Mam kartę dlink dwa 547. Nie mogę jednak zmusić jej do pracy w trybie Access-Point pasmo 5GHz (N). Zainstalowałem sterownik ath9k w jądrze (2.6.32-rc5) jako moduł. Zastąpiłem go przez stabilny compat-wireless-2.6.32-rc6 ze strony http://linuxwireless.org/en/users/Download/stable/
Do tego skompilowałem własnoręcznie:
- wireless-regdb-2009.11.10
- crda-1.1.0
- iw-0.9.17
lspci -vKod: Zaznacz cały
01:08.0 Network controller: Atheros Communications Inc. AR5416 802.11abgn Wireless PCI Adapter (rev 01)
Subsystem: D-Link System Inc Device 3a6b
Flags: bus master, 66MHz, medium devsel, latency 168, IRQ 17
Memory at fead0000 (32-bit, non-prefetchable) [size=64K]
Capabilities: [40] #80 [0000]
Kernel driver in use: ath9k
Kernel modules: ath9k
iw listKod: Zaznacz cały
Wiphy phy0
Band 1:
HT capabilities: 0x104e
* 20/40 MHz operation
* SM PS disabled
* 40 MHz short GI
* max A-MSDU len 3839
* DSSS/CCK 40 MHz
HT A-MPDU factor: 0x0003 (65535 bytes)
HT A-MPDU density: 0x0006 (8 usec)
HT MCS set: ff ff 00 00 00 00 00 00 00 00 00 00 01 00 00 00
HT TX/RX MCS rate indexes supported:
MCS index 0
MCS index 1
MCS index 2
MCS index 3
MCS index 4
MCS index 5
MCS index 6
MCS index 7
MCS index 8
MCS index 9
MCS index 10
MCS index 11
MCS index 12
MCS index 13
MCS index 14
MCS index 15
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm)
* 2472 MHz [13] (20.0 dBm)
* 2484 MHz [14] (disabled)
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
max # scan SSIDs: 4
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
Driver does not support configured HT capability/etc/hostapd/hostapd.conf:
driver=nl80211
interface=ath0
channel=9
ieee80211n=1
ht_capab=[HT40-][SHORT-GI-40][DSSS_CCK-40]
#hw_mode=g
#ignore_broadcast_ssid=1
country_code=PL
dump_file=/tmp/hostapd.dump
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
rsn_preauth=1
#essid naszego AP'ka
ssid=xxxx
#filtracja adresow mac
# 0 - dopuszczaj wszystkich z wyjatkiem tych wymienionych na deny list
# 1 - odmawiaj dostepu wszystkim z wyjatkiem tych wymienionych w accept list
# 2 - uzyj zew. serwera Radius
macaddr_acl=1
#Plik z lista dopuszczonych MAC adresow
accept_mac_file=/etc/hostapd/hostapd.accept
# plik z lista niedopusczonych/blokowanych MAC adresow
# deny_mac_file=/etc/hostapd.deny
#metoda autentykacji
auth_algs=1
####### KONFIGURACJA WPA
# wlaczamy WPA-PSK
wpa=2
# tu wpisuje nasze haslo dostepu
wpa_psk=costamcostam
#algorytm zarzadzania kluczami
wpa_key_mgmt=WPA-PSK
#algorytm kodowania
wpa_pairwise=CCMP
rsn_pairwise=CCMPmoże nadawać na tej częstotliwości? Czy istnieje jakaś łatka, która umożliwiłaby karcie działanie w standardzie N? Dodam, że już odchodzę od zmysłów bo kartę konfigurowałem na 1200 możliwych sposobów, a dalej nie mogę zmusić jej do
funkcjonowania w trybie N. Tryb G działa bez problemu. Dodam, że z hostapd łączę
się przez laptopa z kartą intel 4965agn.
