Mam taki problem: używam teraz Squeeze AMD64. Przytrafia mi się zawieszanie systemu przez napęd optyczny ATAPI. Objawy są takie, że nagle wszystko się zatrzymuje, kursorem da się ruszyć raz na 30 sekund, laptopa ciężko też wyłączyć; poniżej informacje o napędzie i stosowne kawałki logów:
sudo dmesg | grep hda
[ 2.304159] hda: TSSTcorpCD/DVDW TS-L632D, ATAPI CD/DVD-ROM drive
[ 2.976109] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 2.976829] hda: UDMA/33 mode selected
[ 4.088050] ide-cd: hda: ATAPI 24X DVD-ROM DVD-R/RAM CD-R/RW drive, 2048kB Cache
[ 8.764084] hda_codec: Unknown model for ALC861, trying auto-probe from BIOS...Kod: Zaznacz cały
sudo cat /var/log/syslog | grep hda
Aug 22 12:08:23 feynman kernel: [ 1656.065014] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:08:23 feynman kernel: [ 1656.065021] hda: possibly failed opcode: 0xa0
Aug 22 12:08:23 feynman kernel: [ 1656.065026] hda: Strange, packet command initiated yet DRQ isn't asserted
Aug 22 12:08:33 feynman kernel: [ 1661.120014] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:08:33 feynman kernel: [ 1661.120021] hda: possibly failed opcode: 0xa0
Aug 22 12:08:33 feynman kernel: [ 1661.120028] hda: drive not ready for command
Aug 22 12:08:33 feynman kernel: [ 1666.124010] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:08:33 feynman kernel: [ 1666.124014] hda: possibly failed opcode: 0xa0
Aug 22 12:08:33 feynman kernel: [ 1666.124017] hda: drive not ready for command
Aug 22 12:08:38 feynman kernel: [ 1671.128011] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:08:38 feynman kernel: [ 1671.128015] hda: possibly failed opcode: 0xa0
Aug 22 12:08:38 feynman kernel: [ 1671.128020] hda: drive not ready for command
Aug 22 12:08:43 feynman kernel: [ 1676.132012] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:08:43 feynman kernel: [ 1676.132017] hda: possibly failed opcode: 0xa0
Aug 22 12:08:43 feynman kernel: [ 1676.132021] hda: drive not ready for command
Aug 22 12:09:23 feynman kernel: [ 1681.144014] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:09:23 feynman kernel: [ 1681.144021] hda: possibly failed opcode: 0xa0
Aug 22 12:09:23 feynman kernel: [ 1681.144027] hda: drive not ready for command
Aug 22 12:09:23 feynman kernel: [ 1686.148010] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:09:23 feynman kernel: [ 1686.148013] hda: possibly failed opcode: 0xa0
Aug 22 12:09:23 feynman kernel: [ 1686.148017] hda: drive not ready for command
Aug 22 12:09:23 feynman kernel: [ 1691.152009] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:09:23 feynman kernel: [ 1691.152013] hda: possibly failed opcode: 0xa0
Aug 22 12:09:23 feynman kernel: [ 1691.152016] hda: drive not ready for command
Aug 22 12:09:23 feynman kernel: [ 1691.152020] ide-cd: hda: weird block size 0
Aug 22 12:09:23 feynman kernel: [ 1691.152022] ide-cd: hda: default to 2kb block sizeKod: Zaznacz cały
Aug 22 12:10:28 feynman shutdown[4908]: shutting down for system reboot
Aug 22 12:10:33 feynman kernel: [ 1786.724015] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:10:38 feynman kernel: [ 1786.724022] hda: possibly failed opcode: 0xa0
Aug 22 12:10:38 feynman kernel: [ 1786.724029] hda: drive not ready for command
Aug 22 12:10:38 feynman kernel: [ 1791.728014] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:10:38 feynman kernel: [ 1791.728020] hda: possibly failed opcode: 0xa0
Aug 22 12:10:38 feynman kernel: [ 1791.728024] hda: drive not ready for command
Aug 22 12:10:38 feynman kernel: [ 1791.728682] ACPI Exception (evregion-0422): AE_TIME, Returned by Handler for [EmbeddedControl] [20090320]
Aug 22 12:10:38 feynman kernel: [ 1791.728704] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SBRG.EC0_.ECCM] (Node ffff880077bd3210), AE
_TIME
Aug 22 12:10:38 feynman kernel: [ 1791.728782] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.SBRG.EC0_.RDC3] (Node ffff880077bd3fd0), AE
_TIME
Aug 22 12:10:43 feynman kernel: [ 1791.728836] ACPI Error (psparse-0537): Method parse/execution failed [\ECIO] (Node ffff880077bd3ed0), AE_TIME
Aug 22 12:10:43 feynman kernel: [ 1791.728886] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.BAT0._STA] (Node ffff880077bd74b0), AE_TIME
Aug 22 12:10:43 feynman kernel: [ 1791.728937] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.PCI0.BAT0._BST] (Node ffff880077bd7470), AE_TIME
Aug 22 12:10:43 feynman kernel: [ 1791.728996] ACPI Exception (battery-0385): AE_TIME, Evaluating _BST [20090320]
Aug 22 12:10:43 feynman kernel: [ 1796.732013] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:10:43 feynman kernel: [ 1796.732018] hda: possibly failed opcode: 0xa0
Aug 22 12:10:43 feynman kernel: [ 1796.732024] hda: drive not ready for command
Aug 22 12:10:43 feynman init: Switching to runlevel: 6
Aug 22 12:10:43 feynman acpid: client 2837[0:0] has disconnected
Aug 22 12:10:44 feynman wpa_supplicant[2774]: CTRL-EVENT-SCAN-RESULTS
Aug 22 12:10:51 feynman kernel: [ 1804.324022] hda: status timeout: status=0xd0 { Busy }
Aug 22 12:10:51 feynman kernel: [ 1804.324163] hda: possibly failed opcode: 0xa0
Aug 22 12:10:51 feynman kernel: [ 1804.324220] hda: drive not ready for commandCzytałem kiedyś, że napędy ATAPI emulowane są jako SCSI, tutaj zostało hda; (z kolei pod Ubuntu miałem wszystkie dyski łącznie z napędem jako sd*).
Znalazłem plik, który stworzyłem pod Ubuntu (9.04 AMD64), zawiera on dpkg -l; są tam dwie paczki:
ii libsgutils1 1.24-2 Utilities for working with generic SCSI devi
ii sg3-utils 1.24-2 Utilities for working with generic SCSI devi
