debian:/home/dragonn# dpkg --purge --force-remove-reinstreq wx2.8-headers
(Odczytywanie bazy danych ... 169462 plików i katalogów obecnie zainstalowanych.)
Usuwanie wx2.8-headers ...
Traceback (most recent call last):
  File "/usr/bin/pycentral", line 2096, in <module>
    main()
  File "/usr/bin/pycentral", line 2090, in main
    rv = action.run(global_options)
  File "/usr/bin/pycentral", line 1550, in run
    pkg.read_version_info()
  File "/usr/bin/pycentral", line 804, in read_version_info
    raise PyCentralError, "package has no field Python-Version"
__main__.PyCentralError: package has no field Python-Version
dpkg: błąd przetwarzania wx2.8-headers (--purge):
 podproces installed pre-removal script zwrócił kod błędu 1
    main()
  File "/usr/bin/pycentral", line 1386, in run
dpkg: błąd podczas czyszczenia środowiska:
 podproces installed post-installation script zwrócił kod błędu 1
 wx2.8-headers
Package: wx2.8-headers
Status: purge ok half-configured
Priority: optional
Section: devel
Installed-Size: 8328
Maintainer: wxWidgets dev-team <wx-dev@lists.wxwidgets.org>
Architecture: amd64
Source: wxwidgets2.8
Version: 2.8.10.1-0
Config-Version: 2.8.10.1-1
Description: wxWidgets Cross-platform C++ GUI toolkit (header files)
 wxWidgets (formerly known as wxWindows) is a class library for C++ providing
 GUI components and other facilities on several popular platforms (and some
 unpopular ones as well).  For more information see [url]http://wxwidgets.org[/url]
 This package provides the common header files required to build applications
 using the wxWidgets toolkit.Kod: Zaznacz cały
purge ok half-configured na install ok installedKod: Zaznacz cały
Config-Version
