Zastanawiam się już jakiś czas nad takim o to przeniesieniem istniejącego systemu:
Na działającym komputerze:
- Tworzę listę zainstalowanych pakietów.
- Następnie kopię danych.
- Instaluję czysty system.
- Instaluję pakiety z listy.
- Wgrywam dane.
aptitude search ~i | grep -vE '^i A' | awk '{print $2}' > listaKod: Zaznacz cały
# aptitude search ~i |grep openoffice
i openoffice.org - full-featured office productivity suite
i A openoffice.org-base - full-featured office productivity suite --
i A openoffice.org-base-core - full-featured office productivity suite --
i A openoffice.org-calc - full-featured office productivity suite --
i A openoffice.org-common - full-featured office productivity suite --
i A openoffice.org-core - full-featured office productivity suite --
i A openoffice.org-draw - full-featured office productivity suite --
i A openoffice.org-filter-mobiledev - full-featured office productivity suite --
i A openoffice.org-impress - full-featured office productivity suite --
i A openoffice.org-java-common - full-featured office productivity suite --
i openoffice.org-l10n-pl - full-featured office productivity suite --
i A openoffice.org-math - full-featured office productivity suite --
i A openoffice.org-officebean - full-featured office productivity suite --
i A openoffice.org-report-builder-b - OpenOffice.org extension for building data
i A openoffice.org-style-galaxy - full-featured office productivity suite --
i A openoffice.org-writer - full-featured office productivity suite --Kod: Zaznacz cały
aptitude remove openoffice.org openoffice.org-l10n-plKod: Zaznacz cały
apt-get remove openoffice.org openoffice.org-l10n-plKod: Zaznacz cały
apt-get autoremoveKod: Zaznacz cały
# aptitude remove openoffice.org openoffice.org-l10n-pl -s
Reading package lists... Done
Building dependency tree
Reading extended state information
Initializing package states... Done
Reading task descriptions... Done
The following packages will be REMOVED:
libcolamd2.7.1{u} libcommons-beanutils-java{u} libcommons-collections3-java{u} libcommons-digester-java{u} libcommons-logging-java{u} libdb-je-java{u} libdb4.6-java{u} libhsqldb-java{u} libhyphen0{u} libjaxp1.3-java{u} libjline-java{u} libjtidy-java{u} liblucene2-java{u} libmysqlclient16{u} libneon27{u} libpq5{u} libraptor1{u} librasqal1{u} librdf0{u} libregexp-java{u} libservlet2.4-java{u} libwpd8c2a{u} libwpg-0.1-1{u} libwps-0.1-1{u} lp-solve{u} mysql-common{u} openoffice.org openoffice.org-base{u} openoffice.org-base-core{u} openoffice.org-calc{u} openoffice.org-common{u} openoffice.org-core{u} openoffice.org-draw{u} openoffice.org-filter-mobiledev{u} openoffice.org-impress{u} openoffice.org-java-common{u} openoffice.org-l10n-pl openoffice.org-math{u} openoffice.org-officebean{u} openoffice.org-report-builder-bin{u} openoffice.org-style-galaxy{u} openoffice.org-writer{u} ttf-opensymbol{u} uno-libs3{u} ure{u}
0 packages upgraded, 0 newly installed, 45 to remove and 0 not upgraded.
Need to get 0B of archives. After unpacking 304MB will be freed.
Do you want to continue? [Y/n/?]
Would download/install/remove packages.A jak potem użyć tej listy? Analogicznie, czyliArnVaker pisze:Czy nie lepiej byłoby do odtworzenia systemu użyć listy pakietów, która nie uwzględnia tych automatycznie zainstalowanych? Można ją uzyskać na przykład tak:Kod: Zaznacz cały
debconf-set-selections < listaKod: Zaznacz cały
aptitude search --disable-columns ~i | grep -vE '^i.A' | awk '{print $2}' > listaKod: Zaznacz cały
aptitude update && aptitude safe-upgrade && aptitude full-upgradeKod: Zaznacz cały
aptitude install $(cat lista)Witam czyli po odtworzeniu listy pakiety zostaną one doinstalowane automatycznie. ?ArnVaker pisze:Utworzenie listy zainstalowanych pakietów, nieobejmującej zainstalowanych automatycznie:
Mam pytanie, chciałem sobie przetestować twój sposób, wyedytowałem sobie plik który utworzyłem i mam coś takiego,ArnVaker pisze:Utworzenie listy zainstalowanych pakietów, nieobejmującej zainstalowanych automatycznie:Kod: Zaznacz cały
aptitude
[opcje]
(jeśli
Ten
Symualcja
Pobranie
Pytanie
Przyjęcie
format
order
width
Agresywne
Wyświetlanie
Wyświetlanie
Wyświetlanie
Wyświetlanie
[wydanie]
Wyłączenie
nazwa=wartość
Czy
zależności
fname
Przeprowadzenie
aptitude
czarownik pisze:Witam czyli po odtworzeniu listy pakiety zostaną one doinstalowane automatycznie?
