drmRadeon - wy
pijanyadmin
drmRadeon - wyłączanie aplikacji - Ubuntu 9.10
Post autor: pijanyadmin »
drmRadeonCmdBuffer: -12. Kernel failed to parse or rejected command stream. See dmesg for more info.
Taki komunikat pokazuje się po uruchomieniu jakiejś gry, bądź aplikacji 3d. Karta graficzna radeon9550, akceleracja jest, kernel 2.6.32rc8 (na innych jest to samo).
dmesg |tail -n 50
[  978.936813]  [<c01c4d77>] __get_free_pages+0x17/0x30
[  978.936826]  [<c01ef630>] __kmalloc+0x100/0x1b0
[  978.936836]  [<c01c7e2d>] ? put_compound_page+0x1d/0x30
[  978.936843]  [<c01c874e>] ? put_page+0x2e/0x40
[  978.936861]  [<c032e49c>] ? copy_from_user+0x3c/0x70
[  978.937008]  [<d8bc370d>] radeon_cp_cmdbuf+0xb2d/0xd60 [radeon]
[  978.937023]  [<c0145f41>] ? update_curr+0x101/0x1b0
[  978.937038]  [<c0136d0e>] ? __enqueue_entity+0x8e/0xb0
[  978.937053]  [<c013efd7>] ? wakeup_gran+0x77/0x90
[  978.937060]  [<c013d9bd>] ? resched_task+0x1d/0x60
[  978.937066]  [<c0146551>] ? check_preempt_wakeup+0xe1/0x1b0
[  978.937073]  [<c032e50e>] ? copy_to_user+0x3e/0x60
[  978.937098]  [<d8bbb1a0>] ? radeon_cp_getparam+0xc0/0x200 [radeon]
[  978.937105]  [<c032e49c>] ? copy_from_user+0x3c/0x70
[  978.937178]  [<d8af05c5>] drm_ioctl+0x275/0x390 [drm]
[  978.937204]  [<d8bc2be0>] ? radeon_cp_cmdbuf+0x0/0xd60 [radeon]
[  978.937211]  [<c032a754>] ? rb_erase+0xb4/0x120
[  978.937219]  [<c0101e9f>] ? __switch_to+0x10f/0x180
[  978.937227]  [<c013fb42>] ? finish_task_switch+0x52/0xb0
[  978.937242]  [<c020591c>] vfs_ioctl+0x6c/0x80
[  978.937248]  [<c0205b04>] do_vfs_ioctl+0x64/0x1c0
[  978.937257]  [<c02db3c0>] ? security_file_ioctl+0x10/0x20
[  978.937263]  [<c0205cb3>] sys_ioctl+0x53/0x70
[  978.937270]  [<c0102ee3>] sysenter_do_call+0x12/0x28
[  978.937275] Mem-Info:
[  978.937279] DMA per-cpu:
[  978.937283] CPU    0: hi:    0, btch:   1 usd:   0
[  978.937286] Normal per-cpu:
[  978.937290] CPU    0: hi:  186, btch:  31 usd:   0
[  978.937301] active_anon:37979 inactive_anon:40035 isolated_anon:0
[  978.937303]  active_file:590 inactive_file:2842 isolated_file:2
[  978.937306]  unevictable:0 dirty:6 writeback:70 unstable:0
[  978.937308]  free:1264 slab_reclaimable:790 slab_unreclaimable:1323
[  978.937311]  mapped:962 shmem:17 pagetables:457 bounce:0
[  978.937325] DMA free:1576kB min:100kB low:124kB high:148kB active_anon:2852kB inactive_anon:3216kB active_file:48kB inactive_file:608kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15804kB mlocked:0kB dirty:0kB writeback:0kB mapped:108kB shmem:0kB slab_reclaimable:16kB slab_unreclaimable:48kB kernel
_stack:0kB pagetables:4kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[  978.937336] lowmem_reserve[]: 0 365 365 365
[  978.937352] Normal free:3480kB min:2392kB low:2988kB high:3588kB active_anon:149064kB inactive_anon:156924kB active_file:2312kB inactive_file:10760kB unevictable:0kB isolated(anon):0kB isolated(file):8kB present:373824kB mlocked:0kB dirty:24kB writeback:280kB mapped:3740kB shmem:68kB slab_reclaimable:3144kB slab_unreclaimable:5244kB kernel_stack:1248kB pagetables:1824kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[  978.937365] lowmem_reserve[]: 0 0 0 0
[  978.937371] DMA: 252*4kB 13*8kB 9*16kB 2*32kB 4*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 1576kB
[  978.937577] Normal: 650*4kB 30*8kB 10*16kB 9*32kB 1*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 3480kB
[  978.937595] 4310 total pagecache pages
[  978.937599] 865 pages in swap cache
[  978.937604] Swap cache stats: add 21314, delete 20449, find 702/933
[  978.937607] Free swap  = 1036604kB
[  978.937610] Total swap = 1108444kB
[  978.947296] 98272 pages RAM
[  978.947303] 0 pages HighMem
[  978.947306] 3367 pages reserved
[  978.947309] 11274 pages shared
[  978.947312] 84009 pages non-shared
Szczerze mówiąc nie wiem co może być przyczyną i jak się tego pozbyć. Miał ktoś podobny przypadek?
