__USE_SQLITEDB__ Przy okazji, nie ma możliwości użycia
./configureKod: Zaznacz cały
./autogen.shKod: Zaznacz cały
__USE_SQLITEDB__ Kod: Zaznacz cały
make CPPFLAGS=USE_SQLITEDB=0Kod: Zaznacz cały
/usr/bin/ld: cannot find -llua5.1-sql-sqlite
./configure --helpTylko wyłączenie sqlite raczej nie będzie dobrym pomysłem.Optional Features:
--disable-option-checking ignore unrecognized --enable/--with options
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--disable-dependency-tracking speeds up one-time build
--enable-dependency-tracking do not reject slow dependency extractors
--enable-debug enable debuging
--enable-server-diag enable server diagnostics
--enable-otconfig use otserv.lua configuration
--enable-skulls enable skull system
--enable-otallocator enable otserv custom allocator
--enable-mysql enable MySQL support
--enable-pgsql enable PostgreSQL support
--enable-odbc enable ODBC support
--enable-sqlite enable SQLite support (default))
--enable-profiler enable profiler support
--disable-xmltest Do not try to compile and run a test LIBXML program
U ciebie problem jest to, że nadal nie zinstalowałeś luasql-sqlite3.g++ -I/usr/include/libxml2 -D__USE_SQLITE__ -DSYSCONFDIR=\"/usr/local/etc\" -DPKGDATADIR=\"/usr/local/share/otserv\" -D_THREAD_SAFE -D_REENTRANT -Wall -g -O2 -o otserv databasesqlite.o account.o map.o rsa.o actions.o md5.o scheduler.o admin.o monster.o scriptmanager.o allocator.o depot.o monsters.o server.o ban.o exception.o movement.o sha1.o baseevents.o fileloader.o networkmessage.o spawn.o beds.o game.o npc.o spells.o chat.o house.o otserv.o status.o combat.o housetile.o outfit.o talkaction.o ioaccount.o outputmessage.o tasks.o condition.o iomapotbm.o party.o teleport.o configmanager.o iomapserialize.o player.o thing.o connection.o position.o tile.o container.o ioplayer.o protocol.o tools.o creature.o item.o protocolgame.o trashholder.o creatureevent.o items.o protocollogin.o vocation.o cylinder.o logger.o protocolold.o waitlist.o database.o luascript.o quests.o weapons.o mailbox.o raids.o -lsqlite3 -llua -lboost_date_time-mt -lboost_system-mt -lboost_regex-mt -lboost_thread-mt -lgmp -lxml2 -lz -lm
cp ./config.lua.dist config.lua
make[1]: Opuszczenie katalogu `/home/grapeli23/tmp/tibia/trunk'
