lspci -kKod: Zaznacz cały
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 10)
Subsystem: Giga-byte Technology Device 5000
Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 10)
Kernel driver in use: pcieport-driver
Kernel modules: shpchp
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
Subsystem: Giga-byte Technology Device a002
Kernel driver in use: HDA Intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
Subsystem: Giga-byte Technology Device 5004
Kernel driver in use: uhci_hcd
Kernel modules: uhci-hcd
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
Subsystem: Giga-byte Technology Device 5006
Kernel modules: ehci-hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
Subsystem: Giga-byte Technology Device 5001
Kernel modules: intel-rng, iTCO_wdt
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
Subsystem: Giga-byte Technology Device b001
Kernel driver in use: PIIX_IDE
Kernel modules: piix, ide-pci-generic, ata_generic
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) SATA IDE Controller (rev 01)
Subsystem: Giga-byte Technology Device b002
Kernel driver in use: ata_piix
Kernel modules: ide-pci-generic, ata_piix, ata_generic
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
Subsystem: Giga-byte Technology GA-8I945PG-RH Mainboard
Kernel driver in use: i801_smbus
Kernel modules: i2c-i801
01:00.0 VGA compatible controller: nVidia Corporation G84 [GeForce 8600 GT] (rev a1)
Kernel driver in use: nvidia
Kernel modules: nvidiafb
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
Subsystem: Giga-byte Technology GA-EP45-DS5 Motherboard
Kernel driver in use: r8169
Kernel modules: r8169
04:01.0 Ethernet controller: Sundance Technology Inc / IC Plus Corp IC Plus IP100A Integrated 10/100 Ethernet MAC + PHY (rev 31)
Subsystem: ASUSTeK Computer Inc. NX1001
Kernel driver in use: sundance
Kernel modules: sundanceKod: Zaznacz cały
ifconfigKod: Zaznacz cały
eth0 Link encap:Ethernet HWaddr 00:1f:d0:da:6e:0f
inet addr:78.28.44.129 Bcast:78.28.44.255 Mask:255.255.255.128
inet6 addr: fe80::21f:d0ff:feda:6e0f/64 Scope:Link
RX packets:4349 errors:0 dropped:158160459139 overruns:0 frame:0
TX packets:2877 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2285399 (2.1 MiB) TX bytes:705212 (688.6 KiB)
Interrupt:252 Base address:0x2000
lo Link encap:Local Loopback
RX packets:168 errors:0 dropped:0 overruns:0 frame:0
TX packets:168 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:10480 (10.2 KiB) TX bytes:10480 (10.2 KiB)Kod: Zaznacz cały
ifconfig eth1Kod: Zaznacz cały
eth1 Link encap:Ethernet HWaddr 00:1f:c6:34:d6:79
BROADCAST MULTICAST MTU:1500 Metric:1
Interrupt:19 Base address:0xd000Kod: Zaznacz cały
/etc/network/interfacesKod: Zaznacz cały
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet dhcp
#LAN - Asus NX1001
allow-hotplug eth1
iface eth1 inet static
adress 10.0.0.1
netmask 255.255.255.0
dns-nameservers 10.0.0.1Edycja:
Okazało się że popełniłem jedną literówkę, zamiast address napisałem adress, jak mówi Google nie tylko ja miałem z tym problem.
auto lo
allow-hotplug eth0
#LAN - Asus NX1001
allow-hotplug eth1
address 10.0.0.1
