Save & ConnectKod: Zaznacz cały
# addgroup TY netdevKod: Zaznacz cały
dmesgKod: Zaznacz cały
ifconfigKod: Zaznacz cały
iwlist wlan1 scanKod: Zaznacz cały
Użytkownik `uzytkownik' jest już członkiem grupy `netdev'.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.30-1-686 (Debian 2.6.30-6) (waldi@debian.org) (gcc version 4.3.4 (Debian 4.3.4-1) ) #1 SMP Sat Aug 15 19:11:58 UTC 2009
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000005f6e0000 (usable)
[ 0.000000] BIOS-e820: 000000005f6e0000 - 000000005f6ea000 (ACPI data)
[ 0.000000] BIOS-e820: 000000005f6ea000 - 000000005f700000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000005f700000 - 0000000060000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0006000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0008000 - 00000000f000c000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x5f6e0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E3FFF uncachable
[ 0.000000] E4000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FE0000000 write-back
[ 0.000000] 2 base 05F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 05F800000 mask FFF800000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 3790f000 - 37fef617
[ 0.000000] Allocated new RAMDISK: 00544000 - 00c24617
[ 0.000000] Move RAMDISK from 000000003790f000 - 0000000037fef616 to 00544000 - 00c24616
[ 0.000000] ACPI: RSDP 000f7a10 00014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 5f6e5e2d 0003C (v01 PTLTD RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 5f6e9e78 00084 (v02 INTEL ALVISO 06040000 LOHR 0000005F)
[ 0.000000] ACPI: DSDT 5f6e6246 03C32 (v01 INTEL ALVISO 06040000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 5f6fafc0 00040
[ 0.000000] ACPI: APIC 5f6e9efc 00068 (v01 INTEL ALVISO 06040000 LOHR 0000005F)
[ 0.000000] ACPI: BOOT 5f6e9fd8 00028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
[ 0.000000] ACPI: MCFG 5f6e9f9c 0003C (v01 INTEL ALVISO 06040000 LOHR 0000005F)
[ 0.000000] ACPI: SSDT 5f6e6064 001DE (v01 PmRef Cpu0Cst 00003001 INTL 20030224)
[ 0.000000] ACPI: SSDT 5f6e5e69 001FB (v01 PmRef CpuPm 00003000 INTL 20030224)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 638MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 0000540b10] TEXT DATA BSS ==> [0000100000 - 0000540b10]
[ 0.000000] #4 [000009f800 - 0000100000] BIOS reserved ==> [000009f800 - 0000100000]
[ 0.000000] #5 [0000541000 - 00005431b0] BRK ==> [0000541000 - 00005431b0]
[ 0.000000] #6 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #7 [0000544000 - 0000c24617] NEW RAMDISK ==> [0000544000 - 0000c24617]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0005f6e0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0005f6e0
[ 0.000000] On node 0 totalpages: 390767
[ 0.000000] free_area_init_node: node 0, pgdat c040bd40, node_mem_map c1000200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 1278 pages used for memmap
[ 0.000000] HighMem zone: 162276 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000dc000
[ 0.000000] PM: Registered nosave memory: 00000000000dc000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 68000000 (gap: 60000000:80000000)
[ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 11 pages at c1bf7000, static data 22172 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 387713
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.30-1-686 root=UUID=2d7ffb3d-a00e-44fc-8091-d5a63f4346ed ro quiet
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] NR_IRQS:1280
[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1496.574 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.004000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Initializing HighMem for node 0 (000377fe:0005f6e0)
[ 0.004000] Memory: 1537592k/1563520k available (2173k kernel code, 24572k reserved, 1151k data, 320k init, 654216k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xffe16000 - 0xfffff000 (1956 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.004000] .init : 0xc0446000 - 0xc0496000 ( 320 kB)
[ 0.004000] .data : 0xc031f5d5 - 0xc043f2f0 (1151 kB)
[ 0.004000] .text : 0xc0100000 - 0xc031f5d5 (2173 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004022] Calibrating delay loop (skipped), value calculated using timer frequency.. 2993.14 BogoMIPS (lpj=5986296)
[ 0.004087] Security Framework initialized
[ 0.004099] SELinux: Disabled at boot.
