Ostatnio zachciało mi się zainstalować jakiś panel do zarządzania serwerem, więc zainstalowałem ispcp (Internet Service Provider Control Panel). Jednak po instalacji wszytko mi padło, oto co dostaje przy próbuje restartu apache:
sudo /etc/init.d/apache2 restart
Forcing reload of web server (apache2)...httpd (pid 3281?) not runningKod: Zaznacz cały
Tue Oct 13 19:20:24 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:23:31 2009] [notice] FastCGI: process manager initialized (pid 20455)
[Tue Oct 13 19:23:31 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:23:32 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:33 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:34 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:23:45 2009] [notice] FastCGI: process manager initialized (pid 21653)
[Tue Oct 13 19:23:45 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:23:45 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:23:46 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:48 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:32:52 2009] [notice] FastCGI: process manager initialized (pid 7187)
[Tue Oct 13 19:32:52 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:32:52 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:32:53 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:32:54 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:32:55 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:42:27 2009] [notice] FastCGI: process manager initialized (pid 30041)
[Tue Oct 13 19:42:27 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:42:27 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:42:28 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:42:30 2009] [alert] No active workers found... Apache is exiting!Kod: Zaznacz cały
sudo hg status
M apache2/mods-available/proxy.conf
M group
M group-
M gshadow
M gshadow-
M hosts
M logrotate.d/apache2
M passwd
M passwd-
M postfix/main.cf
M postfix/master.cf
M proftpd/proftpd.conf
M shadow
M shadow-
? apache2/mods-available/cband.conf
? apache2/mods-available/cband.load
? apache2/mods-available/fastcgi.conf
? apache2/mods-available/fastcgi.load
? apache2/mods-available/fastcgi_ispcp.conf
? apache2/mods-available/fastcgi_ispcp.load
? apache2/mods-available/fcgid.conf
? apache2/mods-available/fcgid.load
? apache2/mods-available/fcgid_ispcp.conf
? apache2/mods-available/fcgid_ispcp.load
? apache2/sites-available/00_master.conf
? apache2/sites-available/01_awstats.conf
? apache2/sites-available/ispcp.conf
? awstats/awstats.conf
? awstats/awstats.conf.local
? bind/db.0
? bind/db.127
? bind/db.255
? bind/db.empty
? bind/db.local
? bind/db.root
? bind/named.conf
? bind/named.conf.local
? bind/named.conf.options
? bind/rndc.key
? bind/zones.rfc1918
? chkrootkit.conf
? courier/authdaemonrc
? courier/authmodulelist
? courier/imapd
? courier/maildrop
? courier/pop3d
? courier/userdb
? courier/userdb.dat
? courier/userdbshadow.dat
? cron.d/awstats
? cron.d/ispcp
? cron.daily/chkrootkit
? cron.daily/rkhunter
? cron.weekly/rkhunter
? default/bind9
? default/courier
? default/portmap
? default/postgrey
? default/rkhunter
? default/saslauthd
? dictionaries-common/ispell-default
? emacs/site-start.d/50dictionaries-common.el
