Postanowiłem zainstalować Siduxa na laptopie i niby wszystko jest w porządku ale mam wrażenie, że sterowniki otwarte nie działają wydajnie. Wynik glxgears daje mi coś takiego
147 frames in 5.0 seconds = 29.362 FPS
152 frames in 5.0 seconds = 30.335 FPS
152 frames in 5.0 seconds = 30.366 FPS
145 frames in 5.0 seconds = 28.911 FPS
148 frames in 5.0 seconds = 29.521 FPS
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
OpenGL vendor string: Mesa Project
OpenGL renderer string: Software Rasterizer
OpenGL version string: 2.1 Mesa 7.6
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_ARB_copy_buffer, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
GL_ARB_half_float_pixel, GL_ARB_imaging, GL_ARB_map_buffer_range,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_shading_language_120, GL_ARB_shadow, GL_ARB_shadow_ambient,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_convolution, GL_EXT_copy_texture,
GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_blit, GL_EXT_fog_coord,
GL_EXT_gpu_program_parameters, GL_EXT_histogram, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_paletted_texture, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_provoking_vertex,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_3DFX_texture_compression_FXT1, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ATI_blend_equation_separate,
GL_ATI_envmap_bumpmap, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATI_fragment_shader,
GL_ATI_separate_stencil, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_resize_buffers,
GL_MESA_texture_array, GL_MESA_ycbcr_texture, GL_MESA_window_pos,
GL_NV_blend_square, GL_NV_fragment_program, GL_NV_light_max_exponent,
GL_NV_point_sprite, GL_NV_texture_env_combine4, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_OES_read_format, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGI_texture_color_table, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
64 GLX Visuals
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0xea 24 tc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0xeb 24 tc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0xec 24 tc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0xed 24 tc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0xee 24 tc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0xef 24 tc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0xf0 24 tc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0xf1 24 tc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0xf2 24 tc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0xf3 24 tc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0xf4 24 tc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0xf5 24 tc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0xf6 24 tc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0xf7 24 tc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0xf8 24 tc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0xf9 24 tc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0xfa 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0xfb 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0xfc 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0xfd 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0xfe 24 tc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0xff 24 tc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x100 24 tc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x101 24 tc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x102 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x103 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x104 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x105 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x106 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x107 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x108 24 dc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x109 24 dc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0x10a 24 dc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x10b 24 dc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0x10c 24 dc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0x10d 24 dc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0x10e 24 dc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0x10f 24 dc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0x110 24 dc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0x111 24 dc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0x112 24 dc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0x113 24 dc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0x114 24 dc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x115 24 dc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0x116 24 dc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x117 24 dc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0x118 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x119 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x11a 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x11b 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x11c 24 dc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x11d 24 dc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x11e 24 dc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x11f 24 dc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0x120 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x121 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x122 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x123 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x124 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x125 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x126 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x69 32 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
128 GLXFBConfigs:
0x6a 0 tc 0 8 0 r . . 3 3 2 0 0 0 0 0 0 0 0 0 0 None
0x6b 0 tc 0 8 0 r . . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow
0x6c 0 tc 0 8 0 r y . 3 3 2 0 0 0 0 0 0 0 0 0 0 None
0x6d 0 tc 0 8 0 r y . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow
0x6e 0 tc 0 8 0 r . . 3 3 2 0 0 0 8 0 0 0 0 0 0 None
0x6f 0 tc 0 8 0 r . . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow
0x70 0 tc 0 8 0 r y . 3 3 2 0 0 0 8 0 0 0 0 0 0 None
0x71 0 tc 0 8 0 r y . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow
0x72 0 tc 0 8 0 r . . 3 3 2 0 0 8 0 0 0 0 0 0 0 None
0x73 0 tc 0 8 0 r . . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow
0x74 0 tc 0 8 0 r y . 3 3 2 0 0 8 0 0 0 0 0 0 0 None
0x75 0 tc 0 8 0 r y . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow
0x76 0 tc 0 8 0 r . . 3 3 2 0 0 8 8 0 0 0 0 0 0 None
0x77 0 tc 0 8 0 r . . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow
0x78 0 tc 0 8 0 r y . 3 3 2 0 0 8 8 0 0 0 0 0 0 None
0x79 0 tc 0 8 0 r y . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow
0x7a 0 tc 0 16 0 r . . 5 6 5 0 0 0 0 0 0 0 0 0 0 None
0x7b 0 tc 0 16 0 r . . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow
0x7c 0 tc 0 16 0 r y . 5 6 5 0 0 0 0 0 0 0 0 0 0 None