[ 0.004122] Mount-cache hash table entries: 512
[ 0.004323] Initializing cgroup subsys ns
[ 0.004331] Initializing cgroup subsys cpuacct
[ 0.004337] Initializing cgroup subsys devices
[ 0.004340] Initializing cgroup subsys freezer
[ 0.004343] Initializing cgroup subsys net_cls
[ 0.004374] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.004378] CPU: L2 cache: 1024K
[ 0.004387] Intel machine check architecture supported.
[ 0.004392] Intel machine check reporting enabled on CPU#0.
[ 0.004408] Checking 'hlt' instruction... OK.
[ 0.020393] SMP alternatives: switching to UP code
[ 0.024402] ACPI: Core revision 20090320
[ 0.033929] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.073627] CPU0: Intel(R) Celeron(R) M processor 1.50GHz stepping 08
[ 0.076001] Brought up 1 CPUs
[ 0.076001] Total of 1 processors activated (2993.14 BogoMIPS).
[ 0.076001] CPU0 attaching NULL sched-domain.
[ 0.076001] net_namespace: 1088 bytes
[ 0.076001] Booting paravirtualized kernel on bare hardware
[ 0.076001] regulator: core version 0.5
[ 0.076001] NET: Registered protocol family 16
[ 0.076001] ACPI: bus type pci registered
[ 0.076001] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.076001] PCI: MCFG area at e0000000 reserved in E820
[ 0.076001] PCI: Using MMCONFIG for extended config space
[ 0.076001] PCI: Using configuration type 1 for base access
[ 0.076001] bio: create slab <bio-0> at 0
[ 0.076001] ACPI: EC: Look up EC in DSDT
[ 0.077925] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.100022] ACPI: EC: GPE storm detected, transactions will use polling mode
[ 0.180080] ACPI: Interpreter enabled
[ 0.180085] ACPI: (supports S0 S3 S4 S5)
[ 0.180110] ACPI: Using IOAPIC for interrupt routing
[ 0.413329] ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[ 0.413332] ACPI: EC: driver started in poll mode
[ 0.413650] ACPI: No dock devices found.
[ 0.413665] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.413792] pci 0000:00:02.0: reg 10 32bit mmio: [0xb0080000-0xb00fffff]
[ 0.413799] pci 0000:00:02.0: reg 14 io port: [0x1800-0x1807]
[ 0.413805] pci 0000:00:02.0: reg 18 32bit mmio: [0xc0000000-0xcfffffff]
[ 0.413812] pci 0000:00:02.0: reg 1c 32bit mmio: [0xb0000000-0xb003ffff]
[ 0.413850] pci 0000:00:02.1: reg 10 32bit mmio: [0x000000-0x07ffff]
[ 0.413971] pci 0000:00:1d.0: reg 20 io port: [0x1820-0x183f]
[ 0.414039] pci 0000:00:1d.1: reg 20 io port: [0x1840-0x185f]
[ 0.414107] pci 0000:00:1d.2: reg 20 io port: [0x1860-0x187f]
[ 0.414175] pci 0000:00:1d.3: reg 20 io port: [0x1880-0x189f]
[ 0.414246] pci 0000:00:1d.7: reg 10 32bit mmio: [0xb0040000-0xb00403ff]
[ 0.414312] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.414319] pci 0000:00:1d.7: PME# disabled
[ 0.414431] pci 0000:00:1e.2: reg 10 io port: [0x1c00-0x1cff]
[ 0.414441] pci 0000:00:1e.2: reg 14 io port: [0x18c0-0x18ff]
[ 0.414450] pci 0000:00:1e.2: reg 18 32bit mmio: [0xb0040800-0xb00409ff]
[ 0.414460] pci 0000:00:1e.2: reg 1c 32bit mmio: [0xb0040400-0xb00404ff]
[ 0.414501] pci 0000:00:1e.2: PME# supported from D0 D3hot D3cold
[ 0.414507] pci 0000:00:1e.2: PME# disabled
[ 0.414549] pci 0000:00:1e.3: reg 10 io port: [0x2400-0x24ff]
[ 0.414558] pci 0000:00:1e.3: reg 14 io port: [0x2000-0x207f]
[ 0.414611] pci 0000:00:1e.3: PME# supported from D0 D3hot D3cold
[ 0.414617] pci 0000:00:1e.3: PME# disabled
[ 0.414713] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.414721] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.414727] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH6 GPIO
[ 0.414732] pci 0000:00:1f.0: LPC Generic IO decode 1 PIO at 0680-06ff