? fam.conf
? hosts.bkp
? init.d/bind9
? init.d/courier-authdaemon
? init.d/courier-imap
? init.d/courier-pop
? init.d/fam
? init.d/ispcp_daemon
? init.d/ispcp_network
? init.d/policyd-weight
? init.d/portmap
? init.d/postgrey
? init.d/saslauthd
? ispcp/apache/00_master.conf
? ispcp/apache/01_awstats.conf
? ispcp/apache/backup/empty-file
? ispcp/apache/backup/fastcgi_ispcp.conf.ispcp
? ispcp/apache/backup/fcgid_ispcp.conf.ispcp
? ispcp/apache/backup/proxy.conf
? ispcp/apache/httpd.conf
? ispcp/apache/parts/als_awstats_b.tpl
? ispcp/apache/parts/als_awstats_dynamic_entry.tpl
? ispcp/apache/parts/als_awstats_e.tpl
? ispcp/apache/parts/als_awstats_static_entry.tpl
? ispcp/apache/parts/als_b.tpl
? ispcp/apache/parts/als_cgi_b.tpl
? ispcp/apache/parts/als_cgi_e.tpl
? ispcp/apache/parts/als_cgi_entry.tpl
? ispcp/apache/parts/als_e.tpl
? ispcp/apache/parts/als_entry.tpl
? ispcp/apache/parts/als_php2_b.tpl
? ispcp/apache/parts/als_php2_e.tpl
? ispcp/apache/parts/als_php2_entry.tpl
? ispcp/apache/parts/als_php_b.tpl
? ispcp/apache/parts/als_php_e.tpl
? ispcp/apache/parts/als_php_entry.tpl
? ispcp/apache/parts/als_rdr_b.tpl
? ispcp/apache/parts/als_rdr_e.tpl
? ispcp/apache/parts/als_rdr_entry.tpl
? ispcp/apache/parts/cfg_b.tpl
? ispcp/apache/parts/cfg_e.tpl
? ispcp/apache/parts/custom.conf.tpl
? ispcp/apache/parts/dg_b.tpl
? ispcp/apache/parts/dg_e.tpl
? ispcp/apache/parts/dg_entry.tpl
? ispcp/apache/parts/dmn_awstats_b.tpl
? ispcp/apache/parts/dmn_awstats_dynamic_entry.tpl
? ispcp/apache/parts/dmn_awstats_e.tpl
? ispcp/apache/parts/dmn_awstats_static_entry.tpl
? ispcp/apache/parts/dmn_b.tpl
? ispcp/apache/parts/dmn_cgi_b.tpl
? ispcp/apache/parts/dmn_cgi_e.tpl
? ispcp/apache/parts/dmn_cgi_entry.tpl
? ispcp/apache/parts/dmn_e.tpl
? ispcp/apache/parts/dmn_entry.tpl
? ispcp/apache/parts/dmn_php2_b.tpl
? ispcp/apache/parts/dmn_php2_e.tpl
? ispcp/apache/parts/dmn_php2_entry.tpl
? ispcp/apache/parts/dmn_php_b.tpl
? ispcp/apache/parts/dmn_php_e.tpl
? ispcp/apache/parts/dmn_php_entry.tpl
? ispcp/apache/parts/ispcp_base.tpl
? ispcp/apache/parts/sub_b.tpl
? ispcp/apache/parts/sub_cgi_b.tpl
? ispcp/apache/parts/sub_cgi_e.tpl
? ispcp/apache/parts/sub_cgi_entry.tpl
? ispcp/apache/parts/sub_e.tpl
? ispcp/apache/parts/sub_entry.tpl
? ispcp/apache/parts/sub_php2_b.tpl
? ispcp/apache/parts/sub_php2_e.tpl
? ispcp/apache/parts/sub_php2_entry.tpl
? ispcp/apache/parts/sub_php_b.tpl
? ispcp/apache/parts/sub_php_e.tpl
? ispcp/apache/parts/sub_php_entry.tpl
? ispcp/apache/parts/vh_b.tpl
? ispcp/apache/parts/vh_e.tpl
? ispcp/apache/parts/vh_entry.tpl
? ispcp/apache/working/fastcgi_ispcp.conf
? ispcp/apache/working/fcgid_ispcp.conf
? ispcp/apache/working/ispcp.conf
? ispcp/awstats/awstats.ispcp_tpl.conf
? ispcp/bind/backup/empty-file
? ispcp/bind/backup/named.conf.1255457775
? ispcp/bind/backup/named.conf.1255458277
? ispcp/bind/backup/named.conf.1255459443
? ispcp/bind/backup/named.conf.ispcp
? ispcp/bind/backup/named.conf.system
? ispcp/bind/named.conf
? ispcp/bind/parts/cfg_dta_b.tpl
? ispcp/bind/parts/cfg_dta_e.tpl
? ispcp/bind/parts/cfg_entry.tpl
? ispcp/bind/parts/cfg_entry_b.tpl
? ispcp/bind/parts/cfg_entry_e.tpl
? ispcp/bind/parts/db_dns2_b.tpl
? ispcp/bind/parts/db_dns2_e.tpl
? ispcp/bind/parts/db_e.tpl
