Server Confirguration Error. Cannot log in. Please contact your system administrator. Kod: Zaznacz cały
NX> 203 NXSSH running with pid: 9364
NX> 285 Enabling check on switch command
NX> 285 Enabling skip of SSH config files
NX> 285 Setting the preferred NX options
NX> 200 Connected to address: 10.2.89.105 on port: 22
NX> 202 Authenticating user: nx
NX> 208 Using auth method: publickey
HELLO NXSERVER - Version 3.4.0-8 - LFE
NX> 105 Hello NXCLIENT - Version 3.4.0
NX> 134 Accepted protocol: 3.4.0
NX> 105 Set shell_mode: shell
NX> 105 Set auth_mode: password
NX> 105 Login
NX> 101 User: dom
NX> 102 Password: ***
NX> 103 Welcome to: dom-desktop user: dom
NX> 105 Listsession --user="dom" --status="suspended\054running" --geometry="1280x800x24+render" --type="unix-application"
NX> 127 Available sessions:
Display Type Session ID Options Depth Screen Status Session Name
NX> 148 Server capacity: not reached for user: dom
NX> 105 Start session with: --virtualdesktop="1" --application="startxfce4" --link="lan" --backingstore="1" --encryption="1" --cache="16M" --images="64M" --shmem="1" --shpix="1" --strict="0" --composite="1" --media="0" --session="KCK" --type="unix-application" --geometry="1280x776" --client="linux" --keyboard="pc102\057pl" --screeninfo="1280x776x24+render"
NX> 595 ERROR: A fatal error occurred in NX Server.
NX> 595 ERROR: The exception id is: A52AD266. To get detailed information about
NX> 595 ERROR: the error search for the string A52AD266 in the system log
NX> 595 ERROR: file (usually '/var/log/messages').
NX> 500 ERROR: Last operation failed.
NX> 280 Exiting on signal: 15
Na komputerze z którym chce się łączyć zainstalowałem to: to
A na moim: to