[ 0.414738] pci 0000:00:1f.0: LPC Generic IO decode 2 PIO at 1200-120f
[ 0.414770] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
[ 0.414779] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
[ 0.414788] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
[ 0.414798] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
[ 0.414807] pci 0000:00:1f.1: reg 20 io port: [0x1810-0x181f]
[ 0.414891] pci 0000:00:1f.3: reg 20 io port: [0x20a0-0x20bf]
[ 0.414966] pci 0000:06:05.0: reg 10 32bit mmio: [0xb0100000-0xb0101fff]
[ 0.415058] pci 0000:06:07.0: reg 10 io port: [0x3000-0x30ff]
[ 0.415069] pci 0000:06:07.0: reg 14 32bit mmio: [0xb0102000-0xb01020ff]
[ 0.415132] pci 0000:06:07.0: supports D1 D2
[ 0.415135] pci 0000:06:07.0: PME# supported from D1 D2 D3hot D3cold
[ 0.415142] pci 0000:06:07.0: PME# disabled
[ 0.415194] pci 0000:06:09.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.415222] pci 0000:06:09.0: supports D1 D2
[ 0.415226] pci 0000:06:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.415232] pci 0000:06:09.0: PME# disabled
[ 0.415281] pci 0000:00:1e.0: transparent bridge
[ 0.415287] pci 0000:00:1e.0: bridge io port: [0x3000-0x3fff]
[ 0.415294] pci 0000:00:1e.0: bridge 32bit mmio: [0xb0100000-0xb01fffff]
[ 0.415336] pci_bus 0000:00: on NUMA node 0
[ 0.415344] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.415595] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCIB._PRT]
[ 0.421399] ACPI: PCI Interrupt Link [LNKA] (IRQs *10 11)
[ 0.421525] ACPI: PCI Interrupt Link [LNKB] (IRQs 10 *11)
[ 0.421647] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 *11)
[ 0.421766] ACPI: PCI Interrupt Link [LNKD] (IRQs 10 *11)
[ 0.421886] ACPI: PCI Interrupt Link [LNKE] (IRQs *10 11)
[ 0.422008] ACPI: PCI Interrupt Link [LNKF] (IRQs *10 11)
[ 0.422126] ACPI: PCI Interrupt Link [LNKG] (IRQs 10 11) *0, disabled.
[ 0.422247] ACPI: PCI Interrupt Link [LNKH] (IRQs 10 *11)
[ 0.422586] PCI: Using ACPI for IRQ routing
[ 0.422974] hpet clockevent registered
[ 0.422979] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.422988] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.422994] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.428126] pnp: PnP ACPI init
[ 0.428138] ACPI: bus type pnp registered
[ 0.484768] pnp: PnP ACPI: found 8 devices
[ 0.484771] ACPI: ACPI bus type pnp unregistered
[ 0.484776] PnPBIOS: Disabled by ACPI PNP
[ 0.484791] system 00:04: ioport range 0x800-0x80f has been reserved
[ 0.484795] system 00:04: ioport range 0x1000-0x107f has been reserved
[ 0.484799] system 00:04: ioport range 0x1180-0x11bf has been reserved
[ 0.484804] system 00:04: ioport range 0x1200-0x1200 has been reserved
[ 0.484808] system 00:04: ioport range 0x1204-0x1204 has been reserved
[ 0.484813] system 00:04: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.484817] system 00:04: iomem range 0xf0000000-0xf0003fff has been reserved
[ 0.484822] system 00:04: iomem range 0xf0004000-0xf0004fff has been reserved
[ 0.484827] system 00:04: iomem range 0xf0005000-0xf0005fff has been reserved
[ 0.484831] system 00:04: iomem range 0xf0008000-0xf000bfff has been reserved
[ 0.484836] system 00:04: iomem range 0xfec18000-0xfec180ff has been reserved
[ 0.484840] system 00:04: iomem range 0xfed20000-0xfed8ffff has been reserved
[ 0.519843] pci 0000:06:09.0: CardBus bridge, secondary bus 0000:07
[ 0.519847] pci 0000:06:09.0: IO window: 0x003400-0x0034ff
[ 0.519854] pci 0000:06:09.0: IO window: 0x003800-0x0038ff
[ 0.519861] pci 0000:06:09.0: PREFETCH window: 0x68000000-0x6bffffff
