lenny# cpan Net::Appliance::Session
CPAN: Storable loaded ok (v2.18)
Going to read /root/.cpan/Metadata
Database was generated on Fri, 27 Nov 2009 07:27:07 GMT
CPAN: YAML loaded ok (v0.70)
Going to read /root/.cpan/build/
............................................................................DONE
Found 20 old builds, restored the state of 20
Running install for module 'Net::Appliance::Session'
Running make for O/OL/OLIVER/Net-Appliance-Session-1.36.tar.gz
Has already been unwrapped into directory /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j
Has already been made
Running make test
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'inc', 'blib/lib', 'blib/arch')" t/*.t
t/10-use..........NOK 1/29
# Failed test 'use Net::Appliance::Session;'
# at t/10-use.t line 10.
# Tried to use 'Net::Appliance::Session'.
# Error: Can't locate IO/Pty.pm in @INC (@INC contains: /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j/inc /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j/blib/lib /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j/blib/arch /etc/perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl . /etc/perl /usr/local/lib/perl/5.10.0 /usr/local/share/perl/5.10.0 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.10 /usr/share/perl/5.10 /usr/local/lib/site_perl .) at /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j/blib/lib/Net/Appliance/Session/Transport.pm line 10.
# BEGIN failed--compilation aborted at t/10-use.t line 10.
# Compilation failed in require at (eval 4) line 3.
# ...propagated at /usr/share/perl/5.10/base.pm line 92.
# BEGIN failed--compilation aborted at /root/.cpan/build/Net-Appliance-Session-1.36-lvyI6j/blib/lib/Net/Appliance/Session.pm line 12.
# Compilation failed in require at (eval 3) line 2.
# BEGIN failed--compilation aborted at (eval 3) line 2.
t/10-use..........NOK 2/29
# Failed test 'new without Host isa Net::Appliance::Session'
# at t/10-use.t line 18.
# new without Host isn't defined
t/10-use..........NOK 3/29
# Failed test 'new with Host isa Net::Appliance::Session'
# at t/10-use.t line 21.
# new with Host isn't defined
Can't call method "can" on an undefined value at t/10-use.t line 51.
# Looks like you planned 29 tests but only ran 3.
# Looks like you failed 3 tests of 3 run.
# Looks like your test died just after 3.
t/10-use..........dubious
Test returned status 255 (wstat 65280, 0xff00)
DIED. FAILED tests 1-29
Failed 29/29 tests, 0.00% okay
t/pod-coverage....ok
t/pod.............ok
Failed Test Stat Wstat Total Fail List of Failed
t/10-use.t 255 65280 29 55 1-29
Failed 1/3 test scripts. 29/49 subtests failed.
Files=3, Tests=49, 0 wallclock secs ( 0.46 cusr + 0.02 csys = 0.48 CPU)
Failed 1/3 test programs. 29/49 subtests failed.
make: *** [test_dynamic] Błąd 255
make test -- NOT OK
//hint// to see the cpan-testers results for installing this module, try:
reports OLIVER/Net-Appliance-Session-1.36.tar.gz
Running make install
make test had returned bad status, won't install without force
lenny# cpan IO::Pty
Running install for module 'IO::Pty'
Running make for R/RG/RGIERSIG/IO-Tty-1.08.tar.gz
Has already been unwrapped into directory /root/.cpan/build/IO-Tty-1.08-9XE62Q
'/usr/bin/perl Makefile.PL INSTALLDIRS=site' returned status 6400, won't make
Running make test
Make had some problems, won't test
Make had some problems, won't installKod: Zaznacz cały
lenny# cpan -f IO::Pty
Running make test
apt-cache search IO::Pty
