.6.32-trunk-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.3.4
sty 24 11:48:16.521: app-140441929299696| Installing module vmmon from /tmp/vmware-root/modules/vmmon.o.
sty 24 11:48:16.523: app-140441929299696| Registering file: /usr/lib/vmware-installer/1.1/vmware-installer --register-file vmware-player-app regular /lib/modules/2.6.32-trunk-amd64/misc/vmmon.o
sty 24 11:48:17.194: app-140441929299696| Registering file: /usr/lib/vmware-installer/1.1/vmware-installer --register-file vmware-player-app regular /lib/modules/2.6.32-trunk-amd64/misc/vmmon.ko
sty 24 11:48:17.993: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:17.994: app-140441929299696| Building module vmnet.
sty 24 11:48:17.994: app-140441929299696| Extracting the sources of the vmnet module.
sty 24 11:48:18.012: app-140441929299696| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmnet-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/2.6.32-trunk-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.3.4
sty 24 11:48:22.216: app-140441929299696| Failed to compile module vmnet!
sty 24 11:48:22.225: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:22.226: app-140441929299696| Building module vmblock.
sty 24 11:48:22.227: app-140441929299696| Extracting the sources of the vmblock module.
sty 24 11:48:22.236: app-140441929299696| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmblock-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/2.6.32-trunk-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.3.4
sty 24 11:48:25.672: app-140441929299696| Installing module vmblock from /tmp/vmware-root/modules/vmblock.o.
sty 24 11:48:25.674: app-140441929299696| Registering file: /usr/lib/vmware-installer/1.1/vmware-installer --register-file vmware-player-app regular /lib/modules/2.6.32-trunk-amd64/misc/vmblock.o
sty 24 11:48:26.153: app-140441929299696| Registering file: /usr/lib/vmware-installer/1.1/vmware-installer --register-file vmware-player-app regular /lib/modules/2.6.32-trunk-amd64/misc/vmblock.ko
sty 24 11:48:26.906: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:26.907: app-140441929299696| Building module vmci.
sty 24 11:48:26.907: app-140441929299696| Extracting the sources of the vmci module.
sty 24 11:48:26.913: app-140441929299696| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmci-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/2.6.32-trunk-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.3.4
sty 24 11:48:27.982: app-140441929299696| Failed to compile module vmci!
sty 24 11:48:27.991: app-140441929299696| Trying to find a suitable PBM set for kernel 2.6.32-trunk-amd64.
sty 24 11:48:27.992: app-140441929299696| Building module vmci.
sty 24 11:48:27.993: app-140441929299696| Extracting the sources of the vmci module.
sty 24 11:48:28.013: app-140441929299696| Building module with command: /usr/bin/make -C /tmp/vmware-root/modules/vmci-only auto-build SUPPORT_SMP=1 HEADER_DIR=/lib/modules/2.6.32-trunk-amd64/build/include CC=/usr/bin/gcc GREP=/usr/bin/make IS_GCC_3=no VMCCVER=4.3.4
sty 24 11:48:28.579: app-140441929299696| Failed to compile module vmci!
