Postanowiłem na laptopie zainstalować Debiana - wcześniej używalem Gentoo i laptop kręcił mi jakieś 2000 klatek przy ,,glxgears''. Jednak po zainstalowaniu Debiana i kombinowaniu z fglrx mam tylko 300.
lspci -v
01:05.0 VGA compatible controller: ATI Technologies Inc RC410 [Radeon Xpress 200M] (prog-if 00 [VGA controller])
Subsystem: Fujitsu Technology Solutions Device 10fb
Flags: bus master, 66MHz, medium devsel, latency 66, IRQ 17
Memory at d0000000 (32-bit, prefetchable) [size=256M]
I/O ports at 9000 [size=200]
Memory at c0100000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at c0120000 [disabled] [size=128K]
Capabilities: [50] Power Management version 2
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
#~~~~~~Sid~~~~~~#
deb [url]ftp://ftp.pl.debian.org/debian/[/url] sid main non-free contrib
deb-src [url]ftp://ftp.pl.debian.org/debian/[/url] sid main non-free contrib
#~~~~~~Opera~~~~~~#
deb [url]http://deb.opera.com/opera/[/url] unstable non-free
#~~~~~~Debian-multimedia~~~~~~#
deb [url]http://www.debian-multimedia.org[/url] sid main
deb-src [url]http://www.debian-multimedia.org[/url] s
SoBaN-notebook:/home/soban# ./ati-driver-installer-9-3-x86.x86_64.run --buildpkg Debian/sid
Created directory fglrx-install.cgc86o
Verifying archive integrity... All good.
Uncompressing ATI Proprietary Linux Driver-8.593...................
ATI Technologies Linux Driver Installer/Packager
Generating package: Debian/sid
Package build failed!
Package build utility output:
dpkg-buildpackage: set CFLAGS to default value: -g -O2
dpkg-buildpackage: set CPPFLAGS to default value:
dpkg-buildpackage: set LDFLAGS to default value:
dpkg-buildpackage: set FFLAGS to default value: -g -O2
dpkg-buildpackage: set CXXFLAGS to default value: -g -O2
dpkg-buildpackage: source package fglrx-installer
dpkg-buildpackage: source version 8.593-1
dpkg-buildpackage: source changed by ATI Technologies Inc. <http://ati.amd.com/support/driver.html>
debian/rules build
dh_installdocs -pfglrx-driver usr/share/doc/fglrx/*
#dh_installchangelogs
dh_link
dh_strip
dh_compress
dh_installdeb
dh_makeshlibs
dh_shlibdeps
dpkg-shlibdeps: warning: symbol XextCreateExtension used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: warning: symbol XextAddDisplay used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: warning: symbol _XReply used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: warning: symbol _XFlush used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: warning: symbol XextRemoveDisplay used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: warning: symbol XextFindDisplay used by debian/fglrx-driver/usr/lib/libfglrx_gamma.so.1.0 found in none of the libraries.
dpkg-shlibdeps: error: couldn't find library libstdc++.so.5 needed by debian/fglrx-driver/usr/lib/libAMDXvBA.so.1.0 (ELF format: 'elf32-i386'; RPATH: '').
Note: libraries are not searched in other binary packages that do not have any shlibs or symbols file.
To help dpkg-shlibdeps find private libraries, you might need to set LD_LIBRARY_PATH.
dh_shlibdeps: dpkg-shlibdeps returned exit code 2
make: *** [binary] Error 1
dpkg-buildpackage: error: debian/rules binary gave error exit status 2
Removing temporary directory: fglrx-install.cgc86o
SoBaN-notebook:/home/soban# uname -a
Linux SoBaN-notebook 2.6.30-2-686 #1 SMP Sat Sep 26 01:16:22 UTC 2009 i686 GNU/LinuxKod: Zaznacz cały
SoBaN-notebook:/home/soban# modprobe fglrx
FATAL: Error inserting fglrx (/lib/modules/2.6.30-2-686/misc/fglrx.ko): Cannot allocate memory
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
Option "AIGLX" "true"
EndSection
Section "Files"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/TTF/"
FontPath "/usr/share/fonts/OTF"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/share/fonts/100dpi/"
FontPath "/usr/share/fonts/75dpi/"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "record"
Load "xtrap"
Load "glx"
Load "dri"
Load "extmod"
Load "GLcore"
Load "freetype"
Load "type1"
SubSection "extmod"
Option "omit xfree86-dga"
EndSubSection
EndSection
Section "InputDevice" Identifier "Keyboard0"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "BenQ E2200HD"
HorizSync 70.0 - 80.0
VertRefresh 60.0 - 60.0
Option "dpms"
EndSection
Section "Monitor"
Identifier "Monitor1"
Option "dpms"EndSection
Section "Device"
Identifier "Card0"
Option "XAANoOffscreenPixmaps" "true"
Driver "radeon"
# Driver "fglrx" gdy ta linijka jest odmaskowana zamiast tej u gory to x-y nie wstaja.
VendorName "ATI Technologies Inc"
BoardName "RC410 [Radeon Xpress 200M]"
BusID "PCI:1:5:0"
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "true"
SubSection "Display"
Viewport 0 0
Depth 24
Modes "1280x800"
Modes "1280x1080"
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card0"
Monitor "Monitor1"
DefaultDepth 24
Viewport 0 0
Depth 24
Modes "1280x800"
Modes "1024x768"
Modes "1280x1080"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "Damage" "Enable"
EndSection
Section "ServerFlags"
Option "AutoAddDevices" "False"
EndSection
