Po podłączeniu pendrive dmesg pięknie pokazuje:
[ 8526.936022] usb 1-5: new high speed USB device using ehci_hcd and address 6
[ 8527.068948] usb 1-5: New USB device found, idVendor=133c, idProduct=a099
[ 8527.068956] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8527.068959] usb 1-5: Product: FlashDrive with MP3 Player
[ 8527.068962] usb 1-5: Manufacturer: AVID Electronics Corp.
[ 8527.068965] usb 1-5: SerialNumber: 000100000000
[ 8527.069081] usb 1-5: configuration #1 chosen from 1 choice
[ 8527.354980] Initializing USB Mass Storage driver...
[ 8527.362187] scsi2 : SCSI emulation for USB Mass Storage devices
[ 8527.362603] usbcore: registered new interface driver usb-storage
[ 8527.362608] USB Mass Storage support registered.
[ 8527.374407] usb-storage: device found at 6
[ 8527.374412] usb-storage: waiting for device to settle before scanning
[ 8532.372182] usb-storage: device scan complete
[ 8532.395554] scsi 2:0:0:0: Direct-Access AVID NAND Flash 1.00 PQ : 0 ANSI: 0 CCS
[ 8532.406330] Driver 'sd' needs updating - please use bus_type methods
[ 8532.412065] sd 2:0:0:0: [sda] 980992 2048-byte hardware sectors: (2.00 GB/1.8 7 GiB)
[ 8532.412509] sd 2:0:0:0: [sda] Write Protect is off
[ 8532.412513] sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 8532.412517] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 8532.414021] sd 2:0:0:0: [sda] 980992 2048-byte hardware sectors: (2.00 GB/1.8 7 GiB)
[ 8532.414425] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 8532.414431] sda:
[ 8532.534300] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 8714.662558] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 8715.486803] kjournald starting. Commit interval 5 seconds
[ 8715.596740] EXT3 FS on hdb1, internal journal
[ 8715.596752] EXT3-fs: mounted filesystem with ordered data mode.
[ 8715.888516] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 8735.293302] FAT: Filesystem panic (dev sda)
[ 8735.293309] invalid access to FAT (entry 0x55555555)
[ 8735.293313] File system has been set read-only
[ 8735.293484] FAT: Filesystem panic (dev sda)
[ 8735.293486] invalid access to FAT (entry 0x55555555)
/dev/hda1 on /media/disk type vfat (rw,nosuid,nodev,uhelper=hal,shortname=lower,uid=1000)
/dev/sda on /media/disk-1 type vfat (rw,nosuid,nodev,uhelper=hal,shortname=lower,uid=1000)
Jak zatrzymam hala i zamontuję ręcznie pendrive to działa w trybie zapis/odczyt.
Mam odpowiedni wpis w /etc/fstab:
/dev/sda /mnt/dysk_usb vfat rw,users,sync,noatime,nodev,noauto,noexec,umask=0,iocharset=iso8859-2,codepage=852 0 0
/20-storage-methods.fdi:
<match key="volume.fstype" string="vfat">
<match key="/org/freedesktop/Hal/devices/computer:system.kernel.name" string="Linux">
<append key="volume.mount.valid_options" type="strlist">shortname=</append>
<append key="volume.mount.valid_options" type="strlist">codepage=</append>
<append key="volume.mount.valid_options" type="strlist">iocharset=</append>
<append key="volume.mount.valid_options" type="strlist">umask=</append>
<append key="volume.mount.valid_options" type="strlist">dmask=</append>
<append key="volume.mount.valid_options" type="strlist">fmask=</append>
<append key="volume.mount.valid_options" type="strlist">uid=</append>
<append key="volume.mount.valid_options" type="strlist">flush</append>
</match>
<append key="volume.mount.valid_options" type="strlist">utf8</append>
locale LANG=pl_PL
System: Debian squeeze
jądro: 2.6.30-1-686
Podejrzewam, brak jakiś wpisów w plikach konfiguracji hala. Czyli całą tą "automagię". Już raz musiałem ręcznie poprawiać w Lennym wtedy wcale nie chciał montować vfat. Niestety teraz nie pamiętam dokładnie co zmieniałem.
Jeśli ma ktoś jakieś pomysły to proszę o pomoc.