Właśnie o to chodzi, żeby pakiety które obecnie zostały zainstalowane automatycznie, również zostały zainstalowane automatycznie na nowym systemie.ArnVaker pisze:Wszystkie zależności pakietów z listy zostaną zainstalowane automatycznie.
To ma być lista pakietów ze statusem "zainstalowany ręcznie", o wszystkie zależności zatroszczy się aptitude i zainstaluje je automatycznie (jak pisałem, o to właśnie chodzi).czarownik pisze:Chyba coś nie tak bo nie widzę żadnych zależności
acpi
acpi-support-base
acpid
adduser
alacarte
alsa-base
alsa-utils
apt
apt-show-versions
apt-utils
aptitude
base-files
base-passwd
bash
bsdmainutils
bsdutils
build-essential
busybox
compiz
compiz-fusion-plugins-extra
compiz-fusion-plugins-main
compiz-fusion-plugins-unsupported
compizconfig-backend-gconf
compizconfig-settings-manager
conky
console-common
console-data
console-tools
coreutils
cpio
cron
dash
debconf
debconf-i18n
debian-archive-keyring
debianutils
deborphan
dhcp3-client
dhcp3-common
dmidecode
dmz-cursor-theme
dpkg
dvd+rw-tools
e2fslibs
e2fsprogs
ed
eject
evince
file-roller
findutils
flashplugin-nonfree
fusion-icon
gamin
gcalctool
gcc-4.2-base
gcc-4.3-base
gcc-4.4-base
gconf-editor
gdm
gdm-themes
gnome-core
gnome-media
gnome-mount
gnome-power-manager
gnome-screensaver
gnome-system-monitor
gnome-system-tools
gnome-utils
gnupg
gparted
gpgv
grep
groff-base
grub-common
grub-legacy
gstreamer0.10-ffmpeg
gthumb
gtk2-engines
gtk2-engines-pixbuf
gzip
hostname
htop
ia32-libs-gtk
iceweasel
iceweasel-l10n-pl
ifupdown
info
initramfs-tools
initscripts
insserv
install-info
installation-report
iproute
iptables
iputils-ping
k3b
kadu
kadu-common
kadu-themes
less
libacl1
libattr1
libblkid1
libbz2-1.0
libc-bin
libc6
libcomerr2
libconsole
libcwidget3
libdb4.7
libdevmapper1.02.1
libept0
libgcc1
libgcrypt11
libgdbm3
libgnutls26
libgpg-error0
liblocale-gettext-perl
libncurses5
libncursesw5
libnewt0.52
libpam-modules
libpam-runtime
libpam0g
libpopt0
libreadline5
libsasl2-2
libselinux1
libsepol1
libsigc++-2.0-0c2a
libslang2
libss2
libssl0.9.8
libstdc++6
libtasn1-3
libtext-charwidth-perl
libtext-iconv-perl
libtext-wrapi18n-perl
libusb-0.1-4
libuuid1
libvolume-id1
libwrap0
libxapian15
linux-headers-2.6-sidux-amd64
linux-headers-2.6.30-2-amd64
linux-image-2.6-sidux-amd64
linux-image-2.6.30-2-amd64
locales
login
logrotate
lsb-base
lsb-release
lzma
makedev
man-db
manpages
mawk
menu
moc
module-assistant
module-init-tools
mount
myspell-pl
nano
ncurses-base
ncurses-bin
net-tools
netbase
netcat-traditional
ntfsprogs
ntp
nvidia-glx
nvidia-kernel-2.6.30-2-amd64
nvidia-kernel-2.6.31-2.slh.1-sidux-amd64
nvidia-kernel-source
nvidia-settings
openarena
openoffice.org
opera
passwd
perl-base
pm-utils
procps
qt3-qtconfig
qt4-qtconfig
readline-common
reiserfsprogs
rsyslog
sed
sensible-utils
skype
smplayer
smplayer-translations
sun-java6-plugin
synaptic
sysv-rc
sysv-rc-conf
sysvinit
sysvinit-utils
tar
tasksel
tasksel-data
testdisk
totem
traceroute
ttf-mscorefonts-installer
tzdata
unrar
unzip
usbutils
util-linux
vim-common
vim-tiny
virtualbox-3.0
w64codecs
wget
whiptail
wine-unstable
xbase-clients
xserver-xorg
yakuake
zlib1gKod: Zaznacz cały
aptitude install $(cat /root/lista)Kod: Zaznacz cały
cd /root
aptitude install $(cat lista)Kod: Zaznacz cały
--disable-columnsKod: Zaznacz cały
nieznana opcja `--disable-columns'
