B
Bastian
Błąd przy nagrywaniu płyt CD/DVD - Squeeze
Post autor: Bastian »
Od czasu aktualizacji Debiana, nie mogę wypalać płyt. Próba na wszystkich prędkościach kończy się niepowodzeniem (k3B). Dostaje oto taki log:
System
K3b Version: 1.0.5
KDE Version: 3.5.10
QT Version:  3.3.8b
Kernel:      2.6.30-1-686-bigmem
Devices
LITE-ON DVDRW SOHW-1633S BS0C (/dev/sr1, ) [CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL] [DVD-ROM, DVD-R Sequential, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite]
HL-DT-ST DVD-ROM GDR8161B 0100 (/dev/sr0, ) [CD-ROM, DVD-ROM] [DVD-ROM, CD-ROM] [None]
Used versions
cdrecord: 1.1.10
cdrecord
scsidev: '/dev/sr1'
devname: '/dev/sr1'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.10
SCSI buffer size: 64512
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
TOC Type: 1 = CD-ROM
Driveropts: 'burnfree'
Device type    : Removable CD-ROM
Version        : 5
Response Format: 2
Capabilities   :
Vendor_info    : 'LITE-ON '
Identification : 'DVDRW SOHW-1633S'
Revision       : 'BS0C'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0009 (CD-R)
Profile: 0x002B (DVD+R/DL)
Profile: 0x001B (DVD+R)
Profile: 0x001A (DVD+RW)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0010 (DVD-ROM)
Profile: 0x000A (CD-RW)
Profile: 0x0009 (CD-R) (current)
Profile: 0x0008 (CD-ROM)
Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
Driver flags   : MMC-3 SWABAUDIO BURNFREE FORCESPEED
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 1895168 = 1850 KB
FIFO size      : 12582912 = 12288 KB
Speed set to 8467 KB/s
Track 01: data   693 MB
Total size:      796 MB (78:55.54) = 355166 sectors
Lout start:      796 MB (78:57/41) = 355166 sectors
Current Secsize: 2048
ATIP info from disk:
  Indicated writing power: 4
  Is not unrestricted
  Is not erasable
  Disk sub type: Medium Type C, low Beta category (C-) (6)
  ATIP start of lead in:  -11559 (97:27/66)
  ATIP start of lead out: 359846 (79:59/71)
Disk type:    Short strategy type (Phthalocyanine or similar)
Manuf. index: 21
Manufacturer: Ricoh Company Limited
Blocks total: 359846 Blocks current: 359846 Blocks remaining: 4680
Forcespeed is OFF.
Starting to write CD/DVD at speed  48.0 in real SAO mode for single session.
Last chance to quit, starting real write in    2 seconds.
   1 seconds.
   0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Errno: 5 (Input/output error), send opc scsi sendcmd: no error
CDB:  54 01 00 00 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 72 0B 00 00 00 00 00 0E 09 0C 00 00 00 00 00 00
Sense Key: 0x0 No Additional Sense, Segment 11
Sense Code: 0x00 Qual 0x00 (no additional sense information) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 214.379s timeout 200s
/usr/bin/wodim: OPC failed.
Writing  time:  215.251s
/usr/bin/wodim: fifo had 192 puts and 0 gets.
/usr/bin/wodim: fifo was 0 times empty and 0 times full, min fill was 100%.
BURN-Free was never needed.
cdrecord command:
/usr/bin/wodim -v gracetime=2 dev=/dev/sr1 speed=48 -dao driveropts=burnfree -eject -data -tsize=355166s -
Dodam, iż wcześniej sypał takim błędem w logach:
wodim: Operation not permitted.
Ale poradziłem sobie ustawiając suid na wodim.
Jednak z tym już nie mogę sobie poradzić. Użytkownik, z którego chcę nagrywać, jest oczywiście w grupie ,,cdrom''.
Mój system to wersja testowa:
Debian GNU/Linux squeeze/sid \n \l
Czy ktoś wie o co może chodzić?
Zalingrad
Post autor: Zalingrad »
Wyczyść zawartość pliku:
/etc/udev/rules.d/70-persistent-cd.rules
i zrestartuj komputer.
