Sid ma aż nadto aktualizacji
Po dzisiejszej (nie robiłem już kilka dni) błędy:
system jest pół polski pół angielski
Jakiś dziwne kodowanie
Próbowałem kilku rzeczy:
mat@mat:~$ su
Password:
mat:/home/mat# apt-get install locales
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
locales: Depends: glibc-2.5-1 but it is not installable
E: Broken packages
mat:/home/mat# apt-get update
Get:1 [url]http://www.kadu.net[/url] unstable Release.gpg [189B]
Get:2 [url]http://www.kadu.net[/url] testing Release.gpg [189B]
Hit [url]http://www.kadu.net[/url] unstable Release
Hit [url]http://www.kadu.net[/url] testing Release
Hit [url]ftp://ftp.pl.debian.org[/url] sid Release.gpg
Ign [url]http://www.kadu.net[/url] unstable/main Packages/DiffIndex
Ign [url]http://www.kadu.net[/url] testing/main Packages/DiffIndex
Hit [url]http://www.kadu.net[/url] unstable/main Packages
Hit [url]ftp://ftp.pl.debian.org[/url] sid/main Packages/DiffIndex
Hit [url]http://www.kadu.net[/url] testing/main Packages
Hit [url]ftp://ftp.pl.debian.org[/url] sid/non-free Packages/DiffIndex
Hit [url]ftp://ftp.pl.debian.org[/url] sid/contrib Packages/DiffIndex
Hit [url]ftp://ftp.pl.debian.org[/url] sid/main Sources/DiffIndex
Hit [url]ftp://ftp.pl.debian.org[/url] sid/non-free Sources/DiffIndex
Hit [url]ftp://ftp.pl.debian.org[/url] sid/contrib Sources/DiffIndex
Get:3 [url]http://www.debian-multimedia.org[/url] sid Release.gpg [189B]
Hit [url]http://www.debian-multimedia.org[/url] sid Release
Ign [url]http://www.debian-multimedia.org[/url] sid/main Packages/DiffIndex
Hit [url]http://www.debian-multimedia.org[/url] sid/main Packages
Get:4 [url]http://www.vobcopy.org[/url] elive Release.gpg [189B]
Hit [url]http://www.vobcopy.org[/url] elive Release
Ign [url]http://www.vobcopy.org[/url] elive/main Packages/DiffIndex
Ign [url]http://www.vobcopy.org[/url] elive/efl Packages/DiffIndex
Ign [url]http://www.vobcopy.org[/url] elive/elive Packages/DiffIndex
Hit [url]http://www.vobcopy.org[/url] elive/main Packages
Hit [url]http://www.vobcopy.org[/url] elive/efl Packages
Hit [url]http://www.vobcopy.org[/url] elive/elive Packages
Get:5 [url]http://debian.beryl-project.org[/url] etch Release.gpg [191B]
Hit [url]http://debian.beryl-project.org[/url] etch Release
Ign [url]http://debian.beryl-project.org[/url] etch/main Packages/DiffIndex
Ign [url]http://debian.beryl-project.org[/url] etch/main Sources/DiffIndex
Hit [url]http://debian.beryl-project.org[/url] etch/main Packages
Hit [url]http://debian.beryl-project.org[/url] etch/main Sources
Fetched 5B in 17s (0B/s)
mat:/home/mat# apt-get upgrade
The following packages have been kept back:
openoffice.org-help-en-us
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
mat:/home/mat# dpkg -i openoffice.org-help-en-us
dpkg: error processing openoffice.org-help-en-us (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
mat:/home/mat# dpkg-reconfigure-locales
bash: dpkg-reconfigure-locales: command not found
mat:/home/mat# dpkg-reconfigure locales
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "pl_PL.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
/usr/sbin/dpkg-reconfigure: locales is broken or not fully installed
mat:/home/mat# apt-get install glibc-2.5-1
Package glibc-2.5-1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package glibc-2.5-1 has no installation candidate
E: Couldn't find packag
Po za ty jeszcze mam jakieś błędy w bootowaniu
Assuming <jakies kodowanie ISOcośtam> Nount czy coś takiego i ten bład jest kilka razy
