[+] Czy to problem z dyskiem, czy z systemem?
skiba
Post autor: skiba »
Witam wszystkich.
Od pewnego czasu zaobserwowałem niepokojące logi w kernel.log. Byłbym wdzięczny za pomoc w ich rozszyfrowaniu.
Jul 20 05:04:05 kopytko kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Jul 20 05:04:05 kopytko kernel: ata1.00: (BMDMA stat 0x20)
Jul 20 05:04:05 kopytko kernel: ata1.00: tag 0 cmd 0x25 Emask 0x9 stat 0x51 err 0x40 (media error)
Jul 20 05:04:05 kopytko kernel: ata1: EH complete
Jul 20 05:04:11 kopytko kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Jul 20 05:04:11 kopytko kernel: ata1.00: (BMDMA stat 0x20)
Jul 20 05:04:11 kopytko kernel: ata1.00: tag 0 cmd 0x25 Emask 0x9 stat 0x51 err 0x40 (media error)
Jul 20 05:04:11 kopytko kernel: ata1: EH complete
Jul 20 05:04:16 kopytko kernel: SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
Jul 20 05:04:16 kopytko kernel: sda: Write Protect is off
Jul 20 05:04:16 kopytko kernel: sda: Mode Sense: 00 3a 00 00
Jul 20 05:04:17 kopytko kernel: SCSI device sda: drive cache: write back
Jul 20 05:04:17 kopytko kernel: SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
Jul 20 05:04:17 kopytko kernel: sda: Write Protect is off
Jul 20 05:04:17 kopytko kernel: sda: Mode Sense: 00 3a 00 00
Jul 20 05:06:03 kopytko kernel: smb_add_request: request [c900de80, mid=50428] timed out!
Jul 20 05:06:13 kopytko kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Jul 20 05:06:15 kopytko kernel: ata1.00: (BMDMA stat 0x20)
Jul 20 05:06:15 kopytko kernel: ata1.00: tag 0 cmd 0x25 Emask 0x9 stat 0x51 err 0x40 (media error)
Jul 20 05:06:15 kopytko kernel: ata1: EH complete
Jul 20 05:06:15 kopytko kernel: SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
Jul 20 05:06:15 kopytko kernel: sda: Write Protect is off
Jul 20 05:06:15 kopytko kernel: sda: Mode Sense: 00 3a 00 00
Jul 20 05:06:15 kopytko kernel: SCSI device sda: drive cache: write back
Częściowo rozwiązany problem (dopisane w pierwszym poście):
http://debian.linux.pl/viewtopic.php?p=46309#46309
Przedstaw wynik polecenia:
uname -r
skiba
Post autor: skiba »
Dziękuje za odpowiedź. Przetestuje podpowiedź w wolnym czasie. Poniżej wynik uname -r
kopytko:~# uname -r
2.6.18-6-686
Przedstaw jeszcze wynik polecenia:
lspci -k
skiba
Post autor: skiba »
fnmirk pisze:Przedstaw jeszcze wynik polecenia:
lspci -k
Niestety system wywala mi że nie ma takiej opcji jak -k. Poniżej wynik lspci -vvx
kopytko:~# lspci -vvx
00:00.0 Host bridge: Intel Corporation Unknown device 29f0
        Subsystem: Intel Corporation Unknown device 34d0
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort+ >SERR- <PERR-
        Latency: 0
        Capabilities: [e0] Vendor Specific Information
00: 86 80 f0 29 46 01 90 30 00 00 00 06 00 00 00 00
10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 e0 00 00 00 00 00 00 00 00 00 00 00
00:1a.0 USB Controller: Intel Corporation Unknown device 2937 (rev 02) (prog-if 00 [UHCI])
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Latency: 0
        Interrupt: pin A routed to IRQ 201
        Region 4: I/O ports at 20c0 [size=200]
        Capabilities: [50] #13 [0306]
00: 86 80 37 29 05 00 90 02 02 00 03 0c 00 00 80 00
20: c1 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 09 01 00 00
00:1a.1 USB Controller: Intel Corporation Unknown device 2938 (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin B routed to IRQ 209
        Region 4: I/O ports at 20a0 [size=200]
00: 86 80 38 29 05 00 90 02 02 00 03 0c 00 00 00 00
20: a1 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 0a 02 00 00
00:1a.2 USB Controller: Intel Corporation Unknown device 2939 (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin C routed to IRQ 169
        Region 4: I/O ports at 2080 [size=200]
00: 86 80 39 29 05 00 90 02 02 00 03 0c 00 00 00 00
20: 81 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 0a 03 00 00
00:1a.7 USB Controller: Intel Corporation Unknown device 293c (rev 02) (prog-if 20 [EHCI])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
        Latency: 0
        Region 0: Memory at e1a00400 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [58] Debug port
        Capabilities: [98] #13 [0306]
00: 86 80 3c 29 06 01 90 02 02 20 03 0c 00 00 00 00
10: 00 04 a0 e1 00 00 00 00 00 00 00 00 00 00 00 00
00:1c.0 PCI bridge: Intel Corporation Unknown device 2940 (rev 02) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Latency: 0, Cache Line Size: 64 bytes
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity+ SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
