Checking for Xgl: not present.
xset q doesn't reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:05.0 0300: 1002:5a62 (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Checking screen 1Comparing resolution (1280x800) to maximum 3D texture size (4096): Passed.
Checking for Software Rasterizer: present.
Software rasterizer detected, abortingaborting and using fallback: /usr/bin/metacity Z góry dziękuję za pomoc.
