mam squeeze, kde, GeForce2 MX200, i386. Zrobiłem dziś aptitude dist-upgrade z 2.6.26.2-686 do 2.6.30-1-686. Po wszystkim nie było X-ów. Niemal identyczny problem miałem z komputerem dzieci (ten wątek). Tam pomogły polecenia:
aptitude purge --purge ~nxserver-xorg
aptitude install xserver-xorgWywołanie i połączenie wyników
X -configure
dpkg-reconfigure xserver-xorgKod: Zaznacz cały
/var/log/Xorg.0.log
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at [url]http://bugs.freedesktop.org/[/url].
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See [url]http://wiki.x.org/wiki/GitPage[/url] for git access instructions.
X.Org X Server 1.6.3.901 (1.6.4 RC 1)
Release Date: 2009-8-25
Build Operating System: Linux 2.6.30.6-dsa-ia32 i686 Debian
Current Operating System: Linux localhost 2.6.30-1-686 #1 SMP Sat Aug 15 19:11:58 UTC 2009 i686
Build Date: 14 September 2009 05:23:17PM
xorg-server 2:1.6.3.901-1 (buildd@murphy.debian.org)
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 8 15:56:44 2009
(II) Loader magic: 0xa40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(--) using VT number 7
(--) PCI:*(0:1:0:0) 10de:0111:0000:0000 nVidia Corporation NV11DDR [GeForce2 MX200] rev 178, Mem @ 0xde000000/16777216, 0xd0000000/134217728, BIOS @ 0x????????/65536
(==) Using default built-in configuration (30 lines)
(==) --- Start of built-in configuration ---
Section "Device"
Identifier "Builtin Default nv Device 0"
Driver "nv"
EndSection
Section "Screen"
Identifier "Builtin Default nv Screen 0"
Device "Builtin Default nv Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vesa Device 0"
Driver "vesa"
EndSection
Section "Screen"
Identifier "Builtin Default vesa Screen 0"
Device "Builtin Default vesa Device 0"
EndSection
Section "Device"
Identifier "Builtin Default fbdev Device 0"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "Builtin Default fbdev Screen 0"
Device "Builtin Default fbdev Device 0"
EndSection
Section "ServerLayout"
Identifier "Builtin Default Layout"
Screen "Builtin Default nv Screen 0"
Screen "Builtin Default vesa Screen 0"
Screen "Builtin Default fbdev Screen 0"
EndSection
(==) --- End of built-in configuration ---
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default nv Screen 0" (0)
(**) | |-->Monitor "<default monitor>"
(**) | |-->Device "Builtin Default nv Device 0"
(==) No monitor specified for screen "Builtin Default nv Screen 0".
Using a default monitor configuration.
(**) |-->Screen "Builtin Default vesa Screen 0" (1)
(**) | |-->Device "Builtin Default vesa Device 0"
(==) No monitor specified for screen "Builtin Default vesa Screen 0".
(**) |-->Screen "Builtin Default fbdev Screen 0" (2)
(**) | |-->Device "Builtin Default fbdev Device 0"
(==) No monitor specified for screen "Builtin Default fbdev Screen 0".
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
compiled for 1.6.3.901, module version = 1.0.0
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.6.3.901, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 1.6.2.901, module version = 2.1.14
ABI class: X.Org Video Driver, version 5.0
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.6.2.901, module version = 2.2.1
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers//fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.6.0, module version = 0.4.0
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro NVS 440, Quadro FX 550,
Quadro FX 550, Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 7100 GS,
GeForce 6800, GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT,
GeForce 6200, GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7350 LE,
GeForce 7300 LE, GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300,
GeForce Go 7400, GeForce Go 7400 GS, Quadro NVS 110M,
Quadro NVS 120M, Quadro FX 350M, GeForce 7500 LE, Quadro FX 350,
GeForce 7300 GS, GeForce 7650 GS, GeForce 7600 GT, GeForce 7600 GS,
GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT, GeForce Go 7700,
GeForce Go 7600, GeForce Go 7600 GT, Quadro NVS 300M,
GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560, GeForce 7900 GTX,
GeForce 7900 GT, GeForce 7900 GS, GeForce 7950 GX2, GeForce 7950 GX2,
GeForce 7950 GT, GeForce Go 7950 GTX, GeForce Go 7900 GS,
GeForce Go 7900 GTX, Quadro FX 2500M, Quadro FX 1500M,
Quadro FX 5500, Quadro FX 3500, Quadro FX 1500, Quadro FX 4500 X2,