[ 0.519868] pci 0000:06:09.0: MEM window: 0x70000000-0x73ffffff
[ 0.519875] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:06
[ 0.519880] pci 0000:00:1e.0: IO window: 0x3000-0x3fff
[ 0.519888] pci 0000:00:1e.0: MEM window: 0xb0100000-0xb01fffff
[ 0.519894] pci 0000:00:1e.0: PREFETCH window: 0x00000068000000-0x0000006bffffff
[ 0.519914] pci 0000:00:1e.0: setting latency timer to 64
[ 0.519931] pci 0000:06:09.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 0.519939] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.519943] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.519947] pci_bus 0000:06: resource 0 io: [0x3000-0x3fff]
[ 0.519951] pci_bus 0000:06: resource 1 mem: [0xb0100000-0xb01fffff]
[ 0.519955] pci_bus 0000:06: resource 2 pref mem [0x68000000-0x6bffffff]
[ 0.519958] pci_bus 0000:06: resource 3 io: [0x00-0xffff]
[ 0.519962] pci_bus 0000:06: resource 4 mem: [0x000000-0xffffffff]
[ 0.519966] pci_bus 0000:07: resource 0 io: [0x3400-0x34ff]
[ 0.519969] pci_bus 0000:07: resource 1 io: [0x3800-0x38ff]
[ 0.519973] pci_bus 0000:07: resource 2 pref mem [0x68000000-0x6bffffff]
[ 0.519977] pci_bus 0000:07: resource 3 mem: [0x70000000-0x73ffffff]
[ 0.520042] NET: Registered protocol family 2
[ 0.520156] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.520551] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.521756] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.522594] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.522599] TCP reno registered
[ 0.522806] NET: Registered protocol family 1
[ 0.522890] Trying to unpack rootfs image as initramfs...
[ 0.808161] Freeing initrd memory: 7041k freed
[ 0.816173] Simple Boot Flag at 0x37 set to 0x1
[ 0.816709] audit: initializing netlink socket (disabled)
[ 0.816729] type=2000 audit(1251922556.815:1): initialized
[ 0.817022] highmem bounce pool size: 64 pages
[ 0.817028] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.817116] VFS: Disk quotas dquot_6.5.2
[ 0.817162] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.817231] msgmni has been set to 1740
[ 0.817422] alg: No test for stdrng (krng)
[ 0.817503] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.817508] io scheduler noop registered
[ 0.817510] io scheduler anticipatory registered
[ 0.817513] io scheduler deadline registered
[ 0.817532] io scheduler cfq registered (default)
[ 0.817554] pci 0000:00:02.0: Boot video device
[ 0.818183] isapnp: Scanning for PnP cards...
[ 0.923972] Switched to high resolution mode on CPU 0
[ 1.172111] isapnp: No Plug & Play device found
[ 1.175489] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.176062] serial 0000:00:1e.3: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 1.176070] serial 0000:00:1e.3: PCI INT B disabled
[ 1.177867] brd: module loaded
[ 1.177984] PNP: PS/2 Controller [PNP0303:KBD0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.178352] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 1.178431] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.178438] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.178442] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.178446] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.178450] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.178634] mice: PS/2 mouse device common for all mice
[ 1.178755] rtc_cmos 00:05: RTC can wake from S4
[ 1.178918] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.178954] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.179086] cpuidle: using governor ladder
[ 1.179089] cpuidle: using governor menu
[ 1.179095] No iBFT detected.