        Capabilities: [40] Express Root Port (Slot+) IRQ 0
                Device: Supported: MaxPayload 128 bytes, PhantFunc 0, ExtTag-
                Device: Latency L0s <64ns, L1 <1us
                Device: Errors: Correctable- Non-Fatal+ Fatal+ Unsupported-
                Device: RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                Device: MaxPayload 128 bytes, MaxReadReq 128 bytes
                Link: Supported Speed 2.5Gb/s, Width x4, ASPM L0s L1, Port 1
                Link: Latency L0s <1us, L1 <4us
                Link: ASPM Disabled RCB 64 bytes CommClk- ExtSynch-
                Link: Speed 2.5Gb/s, Width x0
                Slot: AtnBtn- PwrCtrl- MRL- AtnInd- PwrInd- HotPlug+ Surpise+
                Slot: Number 1, PowerLimit 25.000000
                Slot: Enabled AtnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq-
                Slot: AttnInd Unknown, PwrInd Unknown, Power-
                Root: Correctable- Non-Fatal- Fatal- PME-
        Capabilities: [80] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable+
                Address: fee00000  Data: 40b9
        Capabilities: [90] Subsystem: Intel Corporation Unknown device 2940
        Capabilities: [a0] Power Management version 2
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [100] Virtual Channel
        Capabilities: [180] Unknown (5)
00: 86 80 40 29 47 05 10 00 02 00 04 06 10 00 81 00
10: 00 00 00 00 00 00 00 00 00 01 01 00 f0 00 00 20
20: f0 ff 00 00 f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 0b 01 03 00
00:1c.4 PCI bridge: Intel Corporation Unknown device 2948 (rev 02) (prog-if 00 [Normal decode])
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR-
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: e1000000-e18fffff
        Prefetchable memory behind bridge: 00000000e0000000-00000000e0ffffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity+ SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
                Link: Supported Speed 2.5Gb/s, Width x1, ASPM L0s L1, Port 5
                Link: Latency L0s <256ns, L1 <4us
                Link: ASPM Disabled RCB 64 bytes CommClk+ ExtSynch-
                Link: Speed 2.5Gb/s, Width x1
                Slot: Number 5, PowerLimit 10.000000
                Address: fee00000  Data: 40c1
        Capabilities: [90] Subsystem: Intel Corporation Unknown device 2948
00: 86 80 48 29 47 05 10 08 02 00 04 06 10 00 81 00
10: 00 00 00 00 00 00 00 00 00 02 02 00 f0 00 00 30
20: 00 e1 80 e1 01 e0 f1 e0 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 0b 01 1b 00
00:1d.0 USB Controller: Intel Corporation Unknown device 2934 (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin A routed to IRQ 217
        Region 4: I/O ports at 2060 [size=200]
00: 86 80 34 29 05 00 90 02 02 00 03 0c 00 00 80 00
20: 61 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 0b 01 00 00
00:1d.1 USB Controller: Intel Corporation Unknown device 2935 (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin B routed to IRQ 225
        Region 4: I/O ports at 2040 [size=200]
00: 86 80 35 29 05 00 90 02 02 00 03 0c 00 00 00 00
20: 41 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 0b 02 00 00
00:1d.2 USB Controller: Intel Corporation Unknown device 2936 (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin C routed to IRQ 201
        Region 4: I/O ports at 2020 [size=200]
00: 86 80 36 29 05 00 90 02 02 00 03 0c 00 00 00 00
20: 21 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 50 00 00 00 00 00 00 00 09 03 00 00
00:1d.7 USB Controller: Intel Corporation Unknown device 293a (rev 02) (prog-if 20 [EHCI])
        Latency: 0
        Region 0: Memory at e1a00000 (32-bit, non-prefetchable) [size=1K]
00: 86 80 3a 29 06 01 90 02 02 20 03 0c 00 00 00 00
10: 00 00 a0 e1 00 00 00 00 00 00 00 00 00 00 00 00
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92) (prog-if 01 [Subtractive decode])
        Latency: 0
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: e1900000-e19fffff
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        Capabilities: [50] Subsystem: Intel Corporation Unknown device 34d0
00: 86 80 4e 24 47 01 10 00 92 01 04 06 00 00 01 00
10: 00 00 00 00 00 00 00 00 00 03 03 20 10 10 80 22
20: 90 e1 90 e1 f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 50 00 00 00 00 00 00 00 ff 00 03 00
00:1f.0 ISA bridge: Intel Corporation Unknown device 2916 (rev 02)
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Latency: 0