? ispcp/bind/parts/db_master_e.tpl
? ispcp/bind/parts/db_sub_entry.tpl
? ispcp/bind/parts/db_sub_entry_b.tpl
? ispcp/bind/parts/db_sub_entry_e.tpl
? ispcp/bind/parts/db_time_b.tpl
? ispcp/bind/parts/db_time_e.tpl
? ispcp/bind/working/admin.ibochnia.pl.db
? ispcp/bind/working/named.conf
? ispcp/courier/backup/authdaemonrc.system
? ispcp/courier/backup/empty-file
? ispcp/courier/backup/userdb.system
? ispcp/courier/userdb
? ispcp/courier/working/userdb
? ispcp/cron.d/backup/empty-file
? ispcp/cron.d/backup/ispcp
? ispcp/cron.d/ispcp
? ispcp/cron.d/parts/als_awstats_b.tpl
? ispcp/cron.d/parts/als_awstats_e.tpl
? ispcp/cron.d/parts/als_awstats_entry.tpl
? ispcp/cron.d/parts/dmn_awstats_b.tpl
? ispcp/cron.d/parts/dmn_awstats_e.tpl
? ispcp/cron.d/parts/dmn_awstats_entry.tpl
? ispcp/cron.d/parts/dmn_bk_b.tpl
? ispcp/cron.d/parts/dmn_bk_e.tpl
? ispcp/cron.d/parts/dmn_bk_entry.tpl
? ispcp/cron.d/parts/dmn_custom_b.tpl
? ispcp/cron.d/parts/dmn_custom_e.tpl
? ispcp/cron.d/parts/dmn_custom_entry.tpl
? ispcp/cron.d/parts/dt_b.tpl
? ispcp/cron.d/parts/dt_e.tpl
? ispcp/cron.d/working/ispcp
? ispcp/database/database.sql
? ispcp/database/languages.sql
? ispcp/fcgi/backup/empty-file
? ispcp/fcgi/backup/php5-fcgi-starter.ispcp
? ispcp/fcgi/parts/master/php4-fcgi-starter.tpl
? ispcp/fcgi/parts/master/php4/php.ini
? ispcp/fcgi/parts/master/php5-fcgi-starter.tpl
? ispcp/fcgi/parts/master/php5/php.ini
? ispcp/fcgi/parts/php4-fcgi-starter.tpl
? ispcp/fcgi/parts/php4/php.ini
? ispcp/fcgi/parts/php5-fcgi-starter.tpl
? ispcp/fcgi/parts/php5/php.ini
? ispcp/fcgi/working/empty-file
? ispcp/ispcp.conf
? ispcp/postfix/backup/empty-file
? ispcp/postfix/backup/main.cf.ispcp
? ispcp/postfix/backup/main.cf.system
? ispcp/postfix/backup/master.cf.ispcp
? ispcp/postfix/backup/master.cf.system
? ispcp/postfix/ispcp/aliases
? ispcp/postfix/ispcp/domains
? ispcp/postfix/ispcp/mailboxes
? ispcp/postfix/ispcp/sender-access
? ispcp/postfix/ispcp/transport
? ispcp/postfix/main.cf
? ispcp/postfix/master.cf
? ispcp/postfix/parts/empty-file
? ispcp/postfix/working/aliases
? ispcp/postfix/working/domains
? ispcp/postfix/working/mailboxes
? ispcp/postfix/working/sender-access
? ispcp/postfix/working/transport
? ispcp/proftpd/backup/empty-file
? ispcp/proftpd/backup/proftpd.conf.ispcp
? ispcp/proftpd/backup/proftpd.conf.system
? ispcp/proftpd/parts/proftpd.conf.tpl
? ispcp/proftpd/proftpd.conf
? ispcp/proftpd/working/empty-file
? logcheck/ignore.d.server/courier-imap
? logcheck/ignore.d.server/courier-pop
? logcheck/ignore.d.server/postgrey
? logcheck/violations.ignore.d/courier-imap
? logcheck/violations.ignore.d/courier-pop
? logcheck/violations.ignore.d/postgrey
? logrotate.d/ispcp
? openoffice/dictionary.lst
? openoffice/dictionary.lst.old
? pam.d/imap
? pam.d/pop3
? php5/conf.d/imap.ini
? php5/conf.d/mcrypt.ini
? php5/conf.d/mhash.ini
? postfix/ispcp/aliases
? postfix/ispcp/aliases.db
? postfix/ispcp/domains
? postfix/ispcp/domains.db
? postfix/ispcp/mailboxes
? postfix/ispcp/mailboxes.db
? postfix/ispcp/sender-access
? postfix/ispcp/sender-access.db
? postfix/ispcp/transport
? postfix/ispcp/transport.db
? postgrey/whitelist_clients
? postgrey/whitelist_recipients
? proftpd/ispcp/root_domain.conf
? rkhunter.conf
? sasldb2
