smb.conf i sekcja global
[global]
workgroup = domenalinux
printing = cups
;wins server = 172.23.198.1
printcap name = cups
printcap cache time = 750
cups options = raw
map to guest = Bad User
;include = /etc/samba/dhcp.conf
;max disk size = 100
logon script = time.bat
logon path = \\%L\profiles\.msprofile
logon home = \\%L\%U\.9xprofile
logon drive = P:
usershare allow guests = Yes
encrypt passwords = Yes
smb passwd file = /etc/samba/smbpasswd
security = user
socket options = TCP_NODELAY
hosts allow = 172.23.198.
log level = 3
add machine script = /usr/sbin/useradd -c Machine -d /var/lib/nobody -s /bin/false %m$
admin users = root
domain logons = Yes
domain master = Yes
local master = Yes
os level = 65
preferred master = Yes
name resolve order = host dns
time server = yes
hide files = /*.ini/
invalid users = root
hosts allow = 127.0.0.1 172.23.198.0/24
[2009/10/16 11:08:49, 0] lib/util_sock.c:get_peer_addr(1221)
Oct 16 11:08:49 localhost smbd[21258]: getpeername failed. Error was Drugi koniec nie jest połączony
Oct 16 11:08:49 localhost smbd[21258]: [2009/10/16 11:08:49, 0] lib/access.c:check_access(327)
Oct 16 11:08:49 localhost smbd[21258]: [2009/10/16 11:08:49, 0] lib/util_sock.c:get_peer_addr(1221)
Oct 16 11:08:49 localhost smbd[21258]: Denied connection from (0.0.0.0)
Oct 16 11:08:49 localhost smbd[21258]: Connection denied from 0.0.0.0
Oct 16 11:08:49 localhost smbd[21258]: [2009/10/16 11:08:49, 0] lib/util_sock.c:write_data(562)
Oct 16 11:08:49 localhost smbd[21258]: write_data: write failure in writing to client 172.23.198.64. Error Połączenie zerwane przez drugą stronę
Oct 16 11:08:49 localhost smbd[21258]: [2009/10/16 11:08:49, 0] lib/util_sock.c:send_smb(761)
Oct 16 11:08:49 localhost smbd[21258]: Error writing 5 bytes to client. -1. (Połączenie zerwane przez drugą stronę)
Oct 16 11:08:49 localhost smbd[21259]: [2009/10/16 11:08:49, 0] passdb/pdb_smbpasswd.c:startsmbfilepwent(204)
Oct 16 11:08:49 localhost smbd[21259]: startsmbfilepwent_internal: unable to open file /etc/samba/smbpasswd. Error was: Brak dost�pu
Oct 16 11:08:49 localhost smbd[21259]: [2009/10/16 11:08:49, 0] passdb/pdb_smbpasswd.c:add_smbfilepwd_entry(607)
Oct 16 11:08:49 localhost smbd[21259]: add_smbfilepwd_entry: unable to open file.
Oct 16 11:08:49 localhost smbd[21259]: startsmbfilepwent_internal: unable to open file /etc/samba/smbpasswd. Error was: Brak dostępu
-rw------- 1 root root 31304 2009-10-16 15:33 smbpasswd
