./serioussam2
./Bin/Linux-Dynamic-Release/Sam2: error while loading shared libraries: libopenal.so.0: cannot open shared object file: No such file or directoryKod: Zaznacz cały
./serioussam2
aptitude update
aptitude install libopenal1Kod: Zaznacz cały
updatedbKod: Zaznacz cały
locate libopenalKod: Zaznacz cały
/home/blyskawica/.games/Spring/libs/libopenal.so.1
/.svn/prop-base/libopenal.so.svn-base
/.svn/props/libopenal.so.svn-work
/usr/lib/libopenal.a
/usr/lib/libopenal.so
/usr/lib/libopenal.so.1
/usr/lib/libopenal.so.1.4.272
/usr/share/doc/libopenal-dev
/usr/share/doc/libopenal1
/usr/share/doc/libopenal-dev/README.Debian
/usr/share/doc/libopenal-dev/changelog.Debian.gz
/usr/share/doc/libopenal-dev/copyright
/usr/share/doc/libopenal1/changelog.Debian.gz
/usr/share/doc/libopenal1/copyright
/usr/share/doc/libopenal1/examples
/usr/share/doc/libopenal1/examples/alsoftrc.sample.gz
/var/cache/apt/archives/libopenal-dev_1%3a1.4.272-2_amd64.deb
/var/lib/dpkg/info/libopenal-dev.list
/var/lib/dpkg/info/libopenal-dev.md5sums
/var/lib/dpkg/info/libopenal1.conffiles
/var/lib/dpkg/info/libopenal1.list
/var/lib/dpkg/info/libopenal1.md5sums
/var/lib/dpkg/info/libopenal1.postinst
/var/lib/dpkg/info/libopenal1.postrm
/var/lib/dpkg/info/libopenal1.shlibs
ln -s /usr/lib/libopenal.so /usr/lib/libopenal.so.0niestety nie pomogłomeciarz pisze:Kod: Zaznacz cały
ldd /Bin/Linux-Dynamic-Release/Sam2Kod: Zaznacz cały
ldd serioussam2 Kod: Zaznacz cały
ldd serioussam2
nie jest dynamicznym programem wykonywalnym