[ 1.179534] TCP cubic registered
[ 1.179578] NET: Registered protocol family 10
[ 1.180172] lo: Disabled Privacy Extensions
[ 1.180719] Mobile IPv6
[ 1.180724] NET: Registered protocol family 17
[ 1.180734] Using IPI No-Shortcut mode
[ 1.180976] registered taskstats version 1
[ 1.181151] rtc_cmos 00:05: setting system clock to 2009-09-02 20:15:58 UTC (1251922558)
[ 1.181224] Freeing unused kernel memory: 320k freed
[ 1.181466] Write protecting the kernel text: 2176k
[ 1.181489] Write protecting the kernel read-only data: 784k
[ 1.186629] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.892122] thermal LNXTHERM:01: registered as thermal_zone0
[ 1.892136] ACPI: Thermal Zone [TZS0] (67 C)
[ 2.124112] thermal LNXTHERM:02: registered as thermal_zone1
[ 2.124122] ACPI: Thermal Zone [TZS1] (50 C)
[ 2.183937] Linux agpgart interface v0.103
[ 2.216616] Uniform Multi-Platform E-IDE driver
[ 2.242698] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:02/input/input1
[ 2.242711] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.253415] agpgart-intel 0000:00:00.0: Intel 915GM Chipset
[ 2.253774] agpgart-intel 0000:00:00.0: detected 7932K stolen memory
[ 2.257186] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[ 2.300288] 8139too Fast Ethernet driver 0.9.28
[ 2.300344] 8139too 0000:06:07.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 2.301711] eth0: RealTek RTL8139 at 0x3000, 00:0a:e4:f3:0e:e1, IRQ 20
[ 2.301714] eth0: Identified 8139 chip type 'RTL-8100B/8139D'
[ 2.305022] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.312884] usbcore: registered new interface driver usbfs
[ 2.312931] usbcore: registered new interface driver hub
[ 2.312994] usbcore: registered new device driver usb
[ 2.318418] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.318466] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 2.318486] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.318491] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.318546] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 2.322463] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.322471] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 2.322493] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xb0040000
[ 2.447710] b43-pci-bridge 0000:06:05.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 2.479803] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.479847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.479850] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.479855] usb usb1: Product: EHCI Host Controller
[ 2.479858] usb usb1: Manufacturer: Linux 2.6.30-1-686 ehci_hcd
[ 2.479861] usb usb1: SerialNumber: 0000:00:1d.7
[ 2.479959] usb usb1: configuration #1 chosen from 1 choice
[ 2.480045] hub 1-0:1.0: USB hub found
[ 2.480057] hub 1-0:1.0: 8 ports detected
[ 2.480354] piix 0000:00:1f.1: IDE controller (0x8086:0x266f rev 0x03)
[ 2.480377] PIIX_IDE 0000:00:1f.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 2.480390] piix 0000:00:1f.1: IDE port disabled
[ 2.480404] piix 0000:00:1f.1: not 100% native mode: will probe irqs later
[ 2.480412] ide0: BM-DMA at 0x1810-0x1817
[ 2.480421] Probing IDE interface ide0...
[ 2.493619] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.544218] ssb: Sonics Silicon Backplane found on PCI device 0000:06:05.0
[ 2.768311] hda: SAMSUNG HM160HC, ATA DISK drive
[ 3.608006] hdb: PHILIPS DVD+/-RW SDVD8441, ATAPI CD/DVD-ROM drive
[ 3.608065] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 3.608150] hda: UDMA/100 mode selected
[ 3.608241] hdb: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 3.608475] hdb: UDMA/33 mode selected
[ 3.608687] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 3.669198] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 3.669210] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.669216] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.669250] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 3.669281] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001820
[ 3.669336] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.669340] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.669343] usb usb2: Product: UHCI Host Controller
[ 3.669346] usb usb2: Manufacturer: Linux 2.6.30-1-686 uhci_hcd
[ 3.669350] usb usb2: SerialNumber: 0000:00:1d.0
[ 3.669431] usb usb2: configuration #1 chosen from 1 choice
[ 3.669469] hub 2-0:1.0: USB hub found
[ 3.669478] hub 2-0:1.0: 2 ports detected
[ 3.690811] SCSI subsystem initialized
[ 3.690853] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 3.690864] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.690869] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.690914] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 3.690956] uhci_hcd 0000:00:1d.1: irq 17, io base 0x00001840
[ 3.691009] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.691013] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.691016] usb usb3: Product: UHCI Host Controller
[ 3.691019] usb usb3: Manufacturer: Linux 2.6.30-1-686 uhci_hcd
[ 3.691022] usb usb3: SerialNumber: 0000:00:1d.1
[ 3.691099] usb usb3: configuration #1 chosen from 1 choice
[ 3.691137] hub 3-0:1.0: USB hub found
[ 3.691146] hub 3-0:1.0: 2 ports detected
[ 3.691262] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 3.691270] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.691275] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.691304] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 3.691341] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001860
[ 3.691383] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.691386] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.691390] usb usb4: Product: UHCI Host Controller
[ 3.691393] usb usb4: Manufacturer: Linux 2.6.30-1-686 uhci_hcd
[ 3.691396] usb usb4: SerialNumber: 0000:00:1d.2
[ 3.691459] usb usb4: configuration #1 chosen from 1 choice
[ 3.691491] hub 4-0:1.0: USB hub found
[ 3.691500] hub 4-0:1.0: 2 ports detected
[ 3.691614] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 3.691622] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 3.691627] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 3.691652] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 3.691687] uhci_hcd 0000:00:1d.3: irq 19, io base 0x00001880
[ 3.691727] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.691731] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.691734] usb usb5: Product: UHCI Host Controller
[ 3.691737] usb usb5: Manufacturer: Linux 2.6.30-1-686 uhci_hcd
[ 3.691741] usb usb5: SerialNumber: 0000:00:1d.3
[ 3.691799] usb usb5: configuration #1 chosen from 1 choice
[ 3.691832] hub 5-0:1.0: USB hub found
[ 3.691839] hub 5-0:1.0: 2 ports detected
[ 3.754236] libata version 3.00 loaded.
