2x 1.5TB WD Caviar Green
Jądro: 2.6.30-bpo.2-686
Wcześniej była użyta wersja stabilna jądra, problem również występował
hdparm -I /dev/sdaKod: Zaznacz cały
/dev/sda:
ATA device, with non-removable media
Model Number: WDC WD15EARS-00Z5B1
Serial Number: WD-WMAVU1352927
Firmware Revision: 80.00A80
Transport: Serial, SATA 1.0a, SATA II Extensions, SATA Rev 2.5
Standards:
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 2930277168
device size with M = 1024*1024: 1430799 MBytes
device size with M = 1000*1000: 1500301 MBytes (1500 GB)
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, with device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Recommended acoustic management value: 128, current value: 254
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
Automatic Acoustic Management feature set
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* 64-bit World wide name
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* SATA-I signaling speed (1.5Gb/s)
* SATA-II signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* unknown 76[12]
DMA Setup Auto-Activate optimization
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
unknown 206[12] (vendor specific)
unknown 206[13] (vendor specific)
Security:
Master password revision code = 65534
supported
not enabled
not locked
frozen
not expired: security count
supported: enhanced erase
336min for SECURITY ERASE UNIT. 336min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50014ee0573424c2
NAA : 5
IEEE OUI : 14ee
Unique ID : 0573424c2
Checksum: correct
Podczas kopiowania pliku 800MB transfer wynosi 26MB/s na starcie ale po 3 sekundach jest już tylko 12MB/s i taki utrzymuje się do końca.
ioctl:
Device: rrqm/s wrqm/s r/s w/s rsec/s wsec/s avgrq-sz avgqu-sz await svctm %util
sda 0,00 0,00 0,00 61,00 0,00 60512,00 992,00 26,35 752,33 16,39 100,00
sda 10,00 27,00 79,00 30,00 9400,00 728,00 92,92 5,32 85,61 8,88 96,80
sda 4,00 0,00 4,00 5,00 1056,00 40,00 121,78 4,60 622,22 111,11 100,00
sda 33,00 2802,00 76,00 55,00 12880,00 21736,00 264,24 16,73 117,74 6,90 90,40
sda 0,00 0,00 0,00 2,00 0,00 1136,00 568,00 3,86 476,00 500,00 100,00Kod: Zaznacz cały
/dev/md1 19G 2,4G 16G 13% /
tmpfs 497M 0 497M 0% /lib/init/rw
udev 10M 776K 9,3M 8% /dev
tmpfs 497M 0 497M 0% /dev/shm
/dev/md0 92M 24M 68M 27% /boot
/dev/md3 1,4T 229G 1,1T 18% /home
/dev/md2 19G 755M 18G 5% /varniestety rozwiązanie nie pomogło.
Posiadam dwa dyski Samsunga 1.5T, jeśli wszystko inne zawiedzie to postaram się przenieść partycje na inne dyski.
RT
[ Dodano: |23 Sty 2010|, 2010 14:40 ]
Follow up.
http://wklejto.pl/55171
To iostat, po zmianie dyskow na samsungi 1.5T.
Transfer nieprzerwany na poziomie 30-40MB w ramach tych samych dyskow.
Innymi slowy, tak jak stwierdzono to na forum ubuntu. Dyski WD z serri Green nie sa kompatybilne z systemem linux.
