compiz - problem po aktualizacji
timon
Post autor: timon »
Po ostatniej aktualizacji pojawił się problem z compizem. Przy próbie jego uruchomienia pojawiają się takie komunikaty:
tomek@timonowisko:~$ compiz --replace
/usr/bin/compiz.real (ini) - Warn: Could not open main display config file /home/tomek/.compiz/options/general-allscreens.conf
/usr/bin/compiz.real (ini) - Warn: Loading default plugins (ini,inotify,png,decoration,move,resize,switcher)
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/core-allscreens.conf, check you have the correct permissions
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/general-screen0.conf - using defaults for core
inotify_add_watch: No such file or directory
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/decoration-screen0.conf - using defaults for decoration
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/decoration-allscreens.conf - using defaults for decoration
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/decoration-allscreens.conf, check you have the correct permissions
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/move-screen0.conf - using defaults for move
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/move-allscreens.conf - using defaults for move
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/move-allscreens.conf, check you have the correct permissions
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/resize-screen0.conf - using defaults for resize
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/resize-allscreens.conf - using defaults for resize
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/resize-allscreens.conf, check you have the correct permissions
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/switcher-screen0.conf - using defaults for switcher
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/switcher-screen0.conf, check you have the correct permissions
/usr/bin/compiz.real (ini) - Warn: Could not open config file /home/tomek/.compiz/options/switcher-allscreens.conf - using defaults for switcher
/usr/bin/compiz.real (ini) - Error: Failed to write to /home/tomek/.compiz/options/switcher-allscreens.conf, check you have the correct permissions
W /home/tomek nie mam katalogu .compiz i chyba go tam nigdy nie było. Jak utworzyć/odtworzyć całą jego zawartość?