0x7d 0 tc 0 16 0 r y . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow
0x7e 0 tc 0 16 0 r . . 5 6 5 0 0 0 8 0 0 0 0 0 0 None
0x7f 0 tc 0 16 0 r . . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow
0x80 0 tc 0 16 0 r y . 5 6 5 0 0 0 8 0 0 0 0 0 0 None
0x81 0 tc 0 16 0 r y . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow
0x82 0 tc 0 16 0 r . . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0x83 0 tc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow
0x84 0 tc 0 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0x85 0 tc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow
0x86 0 tc 0 16 0 r . . 5 6 5 0 0 16 8 0 0 0 0 0 0 None
0x87 0 tc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow
0x88 0 tc 0 16 0 r y . 5 6 5 0 0 16 8 0 0 0 0 0 0 None
0x89 0 tc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow
0x8a 0 tc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x8b 0 tc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0x8c 0 tc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0x8d 0 tc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0x8e 0 tc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0x8f 0 tc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0x90 0 tc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0x91 0 tc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0x92 0 tc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0x93 0 tc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0x94 0 tc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0x95 0 tc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0x96 0 tc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x97 0 tc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0x98 0 tc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0x99 0 tc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0x9a 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x9b 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x9c 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x9d 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x9e 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0x9f 0 tc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0xa0 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0xa1 0 tc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0xa2 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0xa3 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0xa4 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0xa5 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0xa6 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0xa7 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0xa8 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0xa9 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0xaa 0 dc 0 8 0 r . . 3 3 2 0 0 0 0 0 0 0 0 0 0 None
0xab 0 dc 0 8 0 r . . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow
0xac 0 dc 0 8 0 r y . 3 3 2 0 0 0 0 0 0 0 0 0 0 None
0xad 0 dc 0 8 0 r y . 3 3 2 0 0 0 0 16 16 16 0 0 0 Slow
0xae 0 dc 0 8 0 r . . 3 3 2 0 0 0 8 0 0 0 0 0 0 None
0xaf 0 dc 0 8 0 r . . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow
0xb0 0 dc 0 8 0 r y . 3 3 2 0 0 0 8 0 0 0 0 0 0 None
0xb1 0 dc 0 8 0 r y . 3 3 2 0 0 0 8 16 16 16 0 0 0 Slow
0xb2 0 dc 0 8 0 r . . 3 3 2 0 0 8 0 0 0 0 0 0 0 None
0xb3 0 dc 0 8 0 r . . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow
0xb4 0 dc 0 8 0 r y . 3 3 2 0 0 8 0 0 0 0 0 0 0 None
0xb5 0 dc 0 8 0 r y . 3 3 2 0 0 8 0 16 16 16 0 0 0 Slow
0xb6 0 dc 0 8 0 r . . 3 3 2 0 0 8 8 0 0 0 0 0 0 None
0xb7 0 dc 0 8 0 r . . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow
0xb8 0 dc 0 8 0 r y . 3 3 2 0 0 8 8 0 0 0 0 0 0 None
0xb9 0 dc 0 8 0 r y . 3 3 2 0 0 8 8 16 16 16 0 0 0 Slow
0xba 0 dc 0 16 0 r . . 5 6 5 0 0 0 0 0 0 0 0 0 0 None
0xbb 0 dc 0 16 0 r . . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow
0xbc 0 dc 0 16 0 r y . 5 6 5 0 0 0 0 0 0 0 0 0 0 None
0xbd 0 dc 0 16 0 r y . 5 6 5 0 0 0 0 16 16 16 0 0 0 Slow
0xbe 0 dc 0 16 0 r . . 5 6 5 0 0 0 8 0 0 0 0 0 0 None
0xbf 0 dc 0 16 0 r . . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow
0xc0 0 dc 0 16 0 r y . 5 6 5 0 0 0 8 0 0 0 0 0 0 None
0xc1 0 dc 0 16 0 r y . 5 6 5 0 0 0 8 16 16 16 0 0 0 Slow
0xc2 0 dc 0 16 0 r . . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0xc3 0 dc 0 16 0 r . . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow
0xc4 0 dc 0 16 0 r y . 5 6 5 0 0 16 0 0 0 0 0 0 0 None
0xc5 0 dc 0 16 0 r y . 5 6 5 0 0 16 0 16 16 16 0 0 0 Slow
0xc6 0 dc 0 16 0 r . . 5 6 5 0 0 16 8 0 0 0 0 0 0 None
0xc7 0 dc 0 16 0 r . . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow
0xc8 0 dc 0 16 0 r y . 5 6 5 0 0 16 8 0 0 0 0 0 0 None
0xc9 0 dc 0 16 0 r y . 5 6 5 0 0 16 8 16 16 16 0 0 0 Slow
0xca 0 dc 0 24 0 r . . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0xcb 0 dc 0 24 0 r . . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0xcc 0 dc 0 24 0 r y . 8 8 8 0 0 0 0 0 0 0 0 0 0 None
0xcd 0 dc 0 24 0 r y . 8 8 8 0 0 0 0 16 16 16 0 0 0 Slow
0xce 0 dc 0 24 0 r . . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0xcf 0 dc 0 24 0 r . . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0xd0 0 dc 0 24 0 r y . 8 8 8 0 0 0 8 0 0 0 0 0 0 None
0xd1 0 dc 0 24 0 r y . 8 8 8 0 0 0 8 16 16 16 0 0 0 Slow
0xd2 0 dc 0 24 0 r . . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0xd3 0 dc 0 24 0 r . . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0xd4 0 dc 0 24 0 r y . 8 8 8 0 0 24 0 0 0 0 0 0 0 None
0xd5 0 dc 0 24 0 r y . 8 8 8 0 0 24 0 16 16 16 0 0 0 Slow
0xd6 0 dc 0 24 0 r . . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0xd7 0 dc 0 24 0 r . . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0xd8 0 dc 0 24 0 r y . 8 8 8 0 0 24 8 0 0 0 0 0 0 None
0xd9 0 dc 0 24 0 r y . 8 8 8 0 0 24 8 16 16 16 0 0 0 Slow
0xda 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0xdb 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0xdc 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0xdd 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0xde 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0xdf 0 dc 0 32 0 r . . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0xe0 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 0 0 0 0 0 0 None
0xe1 0 dc 0 32 0 r y . 8 8 8 8 0 0 8 16 16 16 16 0 0 Slow
0xe2 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0xe3 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0xe4 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0xe5 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0xe6 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0xe7 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0xe8 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0xe9 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
# /etc/X11/xorg.conf (Xorg X Window System server configuration file)
# This file was generated by fll_xorgconfig, the F.U.L.L.S.T.O.R.Y.
# Xorg Configuration tool.
# Edit this file with caution, and see the xorg.conf(5) manual page.
Section "Device"
Identifier "Device 0"
Driver "radeon"
BoardName "ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]"
BusID "PCI:1:0:0"
EndSection