A jakie masz informacje w pliku:
/var/log/Xorg.0.log
pijanyadmin
Unhandled monitor type 0
(II) RADEON(0): EDID for output DVI-0
(II) RADEON(0): Output: S-video, Detected Monitor Type: 0
(II) RADEON(0): EDID for output S-video
(II) RADEON(0): EDID for output VGA-0
(II) RADEON(0): Manufacturer: MAX  Model: 6d7  Serial#: 401446
(II) RADEON(0): Year: 2005  Week: 37
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Analog Display Input,  Input Voltage Level: 0.700/0.300 V
(II) RADEON(0): Sync:  Separate
(II) RADEON(0): Max Image Size [cm]: horiz.: 34  vert.: 27
(II) RADEON(0): Gamma: 2.50
(II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) RADEON(0): First detailed timing is preferred mode
(II) RADEON(0): redX: 0.638 redY: 0.353   greenX: 0.279 greenY: 0.604
(II) RADEON(0): blueX: 0.142 blueY: 0.068   whiteX: 0.313 whiteY: 0.329
(II) RADEON(0): Supported established timings:
(II) RADEON(0): 720x400@70Hz
(II) RADEON(0): 640x480@60Hz
(II) RADEON(0): 640x480@67Hz
(II) RADEON(0): 640x480@72Hz
(II) RADEON(0): 640x480@75Hz
(II) RADEON(0): 800x600@56Hz
(II) RADEON(0): 800x600@60Hz
(II) RADEON(0): 800x600@72Hz
(II) RADEON(0): 800x600@75Hz
(II) RADEON(0): 832x624@75Hz
(II) RADEON(0): 1024x768@60Hz
(II) RADEON(0): 1024x768@70Hz
(II) RADEON(0): 1024x768@75Hz
(II) RADEON(0): 1280x1024@75Hz
(II) RADEON(0): Manufacturer's mask: 0
(II) RADEON(0): Supported standard timings:
(II) RADEON(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
(II) RADEON(0): #4: hsize: 1152  vsize 864  refresh: 75  vid: 20337
(II) RADEON(0): Supported detailed timing:
(II) RADEON(0): clock: 108.0 MHz   Image Size:  337 x 270 mm
(II) RADEON(0): h_active: 1280  h_sync: 1328  h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) RADEON(0): v_active: 1024  v_sync: 1025  v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) RADEON(0): Serial No: 537AB01401446
(II) RADEON(0): Monitor name: 101725
(II) RADEON(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 83 kHz, PixClock max 140 MHz
(II) RADEON(0): EDID (in hex):
(II) RADEON(0): 	00ffffffffffff003438d70626200600
(II) RADEON(0): 	250f010308221b96ea5a65a35a479a24
(II) RADEON(0): 	115054bfef000101010101018180714f
(II) RADEON(0): 	010101010101302a009851002a403070
(II) RADEON(0): 	1300510e1100001e000000ff00353337
(II) RADEON(0): 	41423031343031343436000000fc0031
(II) RADEON(0): 	30313732350a202020202020000000fd
(II) RADEON(0): 	00384b1f530e000a2020202020200020
(II) RADEON(0): EDID vendor "MAX", prod id 1751
(II) RADEON(0): Using hsync ranges from config file
(II) RADEON(0): Using vrefresh ranges from config file
(II) RADEON(0): Printing DDC gathered Modelines:
(II) RADEON(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEON(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz)
(II) RADEON(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEON(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz)
(II) RADEON(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz)
(II) RADEON(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEON(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEON(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEON(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEON(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz)
(II) RADEON(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Output: VGA-0, Detected Monitor Type: 1
(II) RADEON(0): EDID data from the display on output: VGA-0 ----------------------
(II) RADEON(0): Printing probed modes for output VGA-0
(II) RADEON(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEON(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEON(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz)
(II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEON(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEON(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz)
(II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEON(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz)
(II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEON(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz)
(II) RADEON(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz)
(II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEON(0): Output: DVI-0, Detected Monitor Type: 0
Ten fragment powtarza się kilkukrotnie.
