Podłączyłem inny napęd (w ogóle coś z nim było nie tak) więc z powrotem włożyłem moją nagrywarkę i podczas startu mam takie błędy (wycinek z pliku /var/log/dmesg)
5.885325] EDAC MC: Ver: 2.1.0 Nov 16 2009
[ 5.899932] EDAC amd64_edac: Ver: 3.2.0 Nov 16 2009
[ 5.900347] EDAC amd64: ECC is enabled by BIOS, Proceeding with EDAC module initialization
[ 5.904360] EDAC MC: Rev F or later detected
[ 5.904443] EDAC MC0: Giving out device to 'amd64_edac' 'RevF': DEV 0000:00:18.2
[ 5.904467] EDAC PCI0: Giving out device to module 'amd64_edac' controller 'EDAC PCI controller': DEV '0000:00:18.2' (POLLED)
[ 5.911860] hdb: command error: status=0x51 { DriveReady SeekComplete Error }
[ 5.911984] hdb: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
[ 5.912106] hdb: possibly failed opcode: 0xa0
[ 5.924453] end_request: I/O error, dev hdb, sector 0
[ 5.924488] Buffer I/O error on device hdb, logical block 0
[ 5.924519] Buffer I/O error on device hdb, logical block 1
[ 5.924549] Buffer I/O error on device hdb, logical block 2
[ 5.924578] Buffer I/O error on device hdb, logical block 3
[ 5.924607] Buffer I/O error on device hdb, logical block 4
[ 5.924635] Buffer I/O error on device hdb, logical block 5
[ 5.924671] Buffer I/O error on device hdb, logical block 6
[ 5.924707] Buffer I/O error on device hdb, logical block 7
[ 5.924743] Buffer I/O error on device hdb, logical block 8
[ 5.924778] Buffer I/O error on device hdb, logical block 9
[ 5.925399] hdb: command error: status=0x51 { DriveReady SeekComplete Error }
[ 5.925525] hdb: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
[ 5.925658] hdb: possibly failed opcode: 0xa0
[ 5.928526] end_request: I/O error, dev hdb, sector 0
[ 6.291866] hdb: command error: status=0x51 { DriveReady SeekComplete Error }
[ 6.291998] hdb: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
[ 6.292136] hdb: possibly failed opcode: 0xa0
[ 6.296666] end_request: I/O error, dev hdb, sector 0
[ 6.297177] hdb: command error: status=0x51 { DriveReady SeekComplete Error }
[ 6.297304] hdb: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
[ 6.297436] hdb: possibly failed opcode: 0xa0
[ 6.300408] end_request: I/O error, dev hdb, sector 0
[ 6.300910] hdb: command error: status=0x51 { DriveReady SeekComplete Error }
[ 6.301037] hdb: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
[ 6.301169] hdb: possibly failed opcode: 0xa0
[ 6.304874] end_request: I/O error, dev hdb, sector 0
[ 6.741234] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
wodim --devices
wodim: No such file or directory.
Cannot open SCSI driver!
For possible targets try 'wodim --devices' or 'wodim -scanbus'.
For possible transport specifiers try 'wodim dev=help'.
For IDE/ATAPI devices configuration, see the file README.ATAPI.setup from
the wodim documentation.