GeForce 6150, GeForce 6150 LE, GeForce 6100, GeForce Go 6150,
Quadro NVS 210S / NVIDIA GeForce 6150LE, GeForce Go 6100,
GeForce 6150SE, GeForce 6100 nForce 405, GeForce 6100 nForce 400,
GeForce 6100 nForce 420, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8600 GT, GeForce 8600 GS, GeForce 8400 GS,
GeForce 9500M GS, GeForce 8600M GT, GeForce 9650M GS,
GeForce 8700M GT, Quadro FX 370, Quadro NVS 320M, Quadro FX 570M,
Quadro FX 1600M, Quadro FX 570, Quadro FX 1700, GeForce 8400 SE,
GeForce 8500 GT, GeForce 8400 GS, GeForce 8300 GS, GeForce 8400 GS,
GeForce 8600M GS, GeForce 8400M GT, GeForce 8400M GS,
GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M, Quadro NVS 135M,
GeForce 9400 GT, Quadro FX 360M, GeForce 9300M G, Quadro NVS 290,
GeForce GTX 295, GeForce GTX 280, GeForce GTX 260, GeForce GTX 285,
Quadro CX, Quadro FX 5800, Quadro FX 4800, Quadro FX 3800,
GeForce 8800 GTS 512, GeForce 9800 GT, GeForce 8800 GT,
GeForce 9800 GX2, GeForce 9800 GT, GeForce 8800 GS,
GeForce 9800M GTX, GeForce 8800M GTS, GeForce 9800M GT,
GeForce 8800M GTX, GeForce 8800 GS, GeForce 9600 GSO,
GeForce 8800 GT, GeForce 9800 GTX, GeForce 9800 GTX+,
GeForce 9800 GT, GeForce GTS 250, GeForce 9800M GTX, Quadro FX 3700,
Quadro FX 3600M, Quadro FX 3700M, GeForce 9600 GT, GeForce 9600 GS,
GeForce 9600 GSO 512, GeForce GT 130, GeForce GT 140,
GeForce 9800M GTS, GeForce 9700M GTS, GeForce 9800M GS,
GeForce 9800M GTS, Quadro FX 1800, Quadro FX 2700M, GeForce 9500 GT,
GeForce 9400 GT, GeForce 9500 GT, GeForce GT 120, GeForce 9600M GT,
GeForce 9600M GS, GeForce 9600M GT, GeForce 9700M GT,
GeForce 9500M G, GeForce 9650M GT, GeForce 9500 GT, Quadro FX 380,
Quadro FX 580, Quadro FX 770M, GeForce 9300 GE, GeForce 9300 GS,
GeForce 8400 GS, GeForce 9300M GS, GeForce G100, GeForce 9200M GS,
GeForce 9300M GS, Quadro NVS 150M, Quadro NVS 160M, Quadro NVS 420,
Quadro FX 370 LP, Quadro NVS 450, Quadro NVS 295
(II) VESA: driver for VESA chipsets: vesa
(II) FBDEV: driver for framebuffer: fbdev
(II) Primary Device is: PCI 01@00:00:0
(--) NV: Found NVIDIA GeForce2 MX 100/200 at 01@00:00:0
(WW) Falling back to old probe method for vesa
(WW) Falling back to old probe method for fbdev
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
(II) resource ranges after probing:
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce2 MX 100/200"
(II) NV(0): Creating default Display subsection in Screen section
"Builtin Default nv Screen 0" for depth/fbbpp 24/32
(==) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.6.3.901, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xD0000000
(--) NV(0): MMIO registers at 0xDE000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:E-EDID segment register" registered at address 0x60.
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: ADI Model: 3150 Serial#: 16777552
(II) NV(0): Year: 1998 Week: 28
(II) NV(0): EDID Version: 1.1
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) NV(0): Sync: Separate
(II) NV(0): Max Image Size [cm]: horiz.: 30 vert.: 22
(II) NV(0): Gamma: 1.00
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): redX: 0.619 redY: 0.343 greenX: 0.298 greenY: 0.595
(II) NV(0): blueX: 0.146 blueY: 0.104 whiteX: 0.294 whiteY: 0.309
(II) NV(0): Supported established timings:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported standard timings:
(II) NV(0): #0: hsize: 640 vsize 360 refresh: 85 vid: 55601
(II) NV(0): #1: hsize: 640 vsize 480 refresh: 70 vid: 18993
(II) NV(0): #2: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) NV(0): #3: hsize: 800 vsize 600 refresh: 70 vid: 19013
(II) NV(0): #4: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) NV(0): #5: hsize: 1024 vsize 1024 refresh: 107 vid: 12129
(WW) NV(0): Unknown vendor-specific block 1
(II) NV(0): Ranges: V min: 31 V max: 56 Hz, H min: 56 H max: 85 kHz,
(II) NV(0): Serial No: 828T00100150
(II) NV(0): Monitor name: ADI TD_5S1
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff000489503150010001
(II) NV(0): 1c080101681e1600e8b5a49e574c9825
(II) NV(0): 1a4b4fafcc0031d9314a3159454a4559
(II) NV(0): 612f0101010100000001000101010001
(II) NV(0): 01010101000a2020000000fd001f3838
(II) NV(0): 55ff000a202020202020000000ff0038
(II) NV(0): 32385430303130303135300a000000fc
(II) NV(0): 004144492054445f35533120200a003f
(II) NV(0): Probing for EDID on I2C bus B...