Przedstaw cały plik, a nie tylko fragment powtarzający się, z którego niewiele wynika.
pijanyadmin
Ok, link do całości:
http://wklej.org/id/228057/
Przedstaw jeszcze:
/etc/X11/xorg.conf
uname -r
cat /etc/apt/sources.list
pijanyadmin
xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# package.
# Note that some configuration settings that could be done previously
# in this file, now are automatically configured by the server and settings
# here are ignored.
Section "Device"
	Identifier	"Configured Video Device"
EndSection
Section "Monitor"
	Identifier	"Configured Monitor"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Monitor		"Configured Monitor"
	Device		"Configured Video Device"
EndSection
Section "ServerFlags"
	Option "DontZap" "false"
EndSection
uname -r
2.6.32-020632-generic
source.list
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic main restricted
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic main restricted
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates main restricted
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates main restricted
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic universe
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic universe
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates universe
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates universe
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic multiverse
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic multiverse
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates multiverse
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-updates multiverse
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security main restricted
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security main restricted
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security universe
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security universe
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security multiverse
deb-src [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-security multiverse
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-backports main restricted universe multiverse
deb [url]http://archive.canonical.com/ubuntu/[/url] karmic partner
deb [url]http://ppa.launchpad.net/chromium-daily/ppa/ubuntu[/url] karmic main
deb-src [url]http://ppa.launchpad.net/chromium-daily/ppa/ubuntu[/url] karmic main
deb [url]http://ppa.launchpad.net/dockbar-main/ppa/ubuntu[/url] karmic main
deb-src [url]http://ppa.launchpad.net/dockbar-main/ppa/ubuntu[/url] karmic main
deb [url]http://archive.getdeb.net/ubuntu[/url] karmic-getdeb apps
deb [url]http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu[/url] karmic main # 1
deb-src [url]http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu[/url] karmic main #1
deb [url]http://archive.ubuntu.com/ubuntu/[/url] karmic-proposed restricted main multiverse universe
#1 - tego repo używam do ściągnięcia sterowników do karty graficznej, w standardowych nie mam akceleracji.
Dlaczego nie napisałeś od razu, że chodzi o Ubuntu? Tak naprawdę to usunąłbym przynajmniej połowę niepotrzebnych elementów z systemu i dopiero się zastanawiał dlaczego tak się coś dzieje.
Nie wiem, czy następne posunięcia nie rozłożą systemu. Ubuntu posiada sporo metapakietów i należy się w nich nieźle orientować aby zrobić to co chciałem zaproponować. Nie wie też czy to odniesie zamierzony skutek.
Jest taka informacja w logu:
pijanyadmin pisze:
(WW) RADEON(0): DRI init changed memory map, adjusting ...
(WW) RADEON(0):   MC_FB_LOCATION  was: 0xc7ffc000 is: 0xc7ffc000
(WW) RADEON(0):   MC_AGP_LOCATION was: 0xffffffc0 is: 0xd1ffd000
W Debianie spróbowałbym przejść na korzystanie systemu z informacji jakie dopiszę do pliku /etc/X11/xorg.conf. W Ubuntu tego nie próbowałem i nawet nie mam go pod ręką aby to sprawdzić.
pijanyadmin
Czyli nic nie można z tym zrobić w Ubuntu?
Nie wiem, czy nie można z tym coś zrobić? Nie próbowałem używać od dawna Ubuntu i nie wiem jak zachowa się hal kiedy go częściowo wyłączysz i inne powiązane z nim pakiety. W Ubuntu jest sporo metapakietów i automatyki z tym związanej.
Spróbuj wyłączyć odwołanie do hala i ręcznie ustawić większość w pliku xorg.conf. Nie wiem jak wygląda obecnie instalacja sterowników zamkniętych w Ubuntu. Nie wszystkie metody dostępne w Debianie mogą być zastosowane w Ubuntu. Inne skrypty.
