Usunąłem mplayera i przy ponownej instalacji przez terminal wyskakuje mi:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
mplayer: Depends: libfaac0 (>= 1.26) but it is not installable
Depends: liblame0 (>= 3.97) but it is not installable
Depends: libopenal0a but it is not installable
Depends: libx264-57 (>= 1:0.svn20071224) but it is not installable
Depends: libxvidcore4 (>= 1:1.0.0-0.0) but it is not installable
Depends: mplayer-skins but it is not installable
E: Broken packages
