zxdsl 852v2 vs Debian 5.0.1
spinaczel
Post autor: spinaczel »
Instaluje wszystko według poradnika draco (http://draco.almexia.com/id/317977/)
i przy dkms wyskakuje mi:
debian:/usr/src# dkms build -m unicorn -v neo
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area....
make KERNELRELEASE=2.6.29 KERNEL_SOURCES=/lib/modules/2.6.29/build modules....(bad exit status: 2)
Error! Bad return status for module build on kernel: 2.6.29 (x86_64)
Consult the make.log in the build directory
/var/lib/dkms/unicorn/neo/build/ for more information.
0
0
make.log:
debian:/usr/src# cat /var/lib/dkms/unicorn/neo/build/make.log
DKMS make.log for unicorn-neo for kernel 2.6.29 (x86_64)
śro, 8 lip 2009, 11:54:47 CEST
for i in unicorn_usb  ; do make -C $i modules MODDIR=/var/lib/dkms/unicorn/neo/build/$i ; done
make[1]: Wejście do katalogu `/var/lib/dkms/unicorn/neo/build/unicorn_usb'
make CC=cc -C /lib/modules/2.6.29/build SUBDIRS=/var/lib/dkms/unicorn/neo/build/unicorn_usb modules
make[2]: Wejście do katalogu `/root/linux-2.6.29'
 CC [M]  /var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv  .o
In file included from /var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.h:31,
                from /var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:25:
/var/lib/dkms/unicorn/neo/build/unicorn_usb/../include/debug.h:3  4:1: warning: "WARN" redefined
In file included from /root/linux-2.6.29/arch/x86/include/asm/bug.h:38,
                from include/linux/kernel.h:21,
                from /var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:22:
include/asm-generic/bug.h:81:1: warning: this is the location of the previous definition
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'dump_urb':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:190  : error: 'struct urb' has no member named 'bandwidth'
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'fill_isoc_urb':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:210  : error: 'struct urb' has no member named 'lock'
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'StartAtmUsXfer':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:447  : warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:454  : warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'atm_stop_rcv':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:575  : warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'atm_start_rcv':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:658  : warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:664  : warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'adjust_bandwidth':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:853  : warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'start_device':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:165  0: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'term_usb_urb':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:183  9: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:184  7: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:185  4: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:186  3: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:187  3: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:188  4: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:189  4: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:190  3: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:191  0: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'USB_S_Write':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:227  2: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:227  9: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:228  6: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:230  1: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'USB_L_Write':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:235  1: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:235  6: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:236  5: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:237  9: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'USB_S_Read':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:244  2: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:246  2: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:247  6: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:249  9: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:250  8: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:251  8: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:254  9: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:255  2: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function 'USB_L_Read':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:261  6: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:263  5: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:264  6: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:267  0: warning: passing argument 7 of 'fill_isoc_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:267  9: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:268  7: warning: passing argument 6 of 'usb_fill_int_urb' from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:271  7: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:272  0: warning: statement with no effect
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_ActivationMode':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  0: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_AlternativeSetting':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  1: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_AutoActivation':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  2: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_DownstreamRate':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  3: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_LoopbackMode':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  4: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_MswDebugLevel':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  5: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_RetryTime':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  6: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_DebugLevel':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:319  8: warning: return from incompatible pointer type
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c: In function '__check_ledScenario':
/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.c:320  0: warning: return from incompatible pointer type
make[3]: *** [/var/lib/dkms/unicorn/neo/build/unicorn_usb/unicorn_usbdrv.o] Błąd 1
make[2]: *** [_module_/var/lib/dkms/unicorn/neo/build/unicorn_usb] Błąd 2
make[2]: Opuszczenie katalogu `/root/linux-2.6.29'
make[1]: *** [modules] Błąd 2
make[1]: Opuszczenie katalogu `/var/lib/dkms/unicorn/neo/build/unicorn_usb'
make: *** [modules] Błąd 2
Debian Lenny na architekturze amd64, wersja kernela 2.6.29.
Jakieś pomysly?
spinaczel pisze:Jakieś pomysły?
Kupić dobry ruter, a ten modem wyrzucić i zapomnieć o nim.
spinaczel
A jakies bardziej satysfakcjonujace rozwiazanie? :P
