Zainstalowane kodeki:
ii libtheora0 1.0-2.1 The Theora Video Compression Codec
ii libvorbis0a 1.2.3-3 The Vorbis General Audio Compression Codec
ii libvorbisenc2 1.2.3-3 The Vorbis General Audio Compression Codec
ii libvorbisfile3 1.2.3-3 The Vorbis General Audio Compression Codec
ii vorbis-tools 1.2.0-6 several Ogg Vorbis toolsKod: Zaznacz cały
[12:56:59][~$] mplayer big_buck_bunny_480p_stereo.ogg
MPlayer SVN-r29789 (C) 2000-2009 MPlayer Team
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing big_buck_bunny_480p_stereo.ogg.
[Ogg] stream 0: video (Theora v3.2.1), -vid 0
[Ogg] stream 1: audio (Vorbis), -aid 0
Ogg file format detected.
VIDEO: [theo] 854x480 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s)
[gl] using extended formats. Use -vo gl:nomanyfmts if playback fails.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
[theora @ 0x89ac520]Missing extradata!
Could not open codec.
VDecoder init failed :(
Opening video decoder: [theora] Theora/VP3
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
Movie-Aspect is undefined - no prescaling applied.
[swscaler @ 0x8a8abc0]using unscaled yuv420p -> rgb32 special converter
VO: [gl] 854x480 => 854x480 BGRA
Selected video codec: [theora] vfm: theora (Theora (free, reworked VP3))
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [ffvorbis] afm: ffmpeg (FFmpeg Vorbis)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
A: 144.2 V: 144.2 A-V: 0.002 ct: -0.011 149/149 26% 22% 2.2% 0 0
Exiting... (Quit)Kod: Zaznacz cały