[ 3.769164] ide-cd driver 5.00
[ 3.775666] ide-gd driver 1.18
[ 3.777468] ide-cd: hdb: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
[ 3.777476] Uniform CD-ROM driver Revision: 3.20
[ 3.789105] hda: max request size: 512KiB
[ 3.791050] hda: 312581808 sectors (160041 MB) w/8192KiB Cache, CHS=19457/255/63
[ 3.793029] hda: cache flushes supported
[ 3.793094] hda: hda1 hda2 < hda5 hda6 hda7 hda8 >
[ 4.443237] PM: Starting manual resume from disk
[ 4.485659] EXT4-fs: barriers enabled
[ 4.497158] kjournald2 starting: pid 911, dev hda7:8, commit interval 5 seconds
[ 4.497172] EXT4-fs: delayed allocation enabled
[ 4.497174] EXT4-fs: file extents enabled
[ 4.498350] EXT4-fs: mballoc enabled
[ 4.498368] EXT4-fs: mounted filesystem hda7 with ordered data mode
[ 5.642361] udev: starting version 141
[ 5.977786] ACPI: WMI: Mapper loaded
[ 5.980885] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 5.980894] ACPI: Power Button [PWRF]
[ 5.980978] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input3
[ 5.989397] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 6.040136] ACPI: Lid Switch [LID0]
[ 6.040251] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input5
[ 6.040310] ACPI: Sleep Button [SLPB]
[ 6.040469] Marking TSC unstable due to TSC halts in idle
[ 6.040544] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 6.040593] processor ACPI_CPU:00: registered as cooling_device0
[ 6.040602] ACPI: Processor [CPU0] (supports 8 throttling states)
[ 6.096242] ACPI: AC Adapter [ADP1] (on-line)
[ 6.573403] Synaptics Touchpad, model: 1, fw: 6.2, id: 0x12a0b1, caps: 0xa04713/0x204000
[ 6.603486] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input6
[ 6.920161] Clocksource tsc unstable (delta = -125318919 ns)
[ 8.496322] ACPI: Battery Slot [BAT0] (battery present)
[ 8.569203] acer-wmi: Acer Laptop ACPI-WMI Extras
[ 8.583670] yenta_cardbus 0000:06:09.0: CardBus bridge found [1025:006a]
[ 8.583699] yenta_cardbus 0000:06:09.0: Using CSCINT to route CSC interrupts to PCI
[ 8.583702] yenta_cardbus 0000:06:09.0: Routing CardBus interrupts to PCI
[ 8.583709] yenta_cardbus 0000:06:09.0: TI: mfunc 0x00001022, devctl 0x44
[ 8.613284] intel_rng: FWH not detected
[ 8.617308] i801_smbus 0000:00:1f.3: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 8.669354] cfg80211: Using static regulatory domain info
[ 8.669358] cfg80211: Regulatory domain: US
[ 8.669361] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.669365] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 8.669369] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 8.669373] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 8.669377] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 8.669380] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 8.669384] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 8.801862] Intel ICH Modem 0000:00:1e.3: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 8.801898] Intel ICH Modem 0000:00:1e.3: setting latency timer to 64
[ 8.814064] yenta_cardbus 0000:06:09.0: ISA IRQ mask 0x0cf8, PCI irq 22
[ 8.814072] yenta_cardbus 0000:06:09.0: Socket status: 30000006
[ 8.814076] pci_bus 0000:06: Raising subordinate bus# of parent bus (#06) from #06 to #0a
[ 8.814087] yenta_cardbus 0000:06:09.0: pcmcia: parent PCI bridge I/O window: 0x3000 - 0x3fff
[ 8.814092] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: clean.
