01:01.0 Network controller: Texas Instruments ACX 100 22Mbps Wireless InterfaceKod: Zaznacz cały
haruko:/home/urbinek# lsmod | grep acx
acx 120232 0
firmware_class 6816 1 acx
usbcore 118192 6 acx,usblp,usbhid,ehci_hcd,ohci_hcdKod: Zaznacz cały
haruko:/home/urbinek# ls /lib/firmware/ | grep acx
tiacx100
tiacx100r0DKod: Zaznacz cały
haruko:/etc/hostapd# iwconfig wlan0
wlan0 IEEE 802.11b+ ESSID:"urbinek_wifi" Nickname:"acx v0.3.36"
Mode:Master Frequency:2.442 GHz Access Point: 00:80:C8:09:9C:F0
Bit Rate:22 Mb/s Tx-Power=18 dBm Sensitivity=64/255
Retry min limit:7 RTS thr :o ff
Encryption key :o ff
Power Management :o ff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:5 Missed beacon:0
haruko:/home/urbinek# cat /etc/network/interfaces
auto lo eth0 eth1 wlan0
iface lo inet loopback
iface eth0 inet dhcp
iface eth1 inet static
address 192.168.1.1
netmask 255.255.255.0
iface wlan0 inet static
address 192.168.0.1 # ip w sieci bezprzewodowej
pre-up /etc/init.d/wlan0_preup # skrypt konfigurujący wifiKod: Zaznacz cały
haruko:/home/urbinek# cat /etc/init.d/wlan0_preup
#!/bin/sh
iwconfig wlan0 essid urbinek_wifi
iwconfig wlan0 mode Master
iwconfig wlan0 rate auto
iwconfig wlan0 channel 7
##jakaś tam konfiguracja DHCP dla eth0##
Reconfiguring network interfaces...
if-up.d/mountnfs[eth0]: waiting for interface eth1 before doing NFS mounts (warning).
if-up.d/mountnfs[eth0]: waiting for interface wlan0 before doing NFS mounts (warning).
if-up.d/mountnfs[eth1]: waiting for interface wlan0 before doing NFS mounts (warning).
done.Kod: Zaznacz cały
haruko:/home/urbinek# /etc/init.d/hostapd start
Starting advanced IEEE 802.11 management: hostapd failed!Jedyny sterownik, na którym chyba się włącza do madwifi:
haruko:/etc/hostapd# hostapd hostapd.conf
Configuration file: hostapd.conf
ioctl(SIOCGIFINDEX): No such device
madwifi driver initialization failed.
haruko:/etc/hostapd# cat hostapd.conf
logger_syslog=-1
logger_syslog_level=2
logger_stdout=-1
logger_stdout_level=2
debug=0
dump_file=/tmp/hostapd.dump
macaddr_acl=1
accept_mac_file=/etc/hostapd/accept
driver=hostap
ssid=urbinek_wifi
#wpa=2
#wpa_passphrase=passworder
#wpa_key_mgmt=WPA-PSK
#wpa_pairwise=CCMP TKIPNatomiast skanowanie sieci też jest bez rezultatu:
lo no wireless extensions.
eth0 no wireless extensions.
eth1 no wireless extensions.
Mode:Managed Frequency:2.442 GHz Access Point: Not-Associated
haruko:/etc/hostapd# iwlist wlan0 scan
wlan0 No scan results