00: 86 80 16 29 47 01 10 02 02 00 01 06 00 00 80 00
00:1f.2 IDE interface: Intel Corporation Unknown device 2920 (rev 02) (prog-if 8a [Master SecP PriP])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Latency: 0
        Interrupt: pin A routed to IRQ 209
        Region 0: I/O ports at <ignored>
        Region 1: I/O ports at <ignored>
        Region 2: I/O ports at <ignored>
        Region 3: I/O ports at <ignored>
        Region 4: I/O ports at 2410 [size=200]
        Region 5: I/O ports at 2400 [size=200]
        Capabilities: [70] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [b0] #13 [0306]
00: 86 80 20 29 07 00 b0 02 02 8a 01 01 00 00 00 00
10: 39 24 00 00 4d 24 00 00 31 24 00 00 49 24 00 00
20: 11 24 00 00 01 24 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 70 00 00 00 00 00 00 00 0a 01 00 00
00:1f.3 SMBus: Intel Corporation Unknown device 2930 (rev 02)
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Interrupt: pin B routed to IRQ 201
        Region 0: Memory at e1a00800 (64-bit, non-prefetchable) [size=200]
        Region 4: I/O ports at 2000 [size=200]
00: 86 80 30 29 03 01 80 02 02 00 05 0c 00 00 00 00
10: 04 08 a0 e1 00 00 00 00 00 00 00 00 00 00 00 00
20: 01 20 00 00 00 00 00 00 00 00 00 00 86 80 d0 34
30: 00 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00
00:1f.5 IDE interface: Intel Corporation Unknown device 2926 (rev 02) (prog-if 85 [Master SecO PriO])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B-
        Latency: 0
        Region 0: I/O ports at 2428 [size=200]
        Region 1: I/O ports at 2444 [size=134]
        Region 2: I/O ports at 2420 [size=200]
        Region 3: I/O ports at 2440 [size=134]
        Region 4: I/O ports at 20f0 [size=200]
        Region 5: I/O ports at 20e0 [size=200]
00: 86 80 26 29 47 00 b0 02 02 85 01 01 00 00 00 00
10: 29 24 00 00 45 24 00 00 21 24 00 00 41 24 00 00
20: f1 20 00 00 e1 20 00 00 00 00 00 00 86 80 d0 34
02:00.0 VGA compatible controller: Matrox Graphics, Inc. MGA G200e [Pilot] ServerEngines (SEP1) (rev 02) (prog-if 00 [VGA])
        Subsystem: Intel Corporation Unknown device 0101
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort- >SERR- <PERR-
        Interrupt: pin A routed to IRQ 11
        Region 0: Memory at e0000000 (32-bit, prefetchable) [size=16M]
        Region 1: Memory at e1800000 (32-bit, non-prefetchable) [size=16K]
        Region 2: Memory at e1000000 (32-bit, non-prefetchable) [size=8M]
        Expansion ROM at e1810000 [disabled] [size=64K]
        Capabilities: [dc] Power Management version 2
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Capabilities: [e4] Express Legacy Endpoint IRQ 0
                Device: AtnBtn- AtnInd- PwrInd-
                Device: Errors: Correctable- Non-Fatal- Fatal- Unsupported-
                Link: Supported Speed 2.5Gb/s, Width x1, ASPM L0s, Port 0
                Link: Latency L0s <64ns, L1 <1us
        Capabilities: [54] Message Signalled Interrupts: Mask- 64bit- Queue=0/0 Enable-
                Address: 00000000  Data: 0000
00: 2b 10 22 05 07 00 10 10 02 00 00 03 10 00 00 00
10: 08 00 00 e0 00 00 80 e1 00 00 00 e1 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 01 01
30: 00 00 ff ff dc 00 00 00 00 00 00 00 0b 01 00 00
03:02.0 Ethernet controller: Intel Corporation 82541GI/PI Gigabit Ethernet Controller (rev 05)
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr+ Stepping- SERR+ FastB2B-
        Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
        Latency: 32 (63750ns min), Cache Line Size: 64 bytes
        Region 0: Memory at e1920000 (32-bit, non-prefetchable) [size=128K]
        Region 1: Memory at e1900000 (32-bit, non-prefetchable) [size=128K]
        Region 2: I/O ports at 1000 [size=200]
        Expansion ROM at fffe0000 [disabled] [size=128K]
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [e4] PCI-X non-bridge device
                Command: DPERE- ERO+ RBC=512 OST=1
                Status: Dev=00:00.0 64bit- 133MHz- SCD- USC- DC=simple DMMRBC=2048 DMOST=1 DMCRS=8 RSCEM- 266MHz- 533MHz-
00: 86 80 76 10 57 01 30 02 05 00 00 02 10 20 00 00
10: 00 00 92 e1 00 00 90 e1 01 10 00 00 00 00 00 00
30: 00 00 fe ff dc 00 00 00 00 00 00 00 09 01 ff 00
Wykonaj aktualizację do jakieś nowszej wersji systemu. Przynajmniej do Lenny.
skiba
Post autor: skiba »
Problem rozwiązany.
Dla potomnych, wina leżała jednak po stronie dysku. Po około tygodniu od pojawienia się pierwszych błędów dysk odmówił posłuszeństwa.
