Mam problem z serwerem, a dokładnie z zapytaniami dns. Poprawnie mam wpisy zrobione w resolv.conf, dnsy sieci dialog, ale w momencie próby pingowania onet.pl wyświetla
ping: unknown host onet.plKod: Zaznacz cały
route -nKod: Zaznacz cały
cat /etc/resolv.conf
ifconfig
route -n
ping -c 4 213.180.146.27
ping -c 4 ip.twojej.bramy
ping -c 4 ip.twojego.dns
iptables -L
nameserver 194.204.159.1
nameserver 194.204.152.34Kod: Zaznacz cały
eth0 Link encap:Ethernet HWaddr 00:11:25:6B:2B:3C
inet addr:192.168.200.3 Bcast:192.168.200.255 Mask:255.255.255.0
inet6 addr: fe80::211:25ff:fe6b:2b3c/64 Scope:Link
RX packets:1769 errors:0 dropped:0 overruns:0 frame:0
TX packets:780 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:156776 (153.1 KiB) TX bytes:52507 (51.2 KiB)
eth1 Link encap:Ethernet HWaddr 00:5:D A:8C:1C:98
inet addr:192.168.9.1 Bcast:192.168.9.255 Mask:255.255.255.0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:9 Base address:0x4000
lo Link encap:Local Loopback
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:560 (560.0 b) TX bytes:560 (560.0 b)
debian:~# ping -c 4 213.180.146.27
PING 213.180.146.27 (213.180.146.27) 56(84) bytes of data.
64 bytes from 213.180.146.27: icmp_seq=1 ttl=56 time=30.9 ms
64 bytes from 213.180.146.27: icmp_seq=2 ttl=56 time=44.0 ms
64 bytes from 213.180.146.27: icmp_seq=3 ttl=56 time=29.7 msKod: Zaznacz cały
debian:~# ping -c 4 192.168.200.1
PING 192.168.200.1 (192.168.200.1) 56(84) bytes of data.
64 bytes from 192.168.200.1: icmp_seq=1 ttl=254 time=2.28 ms
64 bytes from 192.168.200.1: icmp_seq=2 ttl=254 time=1.72 ms
64 bytes from 192.168.200.1: icmp_seq=3 ttl=254 time=1.71 ms
64 bytes from 192.168.200.1: icmp_seq=4 ttl=254 time=1.76 msKod: Zaznacz cały
debian:~# ping -c 4 217.30.129.149
PING 217.30.129.149 (217.30.129.149) 56(84) bytes of data.
64 bytes from 217.30.129.149: icmp_seq=1 ttl=61 time=17.9 ms
64 bytes from 217.30.129.149: icmp_seq=2 ttl=61 time=14.6 ms
64 bytes from 217.30.129.149: icmp_seq=3 ttl=61 time=15.3 ms
64 bytes from 217.30.129.149: icmp_seq=4 ttl=61 time=14.8 msKod: Zaznacz cały
debian:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
target prot opt source destinationTo co podałeś to TP.SAdan-j2 pisze: dnsy sieci dialog
podaje wyniki resolv.conf
nameserver 194.204.159.1 nameserver 194.204.152.34
* pierwszy (primary) serwer DNS: adres IP: 217.30.129.149]
Zobacz OpenDNS:Ja mam takie i nie mam problemów.Kod: Zaznacz cały
nameserver 208.67.222.222 nameserver 208.67.220.220
eth0 Link encap:Ethernet HWaddr 00:e0:4c:04:39:bf
inet addr:192.168.10.101 Bcast:192.168.10.255 Mask:255.255.255.0
inet6 addr: fe80::2e0:4cff:fe04:39bf/64 Scope:Link
RX packets:3390 errors:0 dropped:0 overruns:0 frame:0
TX packets:2508 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1029766 (1005.6 KiB) TX bytes:197248 (192.6 KiB)
Interrupt:5 Base address:0xd400
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:824 (824.0 B) TX bytes:824 (824.0 B)
nameserver 198.41.0.4
ping -c 4 208.67.222.222
host debian.linux.pl
host debian.linux.pl 208.67.222.222
