compiz --replaceKod: Zaznacz cały
kamil-pc:/home/kamil# compiz --replace
Checking for Xgl: not present.
xset q doesn't reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:00.0 0300: 10de:0428 (rev a1) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
aborting and using fallback: xterm
no xterm found, exiting
kamil-pc:/home/kamil# @edit W komunikacie jest coś napisane o logu /var/log/Xorg.0.log, oto on:
X.Org X Server 1.6.5
Release Date: 2009-10-11
Build Operating System: Linux 2.6.30.8-dsa-ia32 i686 Debian
Current Operating System: Linux kamil-pc 2.6.30-2-686 #1 SMP Sat Sep 26 01:16:22 UTC 2009 i686
Build Date: 13 October 2009 11:25:51AM
xorg-server 2:1.6.5-1 (buildd@murphy.debian.org)
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 15 18:26:35 2009
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(**) Extension "Composite" is enabled
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x6c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 7
(--) PCI:*(0:1:0:0) 10de:0428:17ff:0593 nVidia Corporation G86 [GeForce 8400M G] rev 161, Mem @ 0xce000000/16777216, 0xd0000000/268435456, 0xcc000000/33554432, I/O @ 0x00002000/128
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
compiled for 1.6.5, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.6.5, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.5, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA dlloader X Driver 185.18.36 Fri Aug 14 17:24:40 PDT 2009
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01@00:00:0
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) resource ranges after probing:
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "NoLogo"
(**) NVIDIA(0): Option "RenderAccel" "True"
(**) NVIDIA(0): Option "AllowGLXWithComposite" "True"
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Enabling RENDER acceleration
(EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
(EE) NVIDIA(0): log file that the GLX module has been loaded in your X
(EE) NVIDIA(0): server, and that the module is the NVIDIA GLX module. If
(EE) NVIDIA(0): you continue to encounter problems, Please try
(EE) NVIDIA(0): reinstalling the NVIDIA driver.
(II) NVIDIA(0): NVIDIA GPU GeForce 8400M G (G86M) at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 60.86.49.00.13
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 8400M G at PCI:1:0:0:
(--) NVIDIA(0): AUO (DFP-0)
(--) NVIDIA(0): AUO (DFP-0): 330.0 MHz maximum pixel clock
(--) NVIDIA(0): AUO (DFP-0): Internal Dual Link LVDS
(II) NVIDIA(0): Assigned Display Device: DFP-0
(==) NVIDIA(0):
(==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
(==) NVIDIA(0): will be used as the requested mode.
(==) NVIDIA(0):
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): "nvidia-auto-select"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 800
(--) NVIDIA(0): DPI set to (98, 96); computed from "UseEdidDpi" X config
(--) NVIDIA(0): option
(**) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): ACPI display change hotkey events enabled: the X server is new
(II) NVIDIA(0): enough to receive ACPI display change hotkey events.
(II) NVIDIA(0): Setting mode "nvidia-auto-select"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(==) NVIDIA(0): Disabling shared memory pixmaps
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(WW) NVIDIA(0): Option "XAANoOffscreenPixmaps" is not used
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XC-MISC
SELinux: Disabled on system, not enabling in X server
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(II) config/hal: Adding input device AT Translated Set 2 keyboard
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.6.3, module version = 2.2.5
ABI class: X.Org XInput driver, version 4.0
(**) AT Translated Set 2 keyboard: always reports core events
(**) AT Translated Set 2 keyboard: Device: "/dev/input/event0"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "pl"
(II) config/hal: Adding input device USB 2.0 Camera
(**) USB 2.0 Camera: always reports core events
(**) USB 2.0 Camera: Device: "/dev/input/event7"
(II) USB 2.0 Camera: Found keys
(II) USB 2.0 Camera: Configuring as keyboard
(II) XINPUT: Adding extended input device "USB 2.0 Camera" (type: KEYBOARD)
(II) config/hal: Adding input device Power Button
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event4"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(II) config/hal: Adding input device Video Bus
(**) Video Bus: always reports core events
(**) Video Bus: Device: "/dev/input/event5"
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
(**) Power Button: Device: "/dev/input/event1"
(II) config/hal: Adding input device A4Tech RF USB Mouse
(**) A4Tech RF USB Mouse: always reports core events
(**) A4Tech RF USB Mouse: Device: "/dev/input/event8"
(II) A4Tech RF USB Mouse: Found 12 mouse buttons
(II) A4Tech RF USB Mouse: Found x and y relative axes
(II) A4Tech RF USB Mouse: Found scroll wheel(s)
(II) A4Tech RF USB Mouse: Configuring as mouse
(**) A4Tech RF USB Mouse: YAxisMapping: buttons 4 and 5
(**) A4Tech RF USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "A4Tech RF USB Mouse" (type: MOUSE)
(**) A4Tech RF USB Mouse: (accel) keeping acceleration scheme 1
(**) A4Tech RF USB Mouse: (accel) filter chain progression: 2.00
(**) A4Tech RF USB Mouse: (accel) filter stage 0: 20.00 ms
(**) A4Tech RF USB Mouse: (accel) set acceleration profile 0
(II) A4Tech RF USB Mouse: initialized for relative axes.
(II) config/hal: Adding input device SynPS/2 Synaptics TouchPad
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.6.1.901, module version = 1.1.2
(II) Synaptics touchpad driver version 1.1.2
(**) Option "Device" "/dev/input/event6"
(II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
(II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
(II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
(II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
(II) SynPS/2 Synaptics TouchPad: buttons: left right middle double triple
(--) SynPS/2 Synaptics TouchPad: touchpad found
(**) SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD)
(**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
(**) SynPS/2 Synaptics TouchPad: (accel) filter chain progression: 2.00
(**) SynPS/2 Synaptics TouchPad: (accel) filter stage 0: 20.00 ms
(**) SynPS/2 Synaptics TouchPad: (accel) set acceleration profile 0
