Zrzuty z HTOP i sysv-rc-conf.
 Może ktoś podpowie co jest zbędne i co jeszcze można wyłączyć?
Moje środowisko to GNOME/OpenBox.
A to mój xorg.conf:
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "Module"
	Load	"glx"
	Load	"dri"
	Load	"extmod"
	Load	"xtrap"
	Load	"record"
	Load	"GLcore"
	Load	"dbe"
	Load	"ddc"
EndSection
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver		"kbd"
	Option		"XkbRules"	"xorg"
	Option		"XkbModel"	"pc105"
	Option		"XkbLayout"	"pl"
EndSection
	Identifier	"Configured Mouse"
	Driver		"mouse"
EndSection
Section "Device"
	BoardName	"915 GM"
	BusID	"0:2:0"
	Driver	"intel"
	Option	"AccelMethod" "xaa"
#######	Option	"MigrationHeuristic" "greedy"
	Identifier	"Card0"
	VideoRam	131072
	VendorName   "intel"
EndSection
Section "Monitor"
	#DisplaySize	  330   210	# mm
	Identifier   "Monitor0"
	VendorName   "CMO"
	ModelName    "1504"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Dri"
    Mode        0666
EndSection
#Section "Extensions"
#	Option "Composite" "Enable"
#	Option "RENDER" "Enable"
#EndSection