[ 8.814359] yenta_cardbus 0000:06:09.0: pcmcia: parent PCI bridge Memory window: 0xb0100000 - 0xb01fffff
[ 8.814363] yenta_cardbus 0000:06:09.0: pcmcia: parent PCI bridge Memory window: 0x68000000 - 0x6bffffff
[ 8.904202] MC'97 1 converters and GPIO not ready (0xff00)
[ 8.905209] Intel ICH 0000:00:1e.2: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 8.905275] Intel ICH 0000:00:1e.2: setting latency timer to 64
[ 9.028280] cfg80211: Calling CRDA for country: US
[ 9.031365] Registered led device: acer-wmi::mail
[ 9.149670] b43-phy0: Broadcom 4318 WLAN found (core revision 9)
[ 9.160265] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 9.162004] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
[ 9.162742] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 9.163351] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 9.164222] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 9.320762] phy0: Selected rate control algorithm 'minstrel'
[ 9.321541] Broadcom 43xx driver loaded [ Features: PMLR, Firmware-ID: FW13 ]
[ 9.732037] intel8x0_measure_ac97_clock: measured 55320 usecs (2666 samples)
[ 9.732041] intel8x0: clocking to 48000
[ 10.166659] Adding 530104k swap on /dev/hda6. Priority:-1 extents:1 across:530104k
[ 10.294088] EXT4 FS on hda7, internal journal on hda7:8
[ 11.201244] loop: module loaded
[ 12.177393] eth0: link down
[ 12.177715] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.600261] lp: driver loaded but no devices found
[ 16.619403] ppdev: user-space parallel port driver
[ 19.794783] [drm] Initialized drm 1.1.0 20060810
[ 19.812229] pci 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 19.812237] pci 0000:00:02.0: setting latency timer to 64
[ 19.816210] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 20.091214] input: b43-phy0 as /devices/virtual/input/input7
[ 20.140037] b43 ssb0:0: firmware: requesting b43/ucode5.fw
[ 20.175993] b43 ssb0:0: firmware: requesting b43/pcm5.fw
[ 20.195092] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
[ 20.216212] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
[ 20.348030] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 20.388695] Registered led device: b43-phy0::tx
[ 20.388718] Registered led device: b43-phy0::rx
[ 20.388741] Registered led device: b43-phy0::radio
[ 20.388933] b43-phy0: Radio turned on by software
[ 20.389355] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 21.976385] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 1
[ 22.176028] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 2
[ 22.376166] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 3
[ 22.576164] wlan0: direct probe to AP 00:25:86:c3:46:a4 timed out
[ 32.348131] CPU0 attaching NULL sched-domain.
[ 32.348185] CPU0 attaching NULL sched-domain.
[ 34.659270] [drm:drm_wait_vblank] *ERROR* failed to acquire vblank counter, -22
[ 37.916951] nepomukservices[3063]: segfault at 4 ip b7d8d652 sp bffd2b60 error 4 in libQtCore.so.4.5.2[b7d3a000+234000]
[ 94.792555] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 1
[ 94.992040] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 2
[ 95.192052] wlan0: direct probe to AP 00:25:86:c3:46:a4 try 3
[ 95.392036] wlan0: direct probe to AP 00:25:86:c3:46:a4 timed out
[ 236.416685] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 236.416949] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 247.168169] eth0: no IPv6 routers present
debian:/home/uzytkownik# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0a:e4:f3:0e:e1
inet addr:192.168.1.11 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::20a:e4ff:fef3:ee1/64 Scope:Link
RX packets:621 errors:0 dropped:0 overruns:0 frame:0
TX packets:775 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:393950 (384.7 KiB) TX bytes:212820 (207.8 KiB)
Interrupt:20 Base address:0x3000
lo Link encap:Local Loopback
RX packets:178 errors:0 dropped:0 overruns:0 frame:0
TX packets:178 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11914 (11.6 KiB) TX bytes:11914 (11.6 KiB)
wlan0 Link encap:Ethernet HWaddr 00:14:a4:80:e9:5b
wmaster0 Link encap:UNSPEC HWaddr 00-14-A4-80-E9-5B-65-74-00-00-00-00-00-00-00-00
UP RUNNING MTU:0 Metric:1
RX packets:2312 errors:0 dropped:0 overruns:0 frame:0
TX packets:2482 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1918922 (1.8 MiB) TX bytes:747603 (730.0 KiB)
RX packets:256 errors:0 dropped:0 overruns:0 frame:0
TX packets:256 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17054 (16.6 KiB) TX bytes:17054 (16.6 KiB)
# iwlist wlan0 scan