(II) NV(0): ... none found
(II) NV(0): Unable to detect which CRTCNumber...
(==) NV(0): ...Defaulting to CRTCNumber 0
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): EDID vendor "ADI", prod id 12624
(II) NV(0): Using EDID range info for horizontal sync
(II) NV(0): Using EDID range info for vertical refresh
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) NV(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) NV(0): Modeline "640x480"x0.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(II) NV(0): Modeline "800x600"x0.0 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(--) NV(0): VideoRAM: 32768 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): <default monitor>: Using hsync range of 56.00-85.00 kHz
(II) NV(0): <default monitor>: Using vrefresh range of 31.00-56.00 Hz
(II) NV(0): Estimated virtual size for aspect ratio 1.3636 is 1024x768
(II) NV(0): Clock range: 12.00 to 350.00 MHz
(II) NV(0): Not using default mode "640x350" (hsync out of range)
(II) NV(0): Not using default mode "320x175" (hsync out of range)
(II) NV(0): Not using default mode "640x400" (hsync out of range)
(II) NV(0): Not using default mode "320x200" (hsync out of range)
(II) NV(0): Not using default mode "720x400" (hsync out of range)
(II) NV(0): Not using default mode "360x200" (hsync out of range)
(II) NV(0): Not using default mode "640x480" (hsync out of range)
(II) NV(0): Not using default mode "320x240" (hsync out of range)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "400x300" (hsync out of range)
(II) NV(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(II) NV(0): Not using default mode "512x384" (hsync out of range)
(II) NV(0): Not using default mode "1024x768" (vrefresh out of range)
(II) NV(0): Not using default mode "512x384" (vrefresh out of range)
(II) NV(0): Not using default mode "1152x864" (width too large for virtual size)
(II) NV(0): Not using default mode "576x432" (vrefresh out of range)
(II) NV(0): Not using default mode "1280x960" (width too large for virtual size)
(II) NV(0): Not using default mode "640x480" (vrefresh out of range)
(II) NV(0): Not using default mode "1280x1024" (width too large for virtual size)
(II) NV(0): Not using default mode "640x512" (vrefresh out of range)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "800x600" (vrefresh out of range)
(II) NV(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) NV(0): Not using default mode "896x672" (vrefresh out of range)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (width too large for virtual size)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (width too large for virtual size)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "832x624" (hsync out of range)
(II) NV(0): Not using default mode "416x312" (hsync out of range)
(II) NV(0): Not using default mode "576x432" (hsync out of range)
(II) NV(0): Not using default mode "1360x768" (width too large for virtual size)
(II) NV(0): Not using default mode "680x384" (hsync out of range)
(II) NV(0): Not using default mode "1400x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "700x525" (vrefresh out of range)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "1440x900" (width too large for virtual size)
(II) NV(0): Not using default mode "720x450" (vrefresh out of range)
(II) NV(0): Not using default mode "1600x1024" (width too large for virtual size)
(II) NV(0): Not using default mode "800x512" (vrefresh out of range)
(II) NV(0): Not using default mode "1680x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "840x525" (vrefresh out of range)
(II) NV(0): Not using default mode "840x525" (hsync out of range)
(II) NV(0): Not using default mode "1920x1080" (width too large for virtual size)
(II) NV(0): Not using default mode "960x540" (vrefresh out of range)
(II) NV(0): Not using default mode "1920x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "960x600" (vrefresh out of range)
(II) NV(0): Not using default mode "2048x1536" (width too large for virtual size)
(II) NV(0): Not using driver mode "800x600" (hsync out of range)
(II) NV(0): Not using driver mode "640x480" (hsync out of range)
(II) NV(0): Not using driver mode "720x400" (hsync out of range)
(II) NV(0): Not using driver mode "1024x768" (vrefresh out of range)
(II) NV(0): Not using driver mode "1024x768" (hsync out of range)
(WW) NV(0): Mode pool is empty
(EE) NV(0): No valid modes found
(II) UnloadModule: "nv"
(II) UnloadModule: "vgahw"
(II) Unloading /usr/lib/xorg/modules//libvgahw.so
(II) UnloadModule: "int10"
(II) Unloading /usr/lib/xorg/modules//libint10.so
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at [url]http://wiki.x.org[/url]
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.piobad
