options snd-hda-intel model=hp-dv5Kod: Zaznacz cały
options snd-hda-intel model=autoKod: Zaznacz cały
trafim@Kubuntu:~$ aplay -l
**** Lista PLAYBACK urządzeń ****
karta 0: Intel [HDA Intel], urządzenie 0: STAC92xx Analog [STAC92xx Analog]
Urządzenia podrzędne: 1/1
Urządzenie podrzędne #0: subdevice #0
karta 0: Intel [HDA Intel], urządzenie 3: NVIDIA HDMI [NVIDIA HDMI]
trafim@Kubuntu:~$ lspci | grep -i audio
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)Kod: Zaznacz cały
trafim@Kubuntu:~$ lsmod | grep snd
snd_hda_codec_nvhdmi 6048 1
snd_hda_codec_idt 72976 1
snd_hda_intel 31880 2
snd_hda_codec 87584 3 snd_hda_codec_nvhdmi,snd_hda_codec_idt,snd_hda_intel
snd_hwdep 9352 1 snd_hda_codec
snd_pcm_oss 44704 0
snd_mixer_oss 18976 1 snd_pcm_oss
snd_pcm 93160 3 snd_hda_intel,snd_hda_codec,snd_pcm_oss
snd_seq_dummy 3460 0
snd_seq_oss 33440 0
snd_seq_midi 8192 0
snd_rawmidi 27360 1 snd_seq_midi
snd_seq_midi_event 8448 2 snd_seq_oss,snd_seq_midi
snd_seq 60608 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 26992 2 snd_pcm,snd_seq
snd_seq_device 8308 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 77096 16 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,
snd_seq,snd_timer,snd_seq_device
soundcore 9088 1 snd
snd_page_alloc 10928 2 snd_hda_intel,snd_pcm
trafim@Kubuntu:~$ cat /proc/asound/version
Advanced Linux Sound Architecture Driver Version 1.0.20.
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
# Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
options snd-usb-caiaq index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
# Power down HDA controllers after 10 idle seconds
options snd-hda-intel power_save=10 power_save_controller=N
options snd-hda-intel model=hp-dv5[b](to dodałem)[/b]
sudo alsa force-reloadKod: Zaznacz cały
aristarh@Kubuntu:~$ sudo alsa force-reload
[sudo] password for aristarh:
Terminating processes: 1382 1401.
Unloading ALSA sound driver modules: snd-hda-codec-nvhdmi snd-hda-codec-idt snd-hda-intel snd-hda-codec snd-hwdep snd-pcm-oss snd-mixer-oss snd-pcm snd-seq-dummy snd-seq-oss snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-timer snd-seq-device snd-page-alloc (failed: modules still loaded: snd-hda-codec-nvhdmi snd-hda-codec-idt snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc).
Loading ALSA sound driver modules: snd-hda-codec-nvhdmi snd-hda-codec-idt snd-hda-intel snd-hda-codec snd-hwdep snd-pcm-oss snd-mixer-oss snd-pcm snd-seq-dummy snd-seq-oss snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-timer snd-seq-device snd-page-alloc.
speaker-test
