make menuconfig
make menuconfig
make xconfig
-bash: make: command not found
dpkg -l | grep make
aptitude install make
kaka@debian:~$ aptitude search ncurses
p evms-ncurses - Enterprise Volume Management System (ncurses UI)
p irmp3-ncurses - irmp3 control frontend
i A lib32ncurses5 - Shared libraries for terminal handling (32-bit)
p lib32ncurses5-dev - Developer's libraries for ncurses (32-bit)
v libncurses-dev -
p libncurses-ruby - ruby Extension for the ncurses C library
p libncurses-ruby1.8 - ruby Extension for the ncurses C library
p libncurses-ruby1.9 - ruby Extension for the ncurses C library
i libncurses5 - Shared libraries for terminal handling
p libncurses5-dbg - Debugging/profiling libraries for ncurses
i libncurses5-dev - Developer's libraries and docs for ncurses
i libncursesw5 - Shared libraries for terminal handling (wide character support)
p libncursesw5-dbg - Debugging/profiling libraries for ncurses
p libncursesw5-dev - Developer's libraries for ncursesw
i ncurses-base - Descriptions of common terminal types
i ncurses-bin - Terminal-related programs and man pages
v ncurses-dev -
p ncurses-hexedit - Edit files/disks in hex, ASCII and EBCDIC
v ncurses-runtime -
i ncurses-term - Additional terminal type definitions
kaka@debian:~$
apt-get install build-essential
make: *** brak reguł do wykonania obiektu 'menuconfig'. Stop.
