udev: missing sysfs features; please update the kernel or disable the kernel's CONFIG_SYSFS_DEPRECATED option; udev may fail to work correctlyKod: Zaznacz cały
dpkg: błąd przetwarzania linux-image-2.6.26-2-686 (--configure):
podproces installed post-installation script zwrócił kod błędu 2
W czasie instalacji wystąpiły problemy. Próba naprawy:
Konfigurowanie linux-image-2.6.26-2-686 (2.6.26-19) ...
Running depmod.
Running mkinitramfs-kpkg.
Deprecation WARNING: use update-initramfs(8)
initrd.img(/boot/initrd.img-2.6.26-2-686
) points to /boot/initrd.img-2.6.26-2-686
(/boot/initrd.img-2.6.26-2-686) -- doing nothing at /var/lib/dpkg/info/linux-image-2.6.26-2-686.postinst line 569.
vmlinuz(/boot/vmlinuz-2.6.26-2-686
) points to /boot/vmlinuz-2.6.26-2-686
(/boot/vmlinuz-2.6.26-2-686) -- doing nothing at /var/lib/dpkg/info/linux-image-2.6.26-2-686.postinst line 569.
Running postinst hook script update-grub.
Searching for GRUB installation directory ... found: /boot/grub
Searching for default file ... found: /boot/grub/default
Testing for an existing GRUB menu.lst file ... found: /boot/grub/menu.lst
Searching for splash image ... none found, skipping ...
expr: argument nieliczbowy
User postinst hook script [update-grub] exited with value 2
linux-image-2.6.26-2-686Kod: Zaznacz cały
Running depmod.
