markos@debian:~$ '/home/markos/Desktop/darklight-r4/configure'
checking build system type... i686-pc-linux
checking host system type... i686-pc-linux
checking target system type... i686-pc-linux
checking for -p flag to install... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for g++... no
checking for c++... no
checking for gpp... gpp
checking whether we are using the GNU C++ compiler... no
checking whether gpp accepts -g... no
checking dependency style of gpp... none
checking whether gpp supports -Wundef... no
checking whether gpp supports -Wno-long-long... no
checking whether gpp supports -Wnon-virtual-dtor... no
checking how to run the C++ preprocessor... /lib/cpp
checking whether gpp supports -O0... no
not using lib directory suffix
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking whether the gpp linker (/usr/bin/ld) supports shared libraries... yes
libtool.m4: error: problem compiling CXX test program
checking for gpp option to produce PIC...
checking if gpp supports -c -o file.o... no
checking for shl_load... (cached) no
checking for shl_load in -ldld... (cached) no
checking for dlopen... (cached) no
checking for dlopen in -ldl... (cached) yes
checking whether a program can dlopen itself... (cached) yes
checking whether a statically linked program can dlopen itself... (cached) yes
appending configuration tag "F77" to libtool
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking if C++ programs can be compiled... no
configure: error: Your Installation isn't able to compile simple C++ programs.
Check config.log for details - if you're using a Linux distribution you might miss
a package named similiar to libstd++-dev.Kod: Zaznacz cały
markos@debian:~$ dpkg -l | grep gcc
ii gcc 4.1.1-15 The GNU C compiler
ii gcc-3.3 3.3.6-15 The GNU C compiler
ii gcc-3.3-base 3.3.6-15 The GNU Compiler Collection (base package)
ii gcc-3.4 3.4.6-5 The GNU C compiler
ii gcc-3.4-base 3.4.6-5 The GNU Compiler Collection (base package)
ii gcc-4.1 4.1.1-21 The GNU C compiler
ii gcc-4.1-base 4.1.1-21 The GNU Compiler Collection (base package)
ii libgcc1 4.1.1-21 GCC support library
markos@debian:~$ dpkg -l | grep libstdc
ii libstdc++2.10-glibc2.2 2.95.4-27 The GNU stdc++ library
ii libstdc++5 3.3.6-15 The GNU Standard C++ Library v3
ii libstdc++5-3.3-dev 3.3.6-15 The GNU Standard C++ Library v3 (development
ii libstdc++6 4.1.1-21 The GNU Standard C++ Library v3
ii libstdc++6-4.1-dev 4.1.1-21 The GNU Standard C++ Library v3 (development
ii libstdc++6-dev 3.4.6-5 The GNU Standard C++ Library v3 (development
