dostaje oto takie coś
~/src/linux$ make xconfig
HOSTCXX scripts/kconfig/qconf.o
In file included from scripts/kconfig/qconf.cc:31:
scripts/kconfig/qconf.moc:11:2: error: #error "The header file 'qconf.h' doesn't include <QObject>."
scripts/kconfig/qconf.moc:19: error: expected constructor, destructor, or type conversion before ‘static’
scripts/kconfig/qconf.moc:56: error: ‘const QMetaObject ConfigList::staticMetaObject’ is not a static member of ‘class ConfigList’
scripts/kconfig/qconf.moc:56: error: variable ‘const QMetaObject ConfigList::staticMetaObject’ has initializer but incomplete type
scripts/kconfig/qconf.moc:58: error: ‘qt_meta_data_ConfigList’ was not declared in this scope
scripts/kconfig/qconf.moc:61: error: prototype for ‘const QMetaObject* ConfigList::metaObject() const’ does not match any in class ‘ConfigList’
scripts/kconfig/qconf.h:49: error: candidate is: virtual QMetaObject* ConfigList::metaObject() const
scripts/kconfig/qconf.moc:66: error: no ‘void* ConfigList::qt_metacast(const char*)’ member function declared in class ‘ConfigList’
scripts/kconfig/qconf.moc:74: error: ‘int ConfigList::qt_metacall’ is not a static member of ‘class ConfigList’
scripts/kconfig/qconf.moc:74: error: incomplete type ‘QMetaObject’ used in nested name specifier
scripts/kconfig/qconf.moc:74: error: expected primary-expression before ‘int’
scripts/kconfig/qconf.moc:74: error: expected primary-expression before ‘void’
scripts/kconfig/qconf.moc:74: error: initializer expression list treated as compound expression
scripts/kconfig/qconf.moc:75: error: expected ‘,’ or ‘;’ before ‘{’ token
make[1]: *** [scripts/kconfig/qconf.o] Błąd 1
make: *** [xconfig] Błąd 2
